System wont boot
Was stuck on bios screen stops at ''initializing usb connections''. Pulled off varios connections, reconnected, replaced battery then a new screen,the Compaq screen with options of esc., f1 and f10 but keyboard not responding.
  • 44 Answers
Try a PS/2 keyboard (the old types of keyboard) or enter the bios by pressing Del key at start up
Posted on Sep 27, 2009
  • 360 Answers
Disconnect all devices except keyboard and mouse and master cd or DVD. unplug then hit power button. Plug back in. Hit power and hopefully you get to BIOS. If you do make sure you save the BIOS before you leave to start OS. Keep me informed and I'll keep checking your listing to see if its working or not.
Posted on Sep 24, 2009
Won't read keyboard
usb or ps2 keyboard ? might need to be enabled in BIOS
If you want to use a USB keyboard to access Windows command prompt options, make changes in the BIOS (Basic Input/Output System), or to operate legacy operating systems, you must enable support for the device inside the BIOS.
Shut down the computer and disconnect the USB keyboard. Connect a PS/2 keyboard to the PS/2 connector port on the rear of the computer. Turn on the computer and press the "Delete" key several times as soon as you see the initial boot or company logo screen. Wait for the main BIOS setup screen to appear. Press the right or left arrow keys to move the cursor to the "Advanced" or "Advanced Settings" menu option. Press the "Enter" key. Move the cursor to the "Integrated Peripherals" or "Peripheral Configuration" menu option. Press the "Enter" key. Press the down-arrow key to navigate to the "USB Controllers" option. Press the "+" or "-" key to change the menu option to "Enabled." Move the cursor to the "USB Legacy Support" or "USB Legacy Function" field. Press the "+" key repeatedly until the value option changes to "Enabled." Press the "F10" key to save changes to the BIOS settings and exit the setup utility. Wait until the computer begins to restart and then press the power button and hold it for approximately four or five seconds. The computer shuts down completely. Unplug the PS/2 keyboard from the computer and set it aside. Reconnect the USB keyboard restart the computer. As soon as you see the initial boot screen, tap the "Delete" key several times and wait for the BIOS setup screen to appear. If you are able to access the BIOS setup screen with the USB keyboard, USB support is active in the BIOS.
Feb 15, 2013 | Dell OptiPlex GX110 PC Desktop
Motherboard DP35DP Installation Problem
You should try a regular ps/2 mouse and keyboard.  You probably don't have the USB drivers installed for the new board.  After you get booted into windows you'll be able to install those.
Oct 12, 2007 | Intel Motherboard
Tip
Troubleshooting Error Messages on a Black Screen that may Occur During Startup...
<b><u>For Hp Laptop</u></b><br /><br />There are many reasons that a computer does not startup or boot into the Windows operating system.<br /><br /><b><u>Resolving Start Up and No Boot Problems Checklist</u></b><br /><b></b> <br /><b>Perform a Hard Reset</b><br />1. Disconnect all peripheral devices and remove all USB devices and media cards.<br />2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds.<br />3. Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.<br />If computer does not start normally, identify the specific problem symptom listed below and take the recommended actions.<br /><br /><b>Symptom: LED lights do not glow, display is black, computer does not start<br /></b>If LEDs do not glow when power button is pressed, there is no power available to the notebook. Check AC adapter wiring and power connection to the notebook. Connect a different AC power adapter and remove battery. Connect a different battery and disconnect AC power adapter. If there is no battery or AC power at the notebook, contact HP for technical assistance.<br /><br /><b>Symptom: LEDs glow, but computer fails to startup or boot, and displays a black screen</b><br />Usually occurs if a component is installed incorrectly, or there is a device conflict or failure. Connect an external monitor to check display Remove all CD/DVDs, SD cards, USB devices, peripherals and do hard reset If memory or hard drive components were replaced, reinstall original components Remove memory modules and replace one-at-a-time If possible, boot to BIOS mode (f10) and run Memory Test and Hard Drive Test If all other methods fail, use recovery disk to recover the computer to original condition.<br /><br /><b>Symptom: Computer displays a blue screen or continually re-starts</b><br />Trying to restart the PC after an error message can usually bypass the error and the PC can run in Safe mode to install an update or patch. <br />Boot to BIOS Diagnostics (f10) and run memory and hard drive diagnostic tests Boot to Windows Advanced boot options (f8) and:<br />o Select Disable automatic restart on system failure to view error message<br />o Run Repair Your Computer<br />o Run Last Known Good Configuration (Advanced)<br />o Select Boot into Safe Mode and then Run a Microsoft system restore<br />o Select Boot into Safe Mode and then Uninstall recently installed programs<br />o Select Boot into Safe Mode and then run Windows Update<br /><br /><b>Symptom: Computer displays the Windows logo screen and stops responding</b><br />Boot to Windows Advanced boot options (f8) and select Disable auto-restart to view error message<br />Boot to BIOS mode (f10) and Restore the BIOS defaults (f9) Boot to BIOS mode (f10) and run Hard Drive Test Boot to Windows Advanced boot options (f8) and select Last Known Good Configuration (Advanced) Boot to Windows Advanced boot options (f8) and select Boot into Safe Mode and then Uninstall recently installed programs<br /><br /><b>Troubleshooting general black screen errors on an EFI-based computer</b><br />The Extensible Firmware Interface (EFI) is available on select HP Notebook PCs manufactured in late 2008 and beyond.<br />To access the Startup Menu and the troubleshooting options on an EFI-based computer, press the power button and immediatly press the ESC key. If computer does not display a EFI Startup Menu, it may a non-EFI computer.<br />The EFI environment allows you to select from the following options:<br />Press f1 for System Information .<br />Press f2 to perform System Diagnostics .<br />Press f1 for System Information System Information.<br />Press f2 to perform the Start-up Test .<br />Press f3 to perform the Run-in Test .<br />Press f4 to perform the Hard Disk Test .<br />Press f11 to view the Error Log .<br />Press f9 for Boot Device Options .<br />Press f10 for Bios Setup .<br />Press f11 to perform a System Recovery .<br /><br /><b>Troubleshooting general black screen errors on non-EFI based computers<br /></b>The Extensible Firmware Interface (EFI) was not available on computer manufactured in 2008 or earlier.<br />When you try to start your computer, it may appear to stop responding with an empty, black screen before reaching a blue screen or the Windows logo. If there is no specific error message provided, there are several things you can do to troubleshoot a black screen. <br />Remove a non-system disk from the computer <br />To remove all non-system disks and reboot the computer, follow the steps below:<br />Disconnect any eSata, USB, or 1394 (Firewire) devices that are attached to the computer.<br />Remove any CD / DVD discs or memory cards from the drives if present.<br />Press and hold the Power button for 30 seconds to turn off the computer. Then, press and release the Power button to turn on the computer. <br /><br /><u> NOTE: During startup, a computer checks several devices for an operating system in a pre-determined order. You can change the order that the computer uses in the system BIOS. </u><br /><b>After removing any non-system disk:<br /></b>If the computer starts up normally to the Windows desktop, no further action is needed.<br />If the computer still stops at the black screen continue by restoring the BIOS default settings.<br /><br />for re-installation bios process, waiting for next tips. <br /><span>Thank you</span> <span>for taking</span> <span>the time</span> <span>to</span> <span>read. H</span>opefully these tips beneficial to you to solve your hp laptop.<br /><br />Regards<br />Multilinkent
on Mar 08, 2011 | Computers & Internet
Cruser keeps blinking.
Black screen with blinking curser?
Your hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Dec 04, 2012 | Acer Aspire One Netbook 8.9" Notebook
When system boots an error occurs"system bios shadowed" "Mouse initialized error" just before the OS is loaded into RAM
Firstly I would enter the BIOS and set it to default. That should remove the BIOS Shadow. When you finally get it to boot, run CHKDSK/F to remove any hard disc virtual errors.
Hope that helps.
Mar 28, 2011 | Fujitsu LifeBookS6120 Notebook
Dont't boot anymore since my power supply died
When the power supply failed, it took the motherboard out at the same time. Time to replace it.
Oct 17, 2009 | ASUS P5GD1 Motherboard
My computer wont boot past Ai lifestyle screen(initial screen)
Boot from windows CD and after all drivers are loaded it will ask you what you want to do
"Install, repair etc" choose Install and then press the R key for repair and follow instructions from there
Feb 02, 2009 | ASUS Premium Vista M2N32-SLI (M2N32-SLI...
Wont boot fully
Try resetting the system BIOS.
There are three ways to do this, depending on the mainboard style.
Check for a jumper near the mainboard battery.
If there is one, and it is a three pin style, move the jumper from the side it is on to the other side, then turn the power on (generally it will spin up, but nothing will happen), and then back off. Replace the jumper as it was originally and boot the system.
If there is a two pin jumper, remove the jumper, turn the computer on (again, it will probably not do anything), then turn the computer off and replace the jumper and reboot.
If there is no jumper, remove the battery, turn the system on, then off, then replace the battery and reboot.
Feb 14, 2008 | IBM eServer xSeries 346
USB functionality turned off in BIOS
Disconnect any usb devices first.
does the error go away?
Jan 26, 2008 | Shuttle ak32vn Motherboard
Still Doesn't Work
You needed to configure bios (F2) when you first installed the processor,
now the Bios hangs before anything can happen,  You need to remove the Bios Battery (looks like a coin on the mobo) for about 30 secs (with the power disconnected)  then re-insert the battery and power on.
you should get the same power on message as you did the 1st time (maybe with a missings settings error too but this is expected)
Enuro12 is right about legacy USB in that your keyboard should work in BIOS (setup)
Computers & Internet Logo
154 people viewed this question
David Payne
David Payne
