Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Freezer works fridge not cold enough
Fridge appears to be getting warmer?
where is the vent from Fridge to freezer for me to check
just hopped on so no savvy skills yet on this site.
  • 135 Answers
The vent is at the bottom of the fresh food side, about a foot from the bottom.
Posted on Sep 24, 2009
My landlord just gave me this fridge and it appears that one thermostate controls freezer and fridge. I am not sure what temperature to set it at as the freezer is getting cold but the fridge is not real...
if this is a self defrosting ref. it should do it by itself. one knob on the right will make your ref cooler by making your freezer warmer..it controls a vent that lets cold air from your freezer. try that ok.
Feb 13, 2011 | Refrigerators
The freezer appears to be working fine, however the fridge is not cold at all. For the last week it has been getting warmer and warmer.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 28, 2011 | GE Refrigerators
Fridge/freezer not getting cold
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 04, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
Fridge side is not cooling, freezer side is fine
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 08, 2009 | Refrigerators
Fridge won't get cold
Check to make sure that the fan in the freezer is running whenever the compressor turns on to cool the unit down. If the fan's not going, warmer moist air from the fridge will make the air duct frost up. The fan needs to be running to blow the cold air into the fridge section.
Apr 28, 2009 | Refrigerators
Fridge slowly gets warmer and stops working
You have one of 3 parts not working.
1.The defrost timer.
2.The defrost element.
3.The defrost themostat.
Jan 11, 2009 | GE Refrigerators
Refrigerator is not cooling
Hello hazraan
Welcome.
You said your Kenmore model 60852990 freezer is working but refrigerator is not cooling.
Lets try a couple of ideas.
Is your freezer filled up where the packages are covering the air vents in the rear of the freezer?
Refrigerators and freezers must share the cold air and circulate between them. If the freezer is packed full with not enough space at the air vents in side it, the fridge will get warmer!
Next,Turn off the fridge and freezer controls, and then go to the breaker box and turn off the breaker to the fridge for 5 minutes!!!!!
Then restart it and the fridge and freezer controls.
This should reset the system and solve the problem. let me know if either were the case.
If either was the reason,it now will take some 8 to 12 hours to gets back to temperature.
Waiting your response.
Huuum, Please remember to leave a rating.
Oct 13, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer not freezing enough and fridge not cold enough
Hello Scott, remove the food from the freezer side and remove the rear freezer panel. You will see a coil and it should be completely frosted over. If not then you have a sealed system issue. If it is froze solid in frost where you cannot even see the coil, then you have a defrost issue. You should have a little frost on all the coil, the defrost is what clears the frost so the evap fan motor can circulate the air thru out the unit. If frost is good, push the light door switch to start the fan. If it isn't running check for 120 volts. If it has voltage, but not running, replace the motor. Hope this helps.
Aug 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge freezer double door top fridge bottom freezer
Things to check
Check freezer...
for Frost build up and if Fan is blowing,
Check condenser...
To make sure clean, and the fan is blowing by compressor & IF it is running
Check Recirclating Vents in refrigerator... to make sure theres no blockage,
CONTROLS ...should be in the middle setting,
YOU CAN TRY turning FREEZER CONTROL
To A WARMER FREEZER SETTING
Allowing.. MORE AIR.. to refrigertor side
Oct 24, 2007 | KitchenAid Superba KSCS23IN Side by Side...
Indesit Fridge Freezer
Check freezer... for Frost build up and if Fan is blowing, Check condenser... To make sure clean, and the fan is blowing (by compressor), Check recirclating Vents in refrigerator... to make sure theres no blockage, CONTROLS ...should be in the middle setting, YOU CAN TRY turning FREEZER CONTROL To A WARMER FREEZER SETTING Allowing.. MORE AIR.. to refrigertor side
Sep 08, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
171 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
