I changed my hard to a bigger capacity I have window 95 system disk and will later on upgrade to window 2000 but my computer does not boot what is wrong. please advised
    President:
  • 2,666 Answers
Windows 95 doesn't support large hard drives, that was only introduced with win98. When you upgrade to win 2000 there shouldn't be a problem.
It is also interesting to note that you don't mention the size of the HDD's
Posted on Sep 24, 2009
    President:
  • 1,187 Answers
Could be a few things ... let's start here:
Assuming that the new hard drive, boot into the BIOS (probably press the [delete] key after you power up the computer.
Go to the "Boot sequence" section and make the CDROM Drive the first boot device. Save that and re-boot.
The Windows CD will boot and examine your system. Then it will prompt you to install.
Please post comments if you need more assistance... We will step you through the entire process...
  • 103 Answers
Well you need to have your operating system installed... if you are operating the new drive with the old drive then check your bios setting for the hard drive order...
NTLDR compressed on a Compaq Presario SR105CL cant enter bios to set to boot
Step 1:
Which operating system ?
Computer is booting from a non-bootable source. Computer hard disk drive is not properly setup in BIOS. Corrupt NTLDR and NTDETECT.COM file. Misconfiguration with the boot.ini file. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT.32 New hard disk drive being added. Corrupt boot sector / master boot record. Seriously corrupted version of Windows 2000 or Windows XP. Loose or Faulty IDE/EIDE hard disk drive cable. Failing to enable USB keyboard support in the BIOS. Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD ROM First verify that no Floppy Diskette or CD is in the computer, unless you are attempting to boot from a diskette. b> Note: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any card reader or flash reader make sure that no memory stick is inside the computer. Additionally disconnect all USB drives, cameras, ipods, iphones, etc. from the computer. If you are attempting to BOOT from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files or is corrupt. If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive. Second, when the computer is booting you should receive the below prompt. Press any key to boot from the CD
Mar 10, 2013 | Compaq Presario sr1055cl PC Desktop
I am getting a disk 1/0 error and am not confident at all with computers. How can I fix this so my son can use the computer? My PC is about 6 years old and I only ever used it 9-10 times
A..Access the BIOS setup by pressing the key designated for your BIOS at Startup? It can be Del/F1/F2 or whatever and will be shown on Boot Screen before Windows is loaded.
B. Do you have a Win98 Boot Diskette proven to work well in a PC?
If so:
1.With the Win98 Boot Diskette in the Floppy Drive, Restart the PC.
2. Press the BIOS key [Eg:Del] enter BIOS setup
Check for correct YYYY/MM/DD and Time for your Time Zone and proceed to take a good look at the entries of your IDE devices and Floppy Drive with special attention to your Hard Drive(s) in IDE section. If they are all properly identified and normal, you can EXIT the BIOS. [ It does not mattere "Save changes" or "don't save changes" as you have not made any changes.]
3. Wait for Boot Disk to be accessed and Windows Startup Menu to appear with the Options:
1.Start Computer with CD-ROM support.
2.Start Computer without CD-ROM support
3. Help File
4. Select the option,1.Start Computer with CD-ROM support. and ENTER
5. Watch the screen for CD-ROM driver installed successfully" and "Diagnostic Tools " installed and CD-ROM drive letter designation and finally appearance of A:\Prompt
6. At, A:\ Prompt type FDISK and press ENTER.
7. Accespt Y at the bottom of "Large Disk Support" message.
8. At FDISK menu select #4. Display...."
9. Check if the HDD is shown as C: A FAT32 and size.
I am suspecting a problem somewhere here; so if you don't have an Active C: drive press ESC >ESC and remove boot Disk CTRL +ALT+ DELETE to reboot and post back
If you have an Active C: drive, press ESC >ESC to A:\Prompt and type in C: and then at C:\> prompt, type DIR and [ENTER] look for Windows Directories. Here is another Problem area. If you cannot Find any Dir or get an Error, make sure your typing and spacing are OK [ No space after Drive letter for the Command] and if so, ALT+CTRL+DEL or Power Off.
If the problem is same do next .
Alternative Start Mode
1. Re-boot PC, as it starts tap F8 several times until the windows boot window appears.
2. Scroll to "Start with last known good configuration.)
3. Press "Enter"
Or
2. Scroll to "Safe Mode" (With networking, if you want to access the internet)
3. Press "Enter"
System Restore
1. Go "Start"
2. "All programs"
3. "Accessories"
4. "System tools"
5. "System Restore"
6. ensure "Restore to an earlier time" is checked and click "Next"
7. Select an earlier date when your PC worked well. (Must be a highlighted date)
8. Click "Next"
9. Allow system restore and reboot
NTLDR is Missing.
Related errors:
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Cause:
Corrupt NTLDR and/or NTDETECT.COM file.
Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
Solutions:
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Verify that your computer hard disk drive is properly setup in the BIOS / CMOS setup. Improper settings can cause this error. Additional information on how to enter the BIOS / CMOS setup can be found in document CH000192.
Windows 2000 users
Windows XP users
Windows 2000 users
If your computer is using Microsoft Windows 2000 and you are encountering the NTLDR error. Create the below boot.ini file on the floppy diskette drive.
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINNT
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" /fastdetect
Copy the NTLDR and NTDETECT.COM files from another computer using the same operating system. Both of these files are located in the root directory of the primary hard disk drive. For example, C:\NTLDR and C:\NTDETECT.COM should be the locations of these files on many computers.
Please keep in mind that these files are hidden system files, if you need additional help with viewing hidden files in Windows please see document CH000516.
Once these files have been copied to a floppy diskette reboot the computer and copy the NTLDR and NTDETECT.COM files to the root directory of the primary hard disk drive. Below is an example of what commonly should be performed from the A:\> drive.
copy ntldr c:
copy ntdetect.com c:
After the above two files have been copied, remove the floppy diskette and reboot the computer.
Windows XP users
Insert the Windows XP bootable CD into the computer.
When prompted to press any key to boot from the CD, press any key.
Once in the Windows XP setup menu press the "R" key to repair Windows.
Log into your Windows installation by pressing the "1" key and pressing enter.
You will then be prompted for your administrator password, enter that password.
Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
copy e:\i386\ntldr c:\
copy e:\i386\ntdetect.com c:\
Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Edit the boot.ini on the root directory of the hard disk drive and verify that it is pointing to the correct location of your Windows operating system and that the partitions are properly defined. Additional information about the boot.ini can be found on document CH000492.
If you are getting this error message while you are attempting to upgrade to Windows 2000 or Windows XP from Windows 95, Windows 98, or Windows ME running FAT32 please try the below recommendations.
Boot the computer with a Windows 95, Windows 98 or Windows ME bootable diskette.
At the A:\> prompt type:
sys c:
After pressing enter you should receive the "System Transferred" message. Once this has been completed remove the floppy diskette and reboot the computer.
If you are attempting to add a new hard disk drive to the computer make sure that drive is a blank drive. Adding a new hard disk drive to a computer that already has Windows installed on it may cause the NTLDR error to occur.
If you are unsure if the new drive is blank or not try booting from a bootable diskette and format the new hard disk drive.
It's possible your computer's hard disk drive may have a corrupt boot sector and/or master boot record. These can be repaired through the Microsoft Windows Recovery console by running the fixboot and fixmbr commands.
Additional information and help in getting into the Microsoft Windows Recovery console can be found on document CH000627.
If you have tried each of the above recommendations that apply to your situation and you continue to experience this issue it is possible you may have a seriously corrupted version of Microsoft Windows. Therefore we would recommend you reinstall Microsoft Windows 2000 and Windows XP.
If you are encountering this issue during your setup you may wish to completely erase your computer hard disk drive and all of its existing data and then install Microsoft Windows 2000 / Windows XP. Additional information about erasing the computer and starting over can be found on document CH000186.
This issue has been known to be caused by a loose or fault IDE/EIDE cable. If the above recommendation does not resolve your issue and your computer hard disk drive is using an IDE or EIDE interface. Verify the computer hard disk drive cable is firmly connected by disconnected and reconnecting the cable.
If the issue continues it is also a possibility that the computer has a faulty cable, try replacing the hard disk drive cable with another cable and/or a new cable.
Hope this helps ,
Jan 26, 2011 | Gigabyte GA-8SRX Motherboard
My computer lost ( ntlpd is missing) plus said press ctrl alt del it's not coming up.
Sounds like you've got some corrupted files. If you have your Windows disc, try a reinstall/repair or try to drop back to a previous restore point.
If those don't work, you might try to reformat/re-install your software. (backup your data if you can beforehand as reformatting will wipe all data from the drive).
This can even be a hardware problem, like the HD controller bad, which caused the file problem in the first place. Or a virus can cause such issues, which would make reformatting/reinstalling a good idea as well.
Make sure you have a defragment task running every month, if not every week. You can schedule to run at night or during the day, whenever you're not at the computer. If you turn it off when you're not using it, just leave it on that one day (or night) that the defragment needs to run... or start it manually before you go to sleep and unless it's a large drive, it should be done when you get up.
Good Luck!
8^)
Jan 02, 2011 | E-Machines eMachines Desktop PC
Ntldr is missing
These are the common causes for this error Computer is booting from a non-bootable source. Computer hard disk drive is not properly setup in BIOS. Corrupt NTLDR and/or NTDETECT.COM file. Misconfiguration with the boot.ini file. Attempting to upgrade from a Windows 95, 98, or ME computer that is usingFAT32. New hard disk drive being added. Corrupt boot sector / master boot record. Seriously corrupted version of Windows 2000 or Windows XP. Loose or Faulty IDE/EIDE hard disk drive cable. Failing to enable USB keyboard support in the BIOS.
Please checkout this link for fixing the same Ntldr is missing
Sep 19, 2010 | Computers & Internet
Component details
ZENITH NOTEBOOK, Z-NOTE 425Ln+, CPU 80486DX 25MHZ, 8MB RAM, 1.44MB FLOPPY DISK DRIVE, 200 MB HARD DISK DRIVE, 9 PIN SERIAL PORT, 25 PIN PRINTER PORT, PS/2 MOUSE PORT, VGA MONOCHROME VIDEO LCD, EXTERNAL VGA CONNECTOR, AC ADAPTER, WEIGHT 8 LBS,
You can install Windows 95, I'm not sure about Windows98
Aug 25, 2009 | Computers & Internet
HI my sons acer travel/mate 6292 has crashed and will not boot up, the screen is black but its stating the NTLDR is missing and asking to press ctrl,alt, and delete to restart, yet when I do this it goes...
Hi tracey,
Cause for the NTLDR missing:
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable. are
Solutions:
Windows XP users
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
  1. Boot the computer with a Windows 95, Windows 98 or Windows ME bootable diskette.
  2. At the A:\> prompt type:
    sys c: <press enter>
  3. After pressing enter you should receive the "System Transferred" message. Once this has been completed remove the floppy diskette and reboot the computer.
ENJOY! RATE THIS SOLUTION RNJ VINOD KUMAR
Jul 03, 2009 | Acer Aspire 5610-4648 Notebook
Dual op systems
in bios setup usually under security you can remove user passwords.
you get into safemode for 2000 and in control panel and remove it form users administrator account
If your not interested in to os systems then you can format
Mar 06, 2009 | Compaq Armada 3500 Notebook
Acer 3690
Could be various causes just follow the information below and you should solve it.
Good luck
NTLDR is Missing
NTLDR is missing
Cause:
Solutions:
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette is in the computer, unless you are attempting to boot from a diskette.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files and/or is corrupt.
Note: If you are not receiving the above message and your BIOS boot options are set properly it's also possible that your CD-ROM drive may not be booting from the CD-ROM properly. Verify the jumpers are set properly on the CD-ROM drive. Additional information about checking the CD-ROM drive connections can be found on document CH000213.
Additional information: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any type of card reader or flash reader make sure that no memory stick is inside the computer.
Windows 2000 users
Windows XP users
Windows XP users
Oct 31, 2008 | Acer Aspire 3690-2196 Notebook
Consustently get "DISK BOOT FAILURE _ INSERT SYSTEM DISK AND PRESS ENTER" message
use xp sp2 bbootable disk and simply run a repair installation it should heal your system
Oct 17, 2007 | Mach Speed (MSNV-939) Motherboard
Computers & Internet Logo
David Payne
David Payne
