After 45 minutes it turns off. It will come back on again but off again evet 10 minutes. It will blink green three times and orange two times. I replaced the bulb, but no luck. Any help?
A Green light or White light maybe blinking while the TV is turning on. This is normal and will stop once the TV does come on. If the light continues to blink and the TV does not come on or if the TV comes on and then turns off and the process starts over again, and unplug the TV for about 3 minutes then plug it back in and try again.
the green is the reboot process and is normal. the red light is an error code indicator. count the blinks of the red light...it cant be 30 times (I think) it will blink a sequence, pause, then do it again for a total of three times. count carefully, it gives you three chances to catch the number it is blinking.
If you have never replaced the lamp before its likely to be close to the end of its usable life. best to replace it, the ballast in the tv can be damaged by your lamp and then you really will have to get out the wallet. Julio [email protected]
Sounds like you have a bad green picture tube that has failed. To check this out; remove front speaker grill, remove small panel, you will see three CRT's (pictue tubes) sticking down, remove the little board on the middle tube then restore power. If TV stays on more then likely the CRT is bad but not always the driver on board could also be bad, check voltages.
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did. Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
