Question about Pantech Matrix Cell Phone
I need the driver for usb sync to my computer... where do i get it from
3100 mobimb cable drives free download
Posted on Sep 24, 2009
Need to install driver for htc touch in my computer
click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
if you computer came with a motherboard disk the drivers could be on it
or you might have to download them
http://download.cnet.com/htc-usb-sync/3000-2014_4-56360.html
hope it helps
Apr 13, 2012 | HTC Computers & Internet
Cannot connected usb with PC
Check your usb cable or try to replace another one.,also check the usb slot of your phone,might corroded likewise and need to clean as well,see if the pins of this connector are well align,you can use magnifying lens to see it closer.clean it using a pin or a dry toothbrush,be sure to take off the battery first to avoid short circuit.also check the usb port of your computer,try to plug it on another slot.
You might need this software to be able to synchronize your phone to your computer
Download this file : ACTIVE SYNC
* After downloading, run and install the application,and then plug your phone using usb cable then wait until drivers are installed and then it will automatically sync the phone on your computer.
Hope this method helps, thank you for visiting FixYa.
Jul 07, 2011 | HP iPAQ rw6828 Smartphone
Htc P3400 my problem is a how can attached my pc with my phone
You need to use the USB Sync Cable that should have come with your package.
You also need to install Microsoft Active Sync on your PC ; use the Getting Started Disc that came with your phone.
Once you install Active Sync then you can connect your phone to your PC with the USB cable. When the PC detects your device it will start the ActiveSync Synchronization Setup Wizard.
More information on your phone can be found here.
Trust this is helpful.
Jan 08, 2011 | Intel Computers & Internet
How to connect to internet via htc s710 to computer
first you need microsoft active sync on your computer, this is for the drivers, then select wireless modem from program menu, option will be usb or bluetooth, select usb now connect phone to computer, it will show htc generic modem found , if driver is not installed it will be in c/program files/active sync.
now next create a dial up connection dialup no is *99# usually and connect.
reply for any feed back
Dec 22, 2010 | HTC S710 Smartphone
My igolf neo won't work with Windows 7 if i try
I fixed this problem by going to Start>Control Panel and uninstalling the Java 64-bit program. It is incompatible with the Neo sync application. The other Java program on there is compatible. It worked immediately without even restarting. (I tried the above Best Solution, but on the newer computers, I get a message saying the Vista driver is only for Vista, not for Windows 7).
Jan 30, 2010 | NEO iGolf neo MP3 Player
Cannot get PDA Smartphone to sync with computer
software you need to install software
let it install before connecting phone to comp
then after finish the install then connect the phone to usb cable
you might if this didnt work the first time have to uninstall all the software and try a fresh copy of the software in comp to sync everything with desktop manager
May 29, 2008 | Dopod 838 Smartphone
Mt6227 drivers
Would you please send me a link to download mt6227 usb drivers?
May 28, 2008 | Nokia N95 Cellular Phone
Can not connect using LG Mobile Sync
Hi all,
I went through the same trouble. After a small investigation I've found that the USB driver wasn't install. I just ran the setup and it worked imediatly C:\Program Files\LGE GSM PC Sync\USB Setup\LGUSBModemDriver_ML_WHQL_Ver_4.6.exe
Hope it could help!
Feb 03, 2008 | LG Shine KE970 Cellular Phone
Computer fails to recognize smt5600
you can use any USB cable, there is nothing specific about any particular brand... now the computer has to recognize the phone. You need the software/driver.
Sep 11, 2005 | Audiovox SMT5600
Pantech Matrix  Cell Phone Logo
97 people viewed this question
Top Pantech Cell Phones Experts
Abdul Mannan
Abdul Mannan
Jax Planet
Jax Planet
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
