Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Green converge lines are gone!
I recently had the ics replaced to fix the pin cushin effect and now when I got to re do the convergance I have no green lines for the first stage of converging..... green writing appears and green arrows but no green line to match up with the cabinet.
Any ideas???
  • version74 Jan 01, 2008
    green is there there are green lettering but the green convergence lines to center the picture to cabinet are gone
    yep green is there
  • Panasonic Master
  • 5,138 Answers
When you are in factory convergence on your hand unit press buttons 1-9 usally 1,2,3 theses should show r,g,b patterns, try them and see if your green is there,
Posted on Dec 22, 2007
Changed ICs Chips but still got bad convergence
After the IC replacement, convergence adjustments should be done. If you wish to get some details; visit the site linked here. Pull up older posts. Details of this adjustments are given.
May 01, 2017 | Philips 60PP9202 60" Rear Projection...
I have a Mitsubishi WS65611 I understand that the green lines are fixed and the red and blue lines are somewhat adjustable my green lines are no longer fixed in the top right and bottom left of the screen ...
YES, you either have a fuse that went out or the convergence IC went out... Sometimes it just comes unsoldered and causes the same effect. You need to locate this "IC" and tap on it with something non metallic. Like a ruler or a stick. While the tv is running and crosshatch is up on screen. If the lines get close as you tap on the IC or bang on the tv. then fuse is good and the tv might just need to be resoldered on that CONVERGENCE IC. Let me know how this works for you and if you have any questions give me a call @ 502-773-7969 and i can help u out further.
Mar 15, 2011 | Mitsubishi WS-65611 65" Rear Projection...
There is a blue shadow to the picture. The color chips were recently replaced and it has been doing this since the replacement. I have tried to adjust the convergence but on the screen with the cross hairs...
STK ICs that were replaced maybe the reason convergence is not lining up or you may have some open low ohm resistors that need to be replaced ,near convergence ICs. STK392-570.
Mats Electronics has STKs for 14.95 each
Jun 23, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Convergence issue; red 3D effect. In grid convergence mode blue will converge w/green fixed lines and red horizontal will but the verticle red will not adjust far enough left to converge. has ajustment...
Convergence is dead.Must know how to solders?Must replaced ICS and all of it resistors.Tries Tv repair, for a convergence kit.The shop will cost u $300 for parts and labors.
Jan 24, 2010 | Hitachi 43FDX01B TV
51MP392H/17 Blue convergence wont move not IC chip
You could have some opened resistors low ohms that are bad go back and ck them around convergence ics.
Nov 20, 2008 | Akai PT4298HD Rear Projection Television
Convergence way off!
Yup, you lost convergence. The only fix is to repair/replace the convergence IC. Some techs will just replace the whole video board.
Nov 13, 2008 | Mitsubishi WS-55511 55" Rear Projection...
JVC I'Art AV-56wp74
A repair facility will charge 400 to 600.00 for the repair. Or you can repair it yourself if you can solder. As both convergence ICs need to be replaced. They are STK392-110 you can get replacement ICs at the following link with free instalation instructions with pictures so you can do the repair yourself. Heres the link.
Jun 15, 2008 | JVC AV-56WP74 56" Rear Projection...
The red and green do not converge on screen. tried auto convergence, does not fix the problem.
There is a problem with the convergence ICs. Either there are bad connections at the pins or the ICs themselves are defective. If you can solder, resolder the pins first. If that does not resolve the problem, replace the ICs. These ICs are large black ICs attached to a heatsink. The should be marked STKxxx.
May 14, 2008 | Televison & Video
Green tube not converging properly
Replace both convergence IC's.....STK392-110 X 2........T.
Nov 15, 2007 | JVC AV-48WP74 48" Rear Projection...
PT 47 convergence IC's? box? both?
Always suspect the IC's first, digital convergence prblems are actually pretty rare IC's go everyday. I'd check partsore .com Generics usually work fine, they are probably STK392-110's but check to make sure.
Apr 16, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
117 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
