Question about Plantronics Audio™ 350 Headset
My input is recording my output
My mic is recording the sound coming through my headset and amplifying it. I've spend the better part of an hour trying to figure this out, and I'm sure it's just some setting somewhere. Any help would be greatly appreciated.
3 Suggested Answers
  • 247 Answers
SOURCE: microphone fuzz
Try turning the microphone volume down in your sound settings - fuzziness is usually caused by trying to amplify the signal to a higher level than it can carry.
For your own piece of mind, you might also want to check your headset on someone else's machine - that will pretty quickly distinguish between a headset and a computer problem.
Posted on Jan 13, 2009
SOURCE: Issue with Music Going Through Headset...
put in 0000
Posted on Dec 05, 2009
HDI Headsets
  • 537 Answers
SOURCE: instructions for set up of... plantronics s10 head
The S10 amplifier/headset system sets up like the Plantronics S12 system of which the user guide is included in the link below. As you will notice, it is designed to work with a telephone. It will not work as a stand-alone unit. To connect it to a dsl box, magic jack or any other line you will need a phone.
Plantronics S12 User's Guide
Good luck from Headsets Direct!
Posted on Dec 19, 2011
0 characters
1 Points
Logitech h250 mic not working
I've checked the mic settings, and adjusted them fully up. When I test them as hardware, they work, when I play a game, they don't work. Very frustrating.
Jun 06, 2012 | Logitech 250 Headset
I have voice, but no sound
Plug the USB connector into an available USB port.
• Check your computer's volume level.
• Check if your computer's volume is muted.
• Check your operating system's audio input and output settings.
• Check the headset's volume and mute settings.
• Restart computer.
May 11, 2012 | Dynex DX-840 Headset
Trying to hook my bluetooth headset to my playstation three what do i need to do
Bluetooth Headset Setup
A Bluetooth headset has to be registered, or "paired", with your PS3 before it can be used.
Make sure your Bluetooth headset is fully charged before you begin.
Check your headset instructions for entering "pairing mode". Activate your headsets' "pairing mode" so it can be recognized by the PS3.
On the Cross Media Bar (or XMB) of the PS3 go to the "Settings" tab, then down into "Accessory Settings", then down into "Manage Bluetooth Devices".
With your headset in pairing mode, follow the onscreen instructions and let the PS3 scan for your headset. When your headset is found, follow the prompts and enter a pass key (if necessary- the default is usually 0000 for all brands). The pairing should now be complete.
If you're using a USB (wired) headset, just plug it into one of the ports on the front of the PS3 (the system should auto-detect the USB headset).
Mic Test and Volume Setting
After pairing a Bluetooth headset, or after plugging in a USB (wired) headset, return to the XMB. Go to "Accessory Settings" and choose "Audio Device Settings". You can test your headset here.
Your headset should appear as the audio input/output device. If not, just use the D-pad to highlight the Input line, then scroll until you see yours. Any microphone you have used with your PS3 will be listed, but only the current one will be available to select.
Set the "Microphone Level" to 3. You can change the level any time if needed.
Speak into the headset, and the level bar at the top of the screen should move at the sound of your voice.
You can also view a list of Bluetooth accessories you have registered in the "Manage Bluetooth Devices" tab under "Settings".
If your mic doesn't appear there then try pairing it again.
There are more ways to configure the audio input and output that can be useful:
Set the input to (your mic) and leave the output on (default)- one person can chat with the other players, and the replys will play over your TV speakers rather than into your mic. Great when sharing one console because everyone can hear the team talk.
Set the input and output to (default)- you will hear the game sound and voice chat through your TV speakers but won't be able to talk back. Great if you don't have a headset, or if you want the room to hear the team chat.
Set the output to (default) to use stereo headphones with your TV or receiver. Then set the input to (your mic) and you can chat while wearing stereo headphones. Keeping the mic close to your face could be a problem since both ears are already taken! You could try a USB desktop mic and see if that works.
In Game XMB:
All of the functions in Audio Device Settings are available when using the XMB via the PS button during a game. You can set the input/output, mic level, and device. You can test your mic, and pair a new BT headset while in game.
For more help you can try these links:
Video Walkthrough (thanks jonny k)-
Playstation 3 Users Guide-
Feb 06, 2010 | Samsung WEP460 Bluetooth Headset
Mic not working properly : I have a iNTEX Headphone with a mic, the mic is not working at all. I've tried recording my voice(which did not work out),In control Panel the default Voice recording device is...
u need to check u r sound setting .plz click on sound icon in taskbar then click on sound property and recording there u can check u r mic if mic not working so srry dude u need to buy a new mic kkkkkkk
Oct 28, 2009 | Logitech Premium Headset
No voice chat in Yahoomessenger
open controller panel to the left click on classic view--if already on classic view the open the "sound" icon click the record tab look for the logitech mic -right click and set as default-reboot the pc and log into yahoo again and try the sound. if no logitech mic is detected under the record tab then headset may not loaded correctly check the device manager for any device that is not loaded.
right click and update it.
Jul 22, 2009 | Logitech 250 Headset
Mic not working when headphone plugged in
Try changing the Windows Default Audio devices
  1. Go to control Panel
  2. Sounds and audio devices
  3. The Audio tab
  4. Then change the Sound Recording Device to Logitech Headphone INPUT
Hopefully this will work
Apr 07, 2009 | Logitech Premium Headset
Microphone fuzz
Jan 13, 2009 | Plantronics Audio™ 350 Headset
Jabra bluetooth adapter A210
you have to connect the jabra audio jack to the audio source, to the speaker output of your receiver for example. If jabra detects the source it will work. If you cut the connection, jabra watch for a while if something happend and than stops the transmittion. Hope that helps
Oct 26, 2008 | LG Jabra A210 Bluetooth Adapter for...
You use headsets to have conversations over the internet .. or to have a personalised audio equipment,.
You should have used the mic to start with, as you heard over the speaker your voice,
There are two pins. One for MIc and other for the headphones.
Use mic only when recording. other times keep it muted in control panel-> sound and audio...
you can use headphone for hearing when you don want the audio stream to be on speakers., TO use so, you have to take of the output from the CPU to the headphone pin after removing the speaker pin or configuring the audio controls control panel-> sound effect manager to have sound always in both theh speakers and headphones.
This requires you to have an appropriate configuration so that all 3 pins are aptly placed fot output from the CPU.
Hope you got what you asked for!
Apr 12, 2008 | Labtec C-322 Headset
Plantronics Audio™ 350 Headset Logo
21 people viewed this question
Top Plantronics Headsets Experts
sonic boom...
sonic boom...
Nataly Roberts
Nataly Roberts
Ed Nelson
Ed Nelson
Are you a Plantronics Headset Expert? Answer questions, earn points and help others
