Have a Ricoh Aficio 4106 and am having some trouble. I am getting ghost images (Lighter copies of the same image on repeat copies.) I am also getting a band down the center of the page. If I am printing in color, this band usually is in full color, while the outer edges are only pink. Help???
    President:
  • 1,462 Answers
You get ghost image, if the moisture is present in the drum, Protect your machine from moisture.
It may also due to bad drum retaining charge which may be a bad erase lamp....So try checking the drum. if the drum catridge crossed life (50000 copies) replace the same.
Leave me comment if you need furthur assistance
RNJ VINOD KUMAR
Posted on Sep 24, 2009
Hi, please help me solve double image on ricoh aficio mp c2551 color machine.
Without a picture I can not be 100% sure, but in most cases it is related to offset from the fuser.
The hot roller is dirty, and will transfer a second "copy" of the image. The distance between each image is equal to the circumference of the hot roller.
The hot roller will then have to be replaced.
ghost image aka offset-2rhlv5r3sdqqpeuzs0ozcjtp-5-0.gif This is an example of how it may look with ghost image/offset.
Jul 11, 2017 | Ricoh Office Equipment & Supplies
When copying i have a shadow in background
Check copy life of consumables like Developer and Drum if ghost image might be Cleaning Blade found Imagaing Unit or Upper Fuser at Fusing Unit. If replace the whole imaging unit can solve your problem but individual parts try to clean first imaging include charge roller before you replace drum, cleaning blade and developer. mostly we replace developer only.
Mar 06, 2015 | Ricoh Aficio 1013 All-In-One Laser Printer
When i copy using my ricoh aficio 3350 the machine cut the image in half, please help
Have you checked that you are 'telling' the copier to use the correct size of paper? You need to tell it that you are using eg an A5 image sheet and an A4 output sheet. The normal default is A4 for both.
Jan 07, 2014 | Ricoh Aficio MP3350
Ricoh aficio SP c231n prints ghosts images
sounds like fuser is bad with wrinkling also or two different problems drum assy blade fail and fuser assy failed
Jan 02, 2013 | Ricoh Corp Aficio SP C231N Laser Printer
Ghost image ricoh 3245c
No can do, if you are referring Norton Ghost. Ghost it only for OS on computers. Printers have chips with instructions.
Here are the drivers in case you need them.
http://support.ricoh.com/bb/html/dr_ut_e/ra/model/c35_45/c35_45en.htm
Oct 25, 2012 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
Hello sir i have problem in ricoh aficio 1022 image repeat problem. u told me to change hotroller pressure roller baring also i change its same plz tell me where is the problem before fusing copy is ok...
Hi sir; No matter who told you to replace, the hot roller is the most possibility, the next item also last item you need to check is drum unit (drum cleaning blade,[replace it ], image transfer roller [clean up by alcohal] and drum [ depend condition ]).
May 09, 2009 | Ricoh Aficio 1035 Copier
Print quality
Ghosting can :
1-prints on the fuser roller, check if yes try cleaning it off, wait until it cools off
2-blanking lamps dirty or not working,(deletes image off the drum, before it gets ready to accept a new one)
BL mirror-(new image)
drum
3-Bad drum (although I doubt it this far in the process.)
Sep 05, 2008 | Ricoh Aficio 1013F Copier
Ghosting
it is a drum moisture problem.protect your machine from moisture.keep your paper carefully.if the drum catridge crossed life (50000 copies) replace the same.
Dec 30, 2006 | Ricoh Aficio 1013 All-In-One Laser Printer
35 people viewed this question
k24674
jasbo
jasbo
