Question about Maytag Atlantis MAV6451 Top Load Washer
Have to slam the lid
My washer machine has been doing something different. Sometimes it wont start while the lid is down. You have to lift it and shut or slam down. Now it wont start washing, and of course I have a load in there. I keep lifting, shutting, slamming. Any suggestions?
  • Anonymous Dec 21, 2007
The same thing happened here. It turned out to be the lid switch. It can be accessed by taking off the back plate (behind the controls) by unscrewing three screws and two screw bolts -simple.
I removed the lid switch and tested it with an ohm meter - instructions are on this site. You should have continuity across machine-motor, as well as across machine -line. (These are labeled on the switch).
If you don't have a meter and you still want to see if that's the problem, after you have removed the lid switch, short the machine and line connectors, (you'll see these labeled on the lid switch so you'll be able to figure out which wires go with what) as well as shorting the machine and motor connectors. Both of these need to be shorted. That bypasses the switch and will activate the motor and controls.
That's what I did to confirm that it was all a "lid switch " problem. I ordered a lid switch from this site for $24.95 for the repair, and will use the "shorting process" to do a couple of loads of wash as I wait three days to get the switch. Good luck.
Posted on Dec 29, 2007
Lid lock button is flashing and wont unlock
I u unplugged the machine and it stopped blinking, the lid unlocked but when I tried starting it again the same thing happened. I cleaned the contacts on the lock but that did not help.
Jan 08, 2013 | Maytag Bravos MTW6600T Top Load Washer
Washer not working
you may have broken the lid switch needs to be checked
Apr 22, 2010 | Maytag Atlantis MAV6451 Top Load Washer
I have a Kenmore 900 series washer. It fills with water but them doesn't run. I see no switch on the lid but if I lift and shut the lid sometimes it will start. This is getting worse.
There is a lid switch which is proabably going bad it is located at the rear of the lid lift the lid up all the way look where the lid touchs the tol at the back in the middle you will see a little tab sticking out which when you close the lib the lid presses down on this tab which makes the switch function. You have to take off the top of washing machine to replace switch. Unplug washer before doing this
Aug 07, 2009 | Kenmore 24052 Top Load Washer
Must repeatedly slam top loading door shut for machine to start
on the inside of the lid there is a lid switch hole that a plastic tab goes down through the switch could be bad or the screws holding the switch in could be lose or broken
Mar 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Have to slam lid down to get washer to start
Did not want to disect the entire machine to get at the lid switch. Couldn't figure out how to get the corner covers off so I figured we would continue to slam the lid until that no longer worked and then "call the guy". Thanks.
Jul 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer won't start after lid is shut, if i slam it, it works!
sounds like your lid switch is loose ..look at the tab that sticks out of the lid and watch where it close's. inspect the switch see if it is loose or broke
Nov 28, 2007 | Washing Machines
Maytag Atlantis MAV6451 Top Load Washer Logo
293 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
