Question about Samsung LN26A450C LCD TV
Samsung LN26A450 LN26A450C1DXZA won't turn on
Red stand by led is on but TV won't turn on. My warranty expired on 09/11/2009 and the TV broke on 09/20/2009! I purchased it on 09/11/2008 at Best Buy with no extra protection plan. My main TV is also samsung (42" DLP) and it died about 20 months after purchase. However, Best Buy fixed that one since I had $400 4-year protection plan. I will never buy Samsung products again. I just created Samsung repair ticket. 1 way shipping costs $81 from FL to NJ (repair center). I have to pay $162 just for shipping PLUS repair cost. I don't recommend Samsung products to anybody.
  • 4 Answers
I had the same problem with my Samsung LN26A450 LCD TV. I found the following YouTube video http://www.youtube.com/watch?v=Mm51C_RDIZE titled "Samsung TV Repair - Part 1 of 2) (also watch Part 2 of 2) which shows how to easily fix the problem. The problem is bad capacitors on the power supply board. My TV had seven (7) bad capacitors - all 7 had dark stains on the ends from leaking electrolytic fluid and one (10V 2200MFD) was blown with bulging ends. I ordered 7 new high-temp (105 degrees C) aluminum radial capacitors from DigiKey.com matching the Temperature, Capacitances and Voltage Ratings for each damaged capacitor that I removed. I followed the instructions in the video except I used desoldering braid ($3.99 at RadioShack) to remove the solder attaching the bad capacitor leads to the power supply board. Once you wick up the old solder from all sides of each lead wire using the desoldering braid, the bad capacitors are easily removed. Total cost of repair including soldering equipment was less than $50. Thanks to “The Professor” for posting the video and saving me $400.
Posted on Oct 30, 2009
  • 3 Answers
My Samsung TV, model LN26A450, would not turn on. The red light would flicker a little when I pressed the power button, but that is all. It was obviously a border line problem, because when the room warmed up, the TV would work, but when the room was cold, the TV was dead.
As a lot of people have pointed out, the problem was a capacitor in the power supply. There was a 2200uf, 10v, 105c capacitor that had a slight bulge on the top. Interestingly, this one capacitor was a lighter shade of blue than the rest.
The TV was easy to take apart, and it was easy to remove the power supply. It took some close examination to find the capacitor with the bulge. The next step was replacing that capacitor.
Luckily, replacement capacitors are available on Amazon. I found mine here.
http://www.amazon.com/gp/product/B0044JL9T4
There are also kits available that include all the capacitors on the power supply.
To replace the capacitor, you will need a soldering iron and some thin solder.
Remove the bad capacitor(s) using the soldering iron. Be sure to note the polarity before you pull it out. Cut the leads on the new capacitor so that they are the same length as the old one. Then insert the new capacitor using the right polarity. It might be necessary to melt the existing solder to insert the leads. Once the leads are inserted, melt a little bit of new solder into the holes to ensure good contact.
Hope this helps.
Posted on Nov 14, 2011
Samsung UN55FH6003FXZA won't turn on even though the red LED on the front is lit showing power is available. It did have a long delay to turn on, now not at all.
Samsung TV won't turn on + blinking red light (explained fix ...
? 4:03
https://www.youtube.com/watch?v=wEWzYLaKdgU
Aug 29, 2014 - Uploaded by Mysimplefix
(CC) (HD) A step-by-step repair video, showing the replacement of swollen/shorted "electrolytic capacitors ...Missing: un55fh6003fxza
bout 1,270 results (0.53 seconds) Search ResultsSamsung LCD TV LN32A330 power won't turn on - Forums - CNETwww.cnet.com > Forums > SamsungCNETMy 1 1/2 year-old LCD TV model LN32A330 won't turn on by direct and remote today. The red stand-by light is lit, but never blinks and the TV won't power up. A..Samsung UN55FH6003FXZA BN94-06418R Main Board ...www.shopjimmy.com/samsung-un55fh6003fxza-bn94-0641...ShopJimmyThis Samsung UN55FH6003FXZA BN94-06418R Main Board IC901 EEPROM ONLY ... TV won't turn on after being off for 30+ minutes - TV shuts off by itself
Jan 05, 2016 | Samsung Televison & Video
Samsung led tv won't power on - red power light is flashing
check the conections between psu and led bars,if the problem still,then the problem is in the led bar board.
Aug 22, 2014 | Samsung UN40D5500 40" 1080p LED TV - Ultra...
I have a 46 inch Panasonic plasma a.HDTV I shipped it on a airplane got home the inside glass was cracked only got 2 weeks of use before i put it in storage every TV repair man tells me its gonna cost more...
If your talking about the front plate go to E-BAY, If all else works and put this in >
Samsung LN26A450 LN26A450C1DXZA /front plate glass
I seen a couple there for $35.00 and installation at local TV repair shop will be cheap less then $100.00 but most wont cover warranty on glass only workmanship. good luck!
Apr 29, 2013 | Televison & Video
Samsung LN26A450 screen won't work
Your model Samsung falls under a class actions settlement. These units have defective power supply boards and Samsung has agreed to pay for the repair / replacement of the boards at no cost to the user even if the unit is out of standard warranty. This sounds like the issue with your TV. Here is a link with additional information about the settlement and how to get the warranty work completed.
http://www.ccl-la.com/blog/index.php/samsung-has-reached-a-settlement-in-class-action-lawsuit-over-faulty-tv-power-supplies/
Sep 09, 2012 | Samsung LN26A450C LCD TV
My samsung LED TV turns on sometines and other times the red light stays on and won't respond to remote control
leave the tv disconnected for a while because if you keep messing with it like my kids did and it will cause the bulb inside to burn out and will not even be worth fixing
Dec 13, 2011 | Televison & Video
I have a samsung LN-S3238D lcd tv. the unit is approx 3 - 4 yrs old. last night when watching tv the tv shut off by itself and will not turn back on. normally when the tv is shut off, the red led light is...
Hi replace the fuse in the wire connecting the mains plug. It's generally located within the 3 pin plug.
If you are lucky it maybe just a fuse blown out.
Thanks
Jul 06, 2017 | Samsung LN-S3238D 32 in. LCD HDTV
My vizio 32" tv won't turn on, only the red led light does. My warranty expired one week before the tv stopped working. can you please help me
I would try real hard to get it repair under warranty, they may bend the rule sinc it is only one week over warranty. Right now the 5vdc standby power supply is working. Typical repair for LCD TV is $200 and up plus parts. If they refuse, I would not buy another VIZIO.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jul 21, 2010 | Vizio VW32L 32 in. LCD HDTV
My samsung LCD TV LN26A450c1D won't turn on.
Greetings. I have a Samsung LN26A450, turn on and normal listening but no video, the screen is black. I opened it and found the F4 in the inverter card open, stamped value says "15" on the board says "0.75A/76V", I put that value and reopen, maybe the value is 1.5 A or 15A ?. I measured most components in the board and are ok.
May 27, 2009 | Samsung LTM1755 17 in. HD-Ready LCD...
Samsung TX R3079WH
the stand by is the indication of a bad power supply. take your tv to w/shop,
even if a tv is on stand by a tone is heard when switching on a tv.
Apr 29, 2009 | Samsung Televison & Video
Samsung LN26A450C LCD TV Logo
12,019 people viewed this question
Henry  Thomas
Henry Thomas
