Question about LG Flatron L1710S 17" LCD Monitor
My lg flatron l1710s flashes on and then the picture goes out and thats it but the power light stays green
  • 3 Answers
Sometimes an old driver for this monitor will mistakenly believe it can display a higher resolution - and so it goes out of range when things autorun. Best trick I've found is to clear your CMOS (reset your BIOS) and, oddly, plug in a different keyboard to a different port and hold delete when you boot. If you need to repeat, change keyboards again. (make sure you hold the delete key down before you even plug the computer back in and it should work fine.) Also, for those unfamiliar with resetting their BIOS, write down your settings first, or ask a friend.
G'luck! Took me some research but I eventually made mine behave. :)
Posted on Apr 24, 2012
  • 50 Answers
This is highly suggestive of a power supply failure to deliver the voltages required. A new power pcb should fix the problem but is a job for an experienced repairer.
Posted on Sep 24, 2009
My flatron L1710S flat screen will not come out of power saving mode. When I turn on the monitor the power button/light is green for a few seconds, the screen indicated "power saving mode", then...
I switch on my PC, ensuring that all cables, leads and power supplies are connected properly. The tower powers up no problems at all. I switch the screen on, the green led lights up, the screen is completely black. A blue box appears centrally on the screen with the text 'power saving mode'. The green led light turns amber and then the screen just goes black.
Please don't suggest going to control panel, as I can't get that far.
PLEASE PLEASE CAN ANYONE SUGGEST ANYTHING give me
Mar 08, 2011 | LG Flatron L1710S 17" LCD Monitor
My LG Flatron 1710S computer screen doesn't have any power. Sometimes the power light will start flashing but most of the time it stays blank.
This is a common issue, the power supplies in LCD monitors fail prematurely. (if your monitor has an internal power supply) , Double check all your power connections, but it sounds like the internal supply is toast, (its a simple capacitor replacement to fix, but cost to do this job seems to always outweigh a new monitor purchase) sorry to be the bearer of bad news.If you find my answer helpful albeit poor news, please use the thumbs up feedback.
Aug 26, 2010 | LG Flatron L1710S 17" LCD Monitor
Have an lg l1710s monitor turn on computer the
YES, You too, bigbill1223, will need to do some soldering of poor thermally fractured solder joints and/or replace some bad electrolytic filter capacitors on your l1710's "switch-mode-power-supply"/ "inverter supply inside the monitor. Visit youtube for "lcd monitor repair""lcd monitor disassembly" videos. You will be impressed with what you find there!!! also visit www.ccl-la.com/badcaps.htm amd www.lcdparts.net and www.badcaps.net for all the info you might need to effect a repair. If soldering ain't your thing, then you will pay 10x the cost of parts alone to farm out the work!! There, I got you started. Now all you need is to do some reading of my profile 12fixlouie aka louie12fix on fixya or another guy that's real good nickname= "buddymc" on fixya. Then do a new comment to your original post. Bye for now. 12fixlouie nrt of windy-city
Nov 12, 2009 | LG Flatron L1710S 17" LCD Monitor
Lg flatron blank screen
t certainly seems like the monitor is not getting a signal. Did this happen after you changed something, or just on normal boot up?
It could be the video card that has failed.
Also, check the pins on the connector; sometimes they can get pushed in.
If you can, try swapping out the video card or use the monitor on another computer.
Good luck,
May 09, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
Screen flashes only for a split-second (as a second display for an iMac)
The inverter is faulty.If your Monitor is powered by a mains'kettle' type lead,then it MAY be repairable,provided you can find someone to do it.If you have an external power supply,then the chances are you have a separate inverter,and it is doubtful whetther you can find the fault or a replacement circuit board....which is why we have become a throw away nation !!
LG Flatron L1710S Monitor stuck in Power Save Mode
Try wiggling the Cord on the backside of the monitor.. Not the Power Plug Cord, The Other Cord that attaches to the PC. Do this once the monitor turns off , grab ahold of the cord about 2 inches from the back of the monitor, then bend the cord to the right, keep bending from the right to the left a couple times to see if your screen comes back, if it does, than you have a Loose connection and this sometimes causes the Symptoms you are receiving.. Hope it helps.
Jun 02, 2008 | LG Flatron L1710S 17" LCD Monitor
LG Flatron problem
i get a black screen and an orange light in my lg lcd flatron whenever i turn it on.. i cnt use my pc because of this problem.. i hope u would answer my question...
u can email me at jmaonir@yahoo.com
tnx man :)
Apr 09, 2008 | LG Flatron L1710S 17" LCD Monitor
I have an LG flatron l1710s monitor . when you turn it on it flashes the message that there is no video signal then the screen goes black. and nothing is showing. the monitor stays on as far as the power...
You need to 1. hook up and 2. select a video source. It can be from your antenna, cable, tuner, VCR, DVR, DVD, etc.
If you have any of these connected properly, 2. select the correct input to get any video to work.
See your operator's manual for set up instructions or ask me for more information about the hook up.
Hope this helps. :)
Mar 31, 2008 | Televison & Video
LG Flatron L1710S 17" LCD Monitor Logo
321 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
