Question about KitchenAid KSRG25FKSS Side by Side Refrigerator
The compressor is very hot & will not start,it is getting power to the starting device. Checked pins to ground terminal with ohm meter, open to ground but not sure if windings shorted out. The starting device is rattling and has a faint electrical burnt smell. The unit is an 2003. What are the odds it's only the starting device & not the compressor? Thanks, Bob
  • 135 Answers
The odds are very good. If it rattles, it is bad. If it tries to start and kicks out after 10 seconds and then tries again after 2 minutes. It is the starting device. I would replace it.
Posted on Sep 24, 2009
Kenmore refridgerator will not power on
Fridge not starting? CLICKING? FIRST ALWAYSCHECK FORpower at the outlet,checkfor 120 volts. I
MAY HAVE A BAD START RELAY OR CAPACITOR ON THE COMPRESSOR , CAN BUY A INEXSPENSIVE 3 IN 1 HARDSTART KIT AND BY PASS THEM , NOT THAT HARD TO DO, COMES WITH INSTRUCTIONS> BY THE WAY DO U HEAR ANY CLICKING SOUNDS FROM COMPRESSOR? BUT U MAY ALSO WANT TO CHECK UR COLD CONTROL THERMOSTAT IF IT GOES BAD U MAY GET A NON START ALSO HAVE IT CHECKED FOR PROPER VOLTAGE AND OHMS RESISTANCE WHEN IN THE ON POSITION
A BAD DEFROST TIMER though seldom CAN SHUT DOWN COMPRESSOR HAVE IT CHECKED WITH MULTI METER.
to check the defrost timer, u can get by and test manually by placing a small ***** driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
AT TIMES YOU MAY HEAR THE COMPRESSOR CLICK OFF AND ON OVER AND OVER. Signs of a bad start relay or capacitor. Check with an OHMS meter for continuity (ohms) and voltage, capacitor can be checked for Microfares. ( if in series with the windings)
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, somes located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur start winding, 1 goes to ur run winding and the center goes to ur ground or COM
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms, u have a short in ur compressor. It should show infinity
God is so good: so this is why I give free advice so please thank him not me.
Mar 28, 2016 | Kenmore Refrigerators
Model HMG-19153. Has no power, just dead wont do anything. Power outlet works fine.
Fridge not starting? CLICKING? FIRST ALWAYSCHECK FORpower at the outlet,checkfor 120 volts. I think God os good that's why I give free advice?
A BAD DEFROST TIMER CAN SHUT DOWN COMPRESSOR HAVE IT CHECKED WITH MULTI METER.
to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
May 15, 2015 | Refrigerators
My lg refrigerator model lfc23760st has no power but the fuses look good is the main control board bad
dont be so quick to assume its ur power board?
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Apr 22, 2015 | LG Refrigerators
Unit will not power up. interior light will come on, if power button is pressed but display will not come on.
Apr 20, 2015 | Refrigerators
Had a power outage. freezer is not working. running but not freezing.
Apr 20, 2015 | Maytag Refrigerators
Stopped the fridge freezer to clean and now not working although power is getting to machine
Mar 26, 2015 | Refrigerators
Suddenly stopped working. There is noise and power.
Mar 21, 2015 | Refrigerators
Bosch KAN58A40AU03 fridge freezer has stopped working. Checked power and fuses inside fridge. Got power on both sides. Nothing's working in fridge freezer, lights, or ice maker. Any suggestions what i
Feb 07, 2015 | Bosch Refrigerators
Fridge not working panel flashes then goes off 6th sense fridge 2 pin plug from europe please help????or does anyone know a phone number of whirlpool cheers
Oct 30, 2014 | Refrigerators
My kenmore run and stop after temp is ok but will not come back to run until i open the door o touch the control face them will do the same thing again ,they toll me to replace the defrost timer is this my...
Jul 03, 2014 | Kenmore Refrigerators
KitchenAid KSRG25FKSS Side by Side Refrigerator Logo
131 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
