Question about Malber P21 Front Load Washer
The handle broke for my p21 to open for laundry. i need to replace it.
  • 135 Answers
Order the part from Sears.com and replace it.
Posted on Sep 24, 2009
Back door won,t open on my 02 avalanche
door handle broke depends on what door handle it is.if door cant be open on out side out side door handle broke.if cant open door on inside inside door handle broke.door handle clip that connects to latch rod broken.when you try open door handle not engage to latch rod.door not going open.have to replace door handle with new clip holds latch rod in place.
Jan 09, 2013 | 2002 Chevrolet Avalanche
Broken front door handler,I need door or broken part-opener
its called a screw driver and force what your looking for.then you have to replace wat ever broke.
Jan 11, 2011 | Malber P21 Front Load Washer
Driver side exterior door handle broke. just one arm broke off the handle, so its still half on but i can't open my door from the out side. can i use the back door handle to replace the front one? also...
This iis very coomon, the part of the handle that broke is the part that releases the latch, you will need to replace the handle, the inside door panel needs to be removed to replace the handle, some of these are revited on and you will need to drill out revits from the outside and disconnect the linkage from the inside, hope this is helpful.
Dec 25, 2010 | 1996 Pontiac Bonneville SE CA Value
Need a new door opening handle?? the handle broke
You should be able to order one from Splendide. In the meantime, try using a screw driver to manually push the door release button.
Michael Lee
Thor Appliance Company
www.thorappliances.com
Sep 22, 2010 | Splendide 2000S Front Load Washer / Dryer
Open a suburban door when both handles are broke
ok easy to fix. remove door panel. when u have the replacement parts. start with the outside handle, remove the bolts, undo the bar, remove the handle. same with the inside handles
Mar 14, 2010 | 1999 Chevrolet Suburban
The outside door handle doesn't work but the inside one does what do I need to replace on an 96 f 250?
You should open the door first...take the interior trim panel off, access the "innards" of your door. It could be as simple as a clip that needs to be reattached or replaced or it could be the handle itself. Open up your door and move the handle and watch the attaching points to make sure it's all attached and in the correct number of pieces...
If you need help removing the door panel we can help you with that as well. (usually the screws are around the inside latch and behind the door courtesy lights.... let us know how it goes!
K
Jul 30, 2009 | 1996 Ford F250 Crew Cab
Malber P21 works 3 times slower than normal; I am afraid it will just stop.
I have a Malber P21 the door was open and not turned on and it filled with water till it overflowed onto floor....any ideas?
Dec 02, 2008 | Malber P21 Front Load Washer
Door handle
Malber...hmmm..sounds like a european make, right? only way to find that is perhaps accessories at website?
Mar 11, 2008 | Malber P21 Front Load Washer
Door handle
I have done this myself, breaking same part and fixing. For parts call 718-767-7396 in NY. I hope they will ship to you if you are not in NY. Good luck!
Jan 16, 2008 | Malber P21 Front Load Washer
Malber P21 Front Load Washer Logo
244 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Dan Webster
Dan Webster
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
