Question about HP D2835 17 in. CRT Monitor
Horizontal line when switched on only a white horizontal line appear
0 characters
1 Points
When i switch on my system, my Crt monitor is showing horizontal lines(not perfectly horizontal). It seems that the original display is breaking down into strips of horizontal lines. I googled the problem...
I would suggest getting a new monitor as trying to fix a problem with circuitry will often create more, leave it to the professionals. Are you sure it's the monitor? it could very well be the graphics, Buy a new monitor(or use a friends) to test your computer's graphics card. If the lines appear again then you need a new graphics card. If the lines are not there its time to buy a new monitor
Jun 20, 2010 | Computer Monitors
Very horizontal faint white lines running down the screen
check if the line appears in BIOS...dont worry when i say BIOS...not sure how to check...turn the system off...restart the system and keep tapping the F2 would get a Blue screen...check if the lines appear on this screen...if it could either be b'cause the display driver has gone wrong or the system might have a physical damage.....if the lines does not occur on this is a manufacturing defect...please contact the manufacturer and report the issue for solution.......
Jan 12, 2010 | Acer AL1717 17" LCD Monitor
Horizontal line appears on my PC Acer screen and
There are two possibilities: That the monitor is bad, or that the video board is bad.
The easiest way to test is to install a different monitor and see if it does the same.
If it does the same, then it is the video board. If not, it is the monitor.
Sep 17, 2009 | Emprex LM2201 22" LCD Monitor
A vertical white line appears on my LG L1520B 15 monitor
This is a horizontal sync circuit gone.
In English, probably cheaper to replace than repair.
Wouldn't hurt to get a quote if it is free.
Jul 29, 2009 | LG L1520B 15" LCD Monitor
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Horizontal lines
i suggest you change video board .
Apr 19, 2008 | Samsung SyncMaster 152N 15" LCD Monitor
HP L1706 monitor with thin white/blue horizontral line
It is the problem of monitor pcb in vertical section.check vertical ic for dry soldring. Resolder the ic if problem still on then change ic or check components related ith it. check continuity of vertical deflection coil.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 13, 2008 | HP L1706 17" LCD Monitor
Horizontal lines
sometimes I encounter vertical lines below..... when i tap the sides it clears for a time being  but after a few moment again appears
Dec 06, 2007 | AOC 19LVWK LCD Monitor
HP D2835 17 in. CRT Monitor Logo
20 people viewed this question
Top HP Computer Monitors Experts
Ivan Bernal
Level 1 Expert
Tony Isted
Level 1 Expert
Elizabeth Mescall
Level 1 Expert
Are you a HP Computer Monitor Expert? Answer questions, earn points and help others
