Question about Apex Digital HT-150 System
Apex DT250 wont turn from standby (red light) to On (green light)
I have been using the Apex Digital DT250 for about a year without incident...although I left it on for most of that time. Lately I have taken to turning it off (with the remote) so that the green light turns red. This evening I discovered that it wont turn back on. Pressing the power button on the remote makes the red light on the dt250 blink once instead of turning green. Pressing the power button on the unit itself makes the red light flash quickly, at about 5 to 8 Hz.
I opened the unit up. But I don't see anything obvious. The connections all look good...
Has anyone discovered where a bad connection can be located or anything?
  • 19 Answers
The DT250 has one or more bad 470uf 25v capacitors. You should replace all four. Look at some of these youtube videos for how do do the replacement.
http://www.youtube.com/watch?v=on_2CP52cW4
http://www.youtube.com/watch?v=YCSNWi3UHf4&NR=1
Order 4 new 470uf 25v capacitors from digikey.com P/N P10274-ND
Use first class mail as your shipping method. Will be under 10 dollars total.
Posted on Oct 08, 2010
I had the same problem and changing the 4 470uf capacitors didn't fix it. I changed C6 which is a 47uf 16v which ended up being the solution.
Posted on Sep 20, 2012
How do i program a vibe unversial remote for apex digital converter box
Use the code search feature to find something that can handle some or all functions of your Apex STB. If a search through all codes contained in the Vibe remote fails, you may have to try a different universal remote. All universal remotes do not contain all possible codes.
Jan 13, 2016 | Televison & Video
PF2020 RESET CHILD LOCK
Turn your television and Apex DT250 receiver on.
Push the "Menu" button on the Apex DT250 remote control.
Press the remote's "Up" and "Down" buttons to scroll through the menu options. Stop when "Parental Controls" is highlighted. Press the "Right" button to select this option.
Enter your four-digit password. If you have not set your password, use the default code of "0000."
Use the "Up" and "Down" arrows to change or set the parental control movie ratings. You can select from "None," "G," "PG," "PG-13," "R," "NC-17" and "X." Once your setting is highlighted, press the "Right" button to go to the next screen.
Use the "Up" and "Down" arrows to change or set the parental control TV ratings. You can select from "None," "TV-Y," "TV-Y7," "TV-G," "TV-PG," "TV-14" and "TV-MA." Once your desired setting is highlighted, press the "OK" button to save your settings. Once the settings are saved, you will be taken back to the main menu. Press the "Exit" key to exit the main menu.
Oct 31, 2012 | Apex Digital PF2020 20" TV
Apex dt250, capacitor blown. I would like to know
Aug 11, 2010 | Televison & Video
Apex DT250 converter stuck in standby mode
I just had the same problem and replaced the popped capacitor and it works. I had to use a 470uf 35 because radio shack didnt have any 25's. It only cost $1.59 so i bought 3 just in case it happens again
Oct 04, 2009 | Apex Digital Computers & Internet
I have a apex DT250 and all of a sudden my tv screen is blank,apex does turn off and on,menu screen doesn't even come on..
Sep 10, 2009 | Apex Digital (AL-A300ATX) 300-Watt Power...
Need Universal code for RCA remote with Apex DT250 Digital Conver
Use cbl/sat button. Your remote might use more or less than 4 digits. Use 749 or 00749. It'll probably work. It worked for me.
Jul 30, 2009 | Televison & Video
Need a Philips universal remote code for Apex digital tv convertr
try going to this Philips site and using their universal remote control finder tool ...
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?tmplt=ePlatform%20-%20Philips&scy=US&slg=AEN&sct=REMOTE_CONTROLS_SU1&cat=REMOTE_CONTROLS_CA1&session=20100815184715_64.252.199.203&grp=SOUND_AND_VISION_GR&ctn=SRP4004/27&mid=Link_RCCodeFinder&hlt=Link_RCCodeFinder
Feb 20, 2009 | Televison & Video
Apex Digital HT-150 System Logo
3,111 people viewed this question
Top Apex Digital Audio Players & Recorders Experts
Robert Rankin
Steve
Are you an Apex Digital Audio Player and Recorder Expert? Answer questions, earn points and help others
