Question about Gateway MX6447 Notebook
Lights on, no display, doesn't boot
I've diagnosed mine as a bad hard drive controller on the motherboard. Drive works in another laptop and another good drive won't register either.
  • 733 Answers
Had similar problem on sony vaio. when power depressed, i could hear the cd drive turn a bit, the hard drive light blink once, and that's it. power light would remain on, but nothing else. I took it apart and resoldered all the main chasis grounds on the motherboard and shorted/resetted the board battery(memory/clock) and put everything back together and started up fine. got lucky i guess.
Posted on Sep 24, 2009
Motherboard for hp pavilion xt963 is there away to tell if its bad
It's very possible that your hard drive is dead. If you get a prompt when booting it such as F1 then the motherboard is working (so far), therefore it means the BIOS is ok and also that your CPU is ok if not nothing will show on your screen. If pressing F1 gives you boot options then select CD. If it won't boot from your CD force it by actually going into BIOS setup and selecting CD as primary boot drive then press F10 to save. (if BIOS setup options don't show when booting try pressing F10 or F8 and any other function keys after F1.
Make sure you have the installation disk. If the PC still doesn't boot or detect it you should try another CD/DVD drive, yours might be bad or buy or borrow a DVD/USB external drive and select it as boot drive in BIOS. Often I've seen that when booting if either the hard drive is bad or your operating system is corrupted it will prompt F1 because it cannot detect either. If OS is corrupted you will be unable to get to safe mode especially if the hard drive is bad, the recovery partition is on that hard drive and safe mode is a Windows program not BIOS.
After you've tried connecting a different CD drive to install your OS you should be able to at least see the Windows installation or whatever operating system you use asking to begin installing. If the installation fails then we move on to the hard drive; take it out and put a new one then try again.
If none of these help then there might be a circuit shorted out on the motherboard which can cause some things to work but not others although this is rare. Lastly I don't know what you meant by USB in your question because unless you have a bootable USB drive the system isn't going to do anything with it anyway.
By the way someone here mentioned RAM memory. BIOS should still show even if your memory is gone but some systems are quirky so this needs to be tested as well. I could go further if you had posted your system's specifications such as how many sticks of RAM you're using. Try dusting off your the inside of your computer with compressed air. Dust acumulation tends to cause weird behavior on a computer.
May 14, 2012 | Intel Motherboard
G61-306NR power button doesn't work
Disk Drive works, Memory is good, so any Blinking Lights or Beeps when you hit the power button? Does anything ever post to the lcd screen when you press the power button?
It sounds like either you've got a memory issue or a video card issue. Just because the memory worked in your friend's computer does not mean it will work in yours. Your Slot where the memory goes might be bad.
When you plug in the power cord is there anylights whatsoever on the laptop, where the plug goes in or on the AC Adapter ofthe power cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Apr 11, 2012 | HEWLETT-PACKARD G61-306NR Notebook
I have a asus motherboard it restarts on starting windows screen I've tried to boot in safe mode that doesn't work
That means there is a problem in the booting environment of the system. This usually results from a virus attack that changes the booting environment. The best way to go around this problem is to slave the hard drive to another desktop computer, access it and make a data backup. By slaving the hard drive i mean, connecting it to a working computer but do not let that computer to boot from your hard drive because it can not. Boot form the working computer so that you can be able to see your hard drive in the 'my Computer" menu as drive E of D or F depending on how many partitions are available.
After making a backup, take it back to youe ASUS motherboard and perform a clean installation of an operating system. This should fix the restarting problem.
Mar 25, 2012 | ASUS Computers & Internet
I have two intel based hp dv6000 laptops. Both are having problems. I suspect the mainboard because everything else was replaced the last months. laptop 1: Not booting, no screen (nothing!!), no beeps,...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly:
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
could be a dirty graphics card you might have remove the graphics card and clean the socket
also check your computer ram and cmos battery to make sure they are securely seated and the battery has plenty of charge:
hope this helps you
Sep 18, 2011 | HP Pavilion dv6000 Motherboard
On start up my lg x120, (s/n: 003msfb0044355)" displays operating system not found" it wont go any further.What do i need to do?
This type of message indicates that the BIOS is unable to detect an operating system. What may cause this condition can be a loose hard drive, a bad data cable, bad hard drive, bad motherboard storage controller, malware, virus, or incorrect BIOS setting.
To troubleshoot, start by entering the BIOS and see if the BIOS detects your hard drive. If it is detected then make sure it is set as the 1st boot priority item. If it is not detected, then open up your laptop to inspect the wiring of the hard drive. Make sure it is firmly seated into the motherboard connector (Don't forget to have the laptop/pc powered off before opening the machine).
Next, remove the hard drive from the laptop and connect it to a motherboard from a desktop to see if it spins and loads the operating system. If it does work, then the hard drive is ok and the motherboard on the laptop is damaged.
You can also use a functional hard drive to install on the pc/laptop to rule out a bad motherboard.
If all of these don't work, you will need to reinstall your operating system because malware has damaged your operating system.
Aug 28, 2011 | Computers & Internet
Hi my ibm thinkpad r51 laptop starts up as normal,showing the windows xp logo.but after that the screen goes black but i can hear things on the desktop.pls i need ur help.thanx
Your laptop could have a back light problem.
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
May 07, 2011 | Lenovo ThinkPad R51
My Compaq Presario F732NR Laptop w/Vista won't Boot.
You have done an excellent job of diagnosing a MotherBoard fault. This is undoubtably the problem. Have you removed all/any cards attached too, like say the WiFi?
Feb 08, 2010 | Computers & Internet
HP Pavilion zv6100 laptop CMOS will not recognize the HD
You could have a faulty disk controller. Try inserting a different working hard disk into the HP and see if it can detect it in the BIOS. If not then the disk controller is faulty and this is a motherboard problem. A replacement motherboard may not be worth it, put your money towards a new laptop and put the hard disk into an USB hard drive adapter case and use it as an USB external hard drive.
Jul 15, 2009 | HP Computers & Internet
Toshiba m50-mx2 powers up okay but no display
when you have the memory in and you boot up does it look like the hard drive LED is flashing? If so then its booting up into windows and that would mean a bad Display. If nothing happens then try a different stick of good RAM and see if it boots up then, if still nothing then it sounds like a bad motherboard.
Feb 02, 2009 | Toshiba Satellite M45-S265 Notebook
PC Won't Power Up
I'd guess the problem is either the hard drive connector in the bay (trying putting in the original drive and seating it very solidly) or else the motherboard hard drive controller (rare problem). You can diagnose which of these it might be by putting the hard drive back in and then booting into the BIOS (F10 or delete at boot up) and then investigating whether the hard drive is being correctly identified by the BIOS. If it is, run any tests or AUTO options it has to see if the BIOS can contact the drive properly. Then, step through the BIOS settings and try turning on and off settings like SMART FOR HARD DRIVE and so forth and rebooting in cycles after every change. It is also possible that with the power problems you've described, the BIOS got reset and may need tweaking to get it working again. If you see evidence t might be a BIOS reset problem (for example, the system clock is crazy wrong), try to LOAD SAFE DEFAULTS AND EXIT option in the BIOS. If you test it all this way and find no problems, and you can access the drive normally on another machine, it is probably the motherboard IDE controlled. Will it boot from a CD/DVD? They are usually on the same IDE channel and so failure to boot from a CD tells you something is wrong in the hardware.
Good luck...
Nov 16, 2007 | HP Pavilion dv4000 Notebook
Gateway MX6447 Notebook Logo
158 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
