Question about Logitech Computers & Internet
Keyboard wont connect
I bumped the reciever and all of a sudden the mouse and keyboard wouldn't work. i pushed the button and after several tries the mouse works but i haven't been able to get the keyboard to work. i have tried to reset the computer. the sleep button seems to work but aside from that nothing, i have changed the batteries
  • 748 Answers
Hello
I've had the same problem with the Keytronic stuff. Most of the time new batteries solve the issue. Once, though, batteries didn't help. I discovered that if I wiggled the batteries it would work. I tried an old trick. Using a straw, put a drop of Coke on the connections. Scrub the area with an old toothbrush. If there's residue use rubbing alcohol to remove it.
Good Luck
Posted on Sep 24, 2009
My Logitech mouse suddenly stopped working. I replaced the battery and it still doesn't work. The red light on the mouse is not blinking anymore.
take the reciever part that is in the computer and push the button in the middle, then push the button on the bottom of the mouse (make sure the batteries in it are new), that should work
Jan 30, 2011 | Logitech Cordless Mouse
The key board has lost its connection, please help. we hve tryed new batterys. the mouse still works.
mcdevito75 here, Sounds like you"ve lost the connection between your keyboard and reciever, that little angled piece with a button you press and lights up. First double check connection on your computer for this reciever, Then double check intsatlation of batteries in keyboard. NOW, press button on reciever, now press button under mouse and wait 20 seconds now press button on reciever then press button under keyboard. This should do it.
Jul 27, 2010 | Logitech Cordless Desktop MX 3000...
I have a logitech Ex100 mouse/keyboard set & both have just suddenly stopped working. It tells you how to re-start the system by pressing 'connect' on the reciever & then the mosue &/or...
Do a Hard Reset method to clear the keyboard and mouse settings and reconnect it back to your computer:
• Remove the batteries from the keyboard
• Press the Connect button on the receiver for 10 seconds.
• Press the Connect button on the mouse.
(You might need a pencil tip or other small tip to press the connect button.)
• Insert the batteries back into the keyboard.
• Press the Connect button on the receiver.
• Press the Connect button on the keyboard.
Mar 02, 2010 | Logitech EX100 967499-0403 Keyboard
Keyboard went dead.
Man, I pushed the channel button and held it down. Turns out that doubles as the re-link button. So, basicly press the link button on the reciever, then press and HOLD the CH button on the back under one of those little footy things.
Oct 23, 2009 | Micro Innovations Wireless...
Wireless keyboard stopped working; mouse still does though
on this key boards problem is that they key pad circuit board has no mechanical connection or wire connection it merely lays across the circuit board loosing contact that's why if you squeeze the bach it starts working again
May 03, 2009 | Gear Head WIRELESS keyboard/Mouse
Receiver not recognized by computer
The green LED on this reciever is also a button. Press the LED on the reciever with a small blunt object (pencil will work) and then press the "connect" button on the bottom of the mouse. The green LED should come on, and restore the connection between the reciever and the mouse.
Apr 14, 2009 | Microsoft Wireless Notebook Optical Mouse...
Keyboard connectivity
Normal 0 Assuming that you have good batteries installed, turn the Keyboard over and locate the small reset/connect button on the back of the keyboard and press it. Then try to see if it is working. If not try pressing the button on the receiver and then on the keyboard. Try typing, should work okay.
Also to Rest/Connect the mouse, turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps. Bud
Nov 30, 2008 | Computers & Internet
Problem with the receiver on my wireless keyboard & mouse KB985W
If you still have the software that came with your keyboard and mouse then i suggest you reload it, it appears that some of your keys have functions to them and they are misbehaving.
If you do not have the software then remove the reciever from the computer and then replace it again. press the connect button on the reciever then the connect button on the keyboard, wait for it to register the keyboard then press the connect button on the reciever then the connect button on the mouse and wait for it to register.
Hopefully this will help.
Nov 16, 2008 | Micro Innovations PD7250LSR Wireless RF...
Keyboard suddenly died
try the connect button under keyboard and on reciever.press the two within seconds! good luck
Jun 13, 2008 | Logitech LX 710 Keyboard/Mouse
Can not get mouse to move and buttons will not work on keyboard. batteries are all good
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Dec 12, 2007 | Microsoft Optical Desktop 1000 (BV3000003)
Computers & Internet Logo
71 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
