Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Dryer sometimes works other times doesn't
A medium sized load of clothes takes at least dry in an hour, other times it will take up to two hours for the same size load to dry.... the clothes never get "hot" when in the "whites" dryer setting.
  • jeff615 Dec 23, 2007
    Our dryer does not seem to get hot enough to dry clothes in proper amount of time. Have had it for about two years, has worked fine in the past.
  • Anonymous Dec 27, 2007
    My dryer has taken a long time to dry clothes from the day I got it. My husband says its becuz its only 110, not 220. Some things take over 2 hours. A medium load may be done in the 90 minutes alotted on the timer. I am ready to get rid of it.
Check and make sure there is not lint build-up in the venting hose leading to outside. This will cause longer drying times and can be a fire hazard. Also, if you use the Aluminum venting hose instead of the white plastic it can cut up to 30 min. off your drying time. It is a lot safer then the white venting hose which can also be a fire hazard. Make sure all the lint is cleaned out from the inside of the dryer where the venting hose is connected. It could be a clog there. This sounds more like the problem since the clothes are actually drying but it could be a partially burnt out heating element. Good Luck.
Posted on Dec 26, 2007
My dryer does not shut off and doesn't get hot. It takes almost 5 hours to dry a load of clothing.
Sorry to say but it sounds like the heating element is on its way out... Happened to ours and repair was more than a new dryer so we brought a new one
Nov 14, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
Clothes not dry. Take about 3 hours to dry the medium load of regular clothes.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101'
Jul 18, 2011 | LG Dryers
Dryer not drying in one cycle. takes multiple cycles do dry one medium size load. the machine is less than a year old and we clean the filter after every load. checked the vent hose and its clear with no...
HI, Check the following to address this issue further.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat. These thermostats are located in the dryer vent duct and sometimes mounted on the blower assembly as well.
Nov 23, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Dryer does heat but takes 3 hours to dry a medium size load of clothes
Sounds like the moist air is not being properly vented. Your dryer has a fan that pulls in dry air and expells the moist air. This is vented thru your dryer hose and should be vented to the outside of your home. Sometimes the hose will get either a blockage or a partial blockage that will make it either not dry your clothes or take longer than it should. I have seen hoses that have a sag collect water much the way your trap will under a sink. You can either throughly clean the hose, and check for a blockage in the hose or the dryer itself, or you may, as a test, disconnect the hose temporarily and vent your dryer into an old pair of panty hose. When you turn the dryer on, the panty hose should inflate. Also make sure you keep your lint trap clean...EVERY LOAD.
Oct 02, 2009 | Amana DLE330RAW Electric Dryer
Not heating properly, many cycles to dry loads
Check the following to address this issue--
1. Venting
2. Thermostat
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 02, 2009 | Maytag SDG3606A Gas Dryer
Dryer taking too long to dry clothes
Hello :)
Very common problem. You need to call a
duct cleaning company and tell them to clean
your dryer vent. Rule-of-thumb: dryer vents
should be cleaned every couple of years to
prevent them from being clogged with lint and
causing lint fires. This is definitely your problem.
Good luck :)
p.s. one way to verify a clogged vent is
to go outside where the vent exits the house
and feel the air-flow. should have adequate air-flow.
Apr 03, 2009 | GE Profile DPSB620ECWW Electric Dryer
Dryer takes MUCH longer to dry clothes than it should
Is the hose crunched down at all in the back
(vent hose)
Feb 09, 2009 | Fisher and Paykel Dryers
Long drying time
Did you find what it was?
Mar 12, 2008 | Dryers
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
204 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
