Question about Maxtor Hard Drive
I need to make my Maxtor a slave but i dont know
I have a Maxtor 6L080L4 and im trying to make it a Slave Drive but for some reason the Jumper that i have it on wont work or that Cap you use
what should i do or what am i doing wrong... i just dont know where to put it i dontunderstand the Diagram
  • 360 Answers
Slave for that drive is the jumper removed.
Here is a picture of jumper settings for your hard drive.
http://support.seagate.com/kbimg/M_c.gif
Hope this helps.
Posted on Sep 24, 2009
    Brigadier General:
  • 4,090 Answers
Http://eshop.macsales.com/Tech/manuals/idehdsettings/Maxtor72.pdf
This document should help clear up the mystery.
Please rate the help++++Thyanks for using FIXYA
  • 1,183 Answers
Refer to the following schematic and put the jumper. Also make sure that your harddrive is detected and in the system BIOS.
http://eshop.macsales.com/Tech/manuals/idehdsettings/Maxtor72.pdf
Thanks for using fixya
proton
What are the jumper settings for the maxtor 9064004 6.4 GB HDD?
Most computers 'nowadays' dont really need jumper settings, usually the best approach is to have all your drives on the same ribbon cable, on "cable select" if thats not an option, 'slave slave(or just slave depending on the drive)' will work just fine.
Mar 01, 2011 | Maxtor Hard Drive
I have an old maxtor 2 drive that i'm trying to slave
Hi!
Just follow the jumper settings in the picture diagram below:
I hope it helps..
Thank you for reaching Fixya.
Apr 11, 2010 | Maxtor Hard Drive
I want to add another hard drive and need to know how to set the jumpers on my maxtor 90645d3 please help.ty
if you want to boot from this drive, please set the jumper to the master position.
if this drive is for additional storage, please set the jumper to slave. and make sure 1st hard drive is set to master.
if this is the only drive in the system, please set the jumper to single or remove the jumper.
there will be a chart telling you which pins are for which setting in the jumper area, which is between the data plug and the power plug on the back of your HDD.
main thing that will cause drives to not work is 2 jumpers on the same cable and they both are set to the same thng.. i.e. master/master or slave/slave. also, if one is set to single drive it will likely bypass the slave drive.
Jan 25, 2010 | Maxtor Hard Drive
I need jumper settings for maxtor n256 model 96147h6 i wish to run it as a slave pls help. thx
For use as slave there is no jumper connected. (Master on/slave off0
Oct 04, 2009 | Maxtor Hard Drive
Installing old maxtor HD on newr pc, have to change it to a slave
J50 is the one furthest from the power connector. To make it a slave remove ALL of the jumpers.
Jul 26, 2009 | Maxtor Hard Drive
Setting Maxtor HD as Slave.
Howdy,
First "easy" one I've had in hours....
Just pull the J50 pin out of the jumper block and PRESTO it'll be a slave the OFF position literally reffers to having the J50 pin off of the hard drive. Just a note though, I highly recommend using a peice of scotch tape to affix the pin to a nearby surface cause there a real pain to find if and when you need em again.
Chris,
Armor-IT
Apr 23, 2009 | Maxtor DiamondMax 60 (33073U4) 30.7 GB...
How to detect the hardrive?
setup the first drive as slave ( sometimes No Jumper ) then the furthest away drive as Master.
If this fails, and you have 2 IDE Slots on the motherboard. ( Primary/Secondary ) Put 1 drive on primary as Slave. And DVD Rom As Master ( same Cable ) Then put second drive On Secondary IDE Slot. ( Set As Master Or Slave )
If none of these solutions Work For you, check to see if Both Channels are activated in the Bios.
Thankyou For Using Fixya.
Mike @ compurepair.
Jan 28, 2009 | Maxtor Hard Drive
Slave harddrive jumper settings
usualy its just one jumper if no jumper on maxtors becomes slave. jumper on 50 is master. if u use cable select.. on same ide another device must also be cable select.
if one is master other is slave on same ide.
Jul 15, 2008 | Maxtor Hard Drive
Slave pin settings
hi frined
remove your hard disk jumper & u r hard will be slave
Apr 12, 2008 | Maxtor 20.4GB 7200rpm ATA-100 HDD p/n...
Maxtor Hard Drive Logo
322 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
