Question about Dell F3534 Touchpad
My touchpad is too sensitive, how do I adjust it?
  • 4,281 Answers
Go to start menu -> control panel then touch pad option then adjust your touch pad settings.
Let me know if you need more assistanse.
Thanks.
Posted on Sep 24, 2009
  • I C Gupta Jul 18, 2011
    Thanks a lot,my problem of touchpad too much sensitive is solved.
    I.C.Gupta
    icgupta@gmail.com
3 Suggested Answers
  • 126 Answers
SOURCE: how do I adjust the sensitivity on the touchpad?
Try going to Start-->Control Panel-->Mouse
Under there should be an option that allows you to change the mouse speed
Posted on Jul 11, 2009
  • 232 Answers
SOURCE: Is there download software that will alow me to
If you go in to control panel in Windows XP and in to the Mouse option you can control the mouse speed.
Alternatively the downloads for your laptop can be found here.
Posted on Dec 15, 2009
How do i fix keystrokes that jump backward as I type?
Some Lenovo touchpads are over sensitive and they cause the cusor to slip or jump around. In Control Panel select Mouse or Touchpad. A box will open and you can locate touchpad Properties and adjust the sensitivity. Lenovo also has updated touchpad software/drivers for one or two of the most troublesome models. i was able to reduce the cursor jumping around quite a bit by adjusting the sensitivity, but i still don't think it's a good design.
Aug 12, 2014 | Lenovo Computers & Internet
Gateway the touch pad not function why?
Adjusting the touchpad sensitivity on a Gateway laptop lets you fix and prevent annoying touchpad problems.
Often the touchpad is accidentally brushed while typing, which causes the cursor to move out of place.
Or you may find yourself having to tap too hard or too often on the touchpad to open windows and programs.
These problems can be fixed by simply adjusting the touchpad's sensitivity settings.
Click the "Start" button and double-click "Control Panel."
Double-click "Hardware & Sound" and choose "Mouse" to open the mouse properties box.
Choose the "Device Settings" tab. Highlight "Synaptic Touchpad" in the Devices box by clicking on it. Click the "Settings" button underneath the Devices box.
Choose "Sensitivity" in the properties settings box.
Click "PalmCheck" to adjust the sensitivity of the touchpad to accidental brushes against the pad while typing, which causes the cursor to move.
Click and hold the pointer to adjust the setting on the sensitivity scale.
Click "Touch Sensitivity" to adjust the sensitivity of the touchpad to tapping.
A higher rating on the scale means less tapping pressure will be needed.
Click "OK" to save your touchpad settings.
May 15, 2013 | Acer Aspire Computers & Internet
How to adjust touchpad sensitivity on dell inspiron 1525
Open Control Panel, Mouse, I don't know your OS?, OR, in the Tray Notification Area, open the Touchpad software Icon, maybe synaptics touchpad, settings, sensitivity Take a look at the Dell forum: http://search.dell.com/results.aspx?c=us&l=en&s=gen&cat=cmu&k=adjust+touchpad+sensitivity&rpp=12&p=1&rf=all&nk=f&ira=False&~srd=False&ipsys=False&advsrch=False
Feb 08, 2013 | Computers & Internet
Cursor does not move when running my finger over the touch pad. Thank You Bill
1. Adjust the touchpad sensitivity from the control panel. Perhaps lessening the sensitivity will solve the problem. In Windows OS go to your control panel, and select hardware and sound. Then click "mouse," and when the new window pops up select the settings tab. From there you can adjust the sensitivity. If your mouse came with its own software you may be able to adjust the settings from the system panel. Hover your mouse over the icons near the system clock, and look for an icon that is titled touchpad, or mouse. You can click this icon and adjust settings.
2. Clean the touchpad with rubbing alcohol in case there is a grease buildup on the touchpad. This is the most common cause for touchpad failure.
3. Remove the touchpad drivers from device manager and reinstall. Sometimes there can be driver errors that are preventing the touchpad from working. Device manager can be accessed via control panel in Windows systems.
4. Replace the touchpad if none of these steps work. Prices can range from $15 to $50 plus labor rates. It is best to let a computer professional change this since major disassembly is required to remove and replace the touchpad, and many fragile components will be exposed during this process.
Hope this help. Goodluck!
Mar 28, 2011 | Computers & Internet
I have a Dell laptop computer with Windows Vista Basic. The mouse on the screen has become very sensitive and sometimes it clicks on an item when it scrolls across the screen. How can I make it less...
  1. Right-click on the desktop and select Personalize > Mouse Pointers . The Mouse Properties settings window will open.
  2. Alternately, click Start and type Mouse in the Search field, and select Mouse when it becomes available in the program list. The Mouse Properties settings window will open.
  3. Select the Device Settings tab. Select the Synaptics TouchPad device and click Settings . In the Properties for Synaptics TouchPad window, expand the Sensitivity topic.
  4. Select the PalmCheck option to adjust the sensitivity of the touchpad to avoid erratic cursor movement caused by accidental touching of the pad during normal typing.
  5. Select the Touch Sensitivity option to adjust how much finger pressure is required to move the mouse on the screen and how responsive the touchpad is to taps.
Jul 12, 2010 | Dell Vostro 1000 Notebook
Is there download software that will alow me to adjust my touchpad sensitivity? The touchpad on my Dell 610 laptop is much too sensitive. I cannot find the usual software on my harddrive used to decrease...
Dec 15, 2009 | Dell F3534 Touchpad
How do i adjust the sensitivity of the touchpad of acer 4730z?
Go to START, CONTROL PANEL, click MOUSE.
Now click POINTER OPTIONS tab and in here, you can adjust the speed and precision of the mouse pointer.
Nov 06, 2009 | Acer Aspire One Netbook 8.9" Notebook
Touch pad too sensitive, it always messes me up when I'm typing
You could try adjust the touchpad settings. Sometimes there is a touchpad icon in the taskbar that you can right click on to adjust the properties. You can also disable the pad and use a USB mouse instead.
Sep 11, 2009 | Sony 4-660-223-01 Touchpad Keyboard
How do I adjust the sensitivity on the touchpad?
Jul 10, 2009 | Compaq Evo Notebook Keyboard N610C/N600c
Computers & Internet Logo
728 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
