My series 80 washing machine filled with water and then quit running. Power is ok. timer will not run on any cycle
  • 5,911 Answers
Check your lid switch. If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle or drain, I would recommend you check your lid switch first. Due to the amount of wear it is the most common cause of these symptoms and least expensive to repair. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
If the switch is not activated by a lid strike, it will activated by a hinge actuator located next to either the left or right lid hinge. You will need to remove the operator console in order to access this type of switch.
NOTE: On this type of lid switch the lid hinge has a small rod that is used as an acutator to toggle the switch. In many cases, you can adjust the rod by bending it if the switch is not making contact.
If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If parts are needed, a replacement can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. All these sites offer competitive pricing, so shop all of them for the best price.
This is a very simple repair, that usually costs about $25 to $35 to repair yourself. If you have questions, please let me know. I hope this helps you.
Posted on Sep 24, 2009
My maytag quite series 100 _ fills with water starts running cycle but stops after about 20 sec _ it does this 3 times then shuts completely off
Sounds like the timer could be a issue . or motor running to hot clean all under and behind make sure no dust ..UNPLUG UNIT FIRST ,....
Sep 28, 2015 | Maytag Washing Machines
I have kenmore 80 series heavy duty/ super capacity plus washer that after it fills with water,hot or cold and it starts the wash cycle, I noticed that the agitator only moves once in awhile and stops
hum either a bad timer sticking the point contacts close. have u tried this in all cycles? and possibly a motor with bad windings not enough power to run agitation? try running in mild or gentle and see what happens? I was tempted to say the cam dogs in agitator but they dont work then stop then work, when they go out they go out.
Feb 17, 2015 | Kenmore Washing Machines
Kenmore 80 series washing machine - cannot get
Hi and welcome to FixYa. I am Kelly. This sounds like either the hose or the water inlet valve screen is clogged. Possibly the pinhole inthe diaphram itself of the water valve. Here is what you can do.
1. Get a bucket
2. Turn off BOTH water valves at the wall.
3. Remove the HOT water connection at the water valve. Then check the inlet screen for debris. You can remove the screen from the water valve by using a knife blade on the very outside edge of the screen tugging outward. Hold the screen up to the light check it for debris. If it is dirty wash it under a light flow of water in the sink. DO NOT reinstall just screen just yet.
4. Use a measuring cup or something similar to catch water at the water valve HOT connection. Select a WARM wash cycle and start the wash cycle. Let the water flow into what ever it is you use to catch the water exiting the HOT water connection.
Tap on the cold water hose connection to try and free the debris inside the water valve as the water is flowing. Do this a few times until you have let water back flow through the water valve for about 20 seconds.
Machine timer off.
5. Reinstall the inlet screen in the water valve and reconnect the hose. Place the HOT water hose in the bucket and start the WARM fill cycle again. This will flush the hose.
Machine timer off.
6. Reconnect the hose at the wall connection and turn on the water at the wall.
7. Select HOT wash and test water flow. It should by now be (fingers crossed) flowing.
You can repeat the above for the cold water side if you need to.
Thanks for using FixYa,
Kelly
Apr 09, 2010 | Kenmore 24032\24036 Top Load Washer
Washing machine Series 80 Kenmore wont drain water after it's RINSE cylce including the motor. It's like the TIMER stopped after the RINSE CYCLE. I think it's the timer.
does it drain after the wash cycle? if it does, then I don't think it's the timer. It uses the same contact there as for the rinse cycle. Do you hear the motor running as if it's trying to drain? If the motor is running, perhaps the pump itself is no good? Just a couple things to check. Hope it helps.
Joe
Sep 05, 2009 | Kenmore Washing Machines
Washer filled with water but never began cycle
It sounds like the controller/timer unit has failed and needs to be replaced. I hope that this help you resolve the issue. Please rate this response. Thanks!
Aug 24, 2009 | Washing Machines
Kenmore 80 Series draining problem
Check the following before replacing the timer.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 01, 2009 | Kenmore Washing Machines
Kenmore 22956 top loader quit running after agite cycle
If the timer cycles your lid switch is ok.
most likely: motor Switch (on Motor), condenser next to motor, motor itself, or wiring going from the time to the switch,
It is probably cost efficient to replace the unit rather than trowing parts at it .
AB
Apr 06, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
