Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
My frigidaire door shelves broke... how to get them fixed cheap? I slammed the door and the hinges that hold onto the door broke off. I tried super glue but that doesn't hold strongly
  • 135 Answers
Order them from the sears.com website.
Posted on Sep 24, 2009
How do I get my kelvinator stove's P 12 front door back
Without more information I can't be sure of your problem but I will make a guess that you removed the door without engaging the hinge locks. I am attaching a video that may help. All oven door hinges are not the same. Some require you to insert a screwdriver or pin in a hole to stop the hinge from retracting. My own oven door has retainers that snap onto the slot just above the hinge. When you remove the door these pieces are used to hold the hinge in the open position.
If the hinges are in the closed position you will have to figure out how to open them and hold them in the open position. Be Careful. The springs are very strong and can hurt you. I am including a link to a youtube video that may be the same as your oven door.
This free troubleshooting video shows step-by-step instructions on replacing the oven door hinge on Frigidaire, Electrolux, Gibson, Kelvinator, Tappan, and Kenmore gas ranges.
Door Hinge Replacement part 316456302 Frigidaire Gas Range Repair
Aug 15, 2014 | Kitchen Ranges
FRIGIDAIRE DOOR WILL NOT STAY SHUT
check shelving and stock in door not stopping door closing. Check hinges tight and complete (sometimes have a self limitting plastic stopper that breaks, allowing weight of door to pull itself open)
Apr 05, 2014 | Frigidaire FRU17G4JW Refrigerator
Door on Frigidaire front load washer loose
have you tried this:
https://www.hunker.com/12000515/how-to-fix-a-sag-in-a-frigidaire-affinity-washer-door
The screws maybe stripping(wearing out) or the hinge bent, should be able to visual look at both. I hope this helps. Tim
Apr 24, 2017 | Washing Machines
My frigidaire washing machine door hinge snapped
Hello - Contact the manufacturer to see if they have any updated or alternate door hinges that you can install yourself. The weight of some front loader doors, and how they are closed/slammed, can wear over time.
Nov 03, 2012 | Frigidaire ATF6000ES Front Load Washer
POWER BUTTON STUCK IN MOGEL # GFDN240ELWW
I took off the front panel by removing the philips head screw behind the control knob. The front control panel will lift straight up. Remove the 6 philips head screws which secure the control board to the inside panel. When you lift up this module you will see the power button. It is made from cheap plastic including the hinge. Only way to repair is to either super gluie the hinge or replace the entire control panel. I think this is an extremely poor design, especially coming from G.E.
Jul 24, 2011 | GE GFDN240ELWW Dryer
I need a door shelf for my Frigidaire side by side refrigerator (# FRS6R5ESBFPN # 241691311)
  • You did not list freezer door or refrigerator so I will link you to all of them and you can choose the one you need. These are all for Frigidaire FRS3R5EMB
  1. Upper freezer shelf - http://www.appliancepartspros.com/Appliance-Parts/frigidaire-bin---door-frzr---upper-item-number-ap2115843.aspx
  2. This one is a replacement for the lower 3 freezer shelves http://www.appliancepartspros.com/Appliance-Parts/frigidaire-freezer-door-shelf-item-number-ap2115974.aspx
  3. This one is a replacement for the 2 bottom shelves of you refrigerator http://www.appliancepartspros.com/Appliance-Parts/frigidaire-refrigerator-door-bin-item-number-ap2115741.aspx
  4. This part here is for the 2 upper shelves of your refrigerator http://www.appliancepartspros.com/Appliance-Parts/frigidaire-refrigerator-door-bin-item-number-ap2116036.aspx
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 21, 2011 | Frigidaire FRS3R5EMB Side by Side...
Do the door hinges ever wear out
I did my own search for the same problem and saw Dougs question and lack of a solution. I have the same sagging door problem and was looking for a fix.
First, when I removed the weight of the items from inside the door, the door closes properly. This means that the door is not very sturdy and cannot hold the weight of items placed on door shelving. There are NO adjustment mechanisms on the door hinges either. Bad on Amana. The GOOD NEWS is that I fixed the problem.
Take out all items from the door shelves. I removed the top hinge with the door closed to keep it from falling. I took the door off and placed it on the floor. The lower hinge has a plastic pivot over a steel pin - remove that for a moment. Place steel washers over the steel pin - about .080" or so thickness. Replace the plastic pivot. Replace the door. Add the normal weight of items back on the door shelves. The door closes perfectly. At least until the door sags again and I'll need to add another shim.
Jun 21, 2010 | Amana ABB2524DE Bottom Freezer...
Marvel, Model 61 RF ww-F made in 7-19-2000
Dear John,
Contact the factory directly at 800-223-3900 8:00am to 5:00 pm EST. I believe the bar pn is 42241938 (for the 2nd and third bar) and the top bar pn is 42241937. (I am going by memory so have them verify it). They also have a kit that has both side hinges and new springs for the freezer door. If you can't get through via phone contact Tim Malloy using tmalloy@northlandnka.com. He's a little overloaded but should get back to you within a day or two.
Nov 01, 2009 | Marvel 61RFxx 24-inch Refrigerator/Freezer
The door is bent a bit and now won't shut right unless slammed just right. I doesn't look bent but must be. I know I have trouble opening it after a wash where it seems stuck and I am sure the previous...
That model has 2 hinges on the door, and one or both of the hinges are probably bent, not the door. The good news is that they are pretty cheap to buy the hinges, and it only involves 8 screws, its an easy fix. After you do that, if you still have problems with the door lock, then it probably got damaged from the door closing when it was bent, and you would need to replace either the door lock or the door strike if the strike on the door is broke. I have replaced many of these hinges for this problem, and havnt come across the door lock getting damaged in the process, but have had to replace a few broken door strikes. hope this helps, good luck.
Oct 23, 2009 | Frigidaire FTF2140FS Front Load Washer /...
Nintendo ds broken hinge
need to replace the hinge (shell housing) about $25.00
Aug 22, 2008 | Nintendo DS Lite Console
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
174 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
