Question about Hyundai Computers & Internet
Turn singles wont work flashers do radio and intear lights just quit checked all fuses
    President:
  • 2,678 Answers
That's one hell of a PC monitor you've got!
Posted on Sep 24, 2009
Turn single lights don't turn on
try the hazard flashers if they work then the fuse is good,check the lights with the hazard flashers working.if they are all working then its should be the signal flasher that is bad.its located at the fuse panel and is round in shape.make sure you replace the signal flasher and not the hazard one.with the hazards on you can tell which one is the signal flasher as it will not make any noise they look the same and people tend to replace the wrong one.
Apr 25, 2011 | 2001 Pontiac Grand Am SE
Radio does not have any sound comming out of it and turn singles not making any noise when flashing but works out side the car
A LIGHT DUTY FLASHER CAN BE VERY HARD TO HEAR
IF WHEN RADIO WAS WORKING (MAKING SOUND) YOU COULD
HEAR IT WAS PROBABLY COIL BEING AMPLIFIED TRUE SPEAKERS
IF YOU PREFER TO HEAR THE FLASHER REPLACE WITH HEAVY DUTY
FLASHER
FOR THE RADIO LOOK FOR BURNT RADIO FUSE DISCONECTED WIRES AT RADIO
INPUT OR OUTPUT ANTENNA WIRE UNPLUGED ETC ETC
Apr 13, 2011 | Chevrolet HHR Cars & Trucks
My CD player and radio have quit working. The
try going under the hood in the main fuse and control box.
Jun 14, 2010 | 2004 Chevrolet Malibu
Turn signals wont work fuses are good?
the hazard switch above the radio is your problem. if you put on your signals and they don't flash turn hazards on then off and they will flash. (changing this *** will fix your problem
Aug 30, 2009 | 1999 Pontiac Grand Am GT
MY TURN SIGNAL QUIT WORKING IS THERE A FLASHER
My service manual states that the '02 T+C has a combination turn signal/hazard flasher/daytime running lights module which is located on the junction block, adjacent to and left of the steering column. To access it, you must remove the steering column lower cover and knee pad panel. There is also a fuse for turn signal/hazard flasher. If none of them work, check the fuse 1st.
Jul 18, 2009 | 2003 Chrysler Town & Country
Turning Lights Not Working
If you put a 2 element bulb in a single bulb elemet socket you would or could destroy the flasher unit. Especially if it is a electronic flasher try replaceing the flasher but get mechanicl flasher they last longer.
Jul 09, 2009 | 1998 Toyota Sienna
Hazards and blinkers not working
There are separate fuses for the turn signals and blinkers, but you should check both of them just to see if they're good.
You may have a burnt out turn signal bulb as well. I know that this sounds like an obvious answer, but a single bulb can sometimes disable the entire system because of the way that some flashers operate.
You could also have a defective turn signal/hazard light flasher. This is located under the dash board on the driver's side between the steering column and the door. You have to remove the sound insulation/kick panel (the cover on the bottom of the dash board) to reach the flasher (it is easy to remove - I don't think you even need tools).
May 16, 2009 | 1997 Pontiac Grand Am
Turn signal quit
your right flasher switch is damage that's why it cant locked when you toggled it. try to clean it and check if the lock is still there.
Apr 18, 2009 | 1992 Chevrolet Lumina
Turn signals wont work but flashers do
Hi.
On your 98 Dakota.
Is equipaded with a single Flasher.
If you replace all ready.
Check the FUSE # 10, 15 amp..
On the Fuse box. left side of Dash.
and the FUSE D 25, amp. On engine compartment Fuse box.
Check the proper funtion of the HAZARD switch.
Bacause if the Hazard switch is bad the turn signal don't will work. Match the OLD flasher with the New one.
If after of this still not work.
Remove the steering wheel cover, locate the Turn signal switch connector and with a TEST Light check power with the Key ON
12v. to the RED wire and PINK wire..
If you found 12v. check the connection with the switch.
If the connection is good. you will need to replace the turn signal switch.
But if you don't found 12v. You need to look a an open circuit.
And fix it..
I hope this help on your problem..
Thank you for use fixya...
Aug 31, 2008 | 1998 Dodge Dakota
Computers & Internet Logo
41 people viewed this question
Top Hyundai Computers & Internet Experts
rhodesworks
 Zackery G
Zackery G
Level 1 Expert
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
