Question about SanDisk Sansa e270 MP3 Player
How do i reset my sansa e270 - SanDisk Sansa e270 MP3 Player
    President:
  • 803 Answers
Press and hold the "Power/Menu" button for 15 seconds to reset it back to its original factory default settings.
Posted on Sep 24, 2009
Hi i have a problem with my ipod the main problem is when i want to turn it
on it shows me name of model - it means is loading but after it should go
on to the main menu but it loading is starting again and when i touch turn
on/off button nothing happen, and loading is starting again and again but
system don`t want to go on to main menu, i took off battery but didn`t
helped, so the problem is that system will not go on to the main menu, what
should i do??? maybe i have to change the battery for new one??? hope to
have an answer ,the model of ipod is:SANSA E270 from SANDISC, 6GB AND THE
COLOUR IS BLACK thank you
PAULINA
Posted on Nov 03, 2009
  • 758 Answers
SOURCE: sansa e270
To obtain the driver for your sandisk device go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer...it should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Please rate accordingly
Thank you
Computerrep
Posted on Mar 27, 2008
  • 758 Answers
SOURCE: driver for sansa e270 for win xp os
Install Windows Media Player 11. The Sansa drivers, and MTP system, are part of WiMP10 / 11. Windows XP "out of the box" has WiMP9, which may be your problem.
The Sansa can function as a flash drive in MSC mode, but your files transferred in MTP will not be available on the PC side.
The Sansa does not require specific drivers from SanDisk, as it's integrated into WiMP.
Go under menu, setting and change the device to MTP or playforsure..
Let me know if that works
Thanky you
Computerrep
Posted on Nov 11, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: sansa e270 it lost driver
Go to Sandisk's website and get the software you need. If the reinstall fails:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Mar 27, 2009
  • 5 Answers
SOURCE: sansa e270 ....computer no longer reads content of sansa
Well, the reason you can't see some of the songs is because they are in a hidden folder. To access the hidden folders, you have to go to computer, then folder options, and check unhide hidden files and folders. If you go back to sansa, you should see a light colored folder that is titled music.
Posted on Jul 16, 2009
  • 378 Answers
SOURCE: Bad track on my sansa e270
may the format is not mp3, it must be i pod compatibel
Posted on Aug 05, 2009
Sansa e270 freeze if switch on,it indicates,REFRESHING DATABASE"
Having gone over a month with no response, I assume the reset solved the problem.
Jul 08, 2010 | SanDisk Sansa e250 MP3 Player
How do you you download videos to Sansa e270?
photos and video must go through conversion with bundled software; the expansion slot can be used with music only.make sure you convert your video first.
Sep 27, 2009 | SanDisk Sansa e270 MP3 Player
Aug 05, 2009 | SanDisk Sansa e270 MP3 Player
Sansa e270 ....computer no longer reads content of sansa
Dec 08, 2008 | SanDisk Sansa e270 MP3 Player
Sandisk sansa e270 get stuck
�� Reset All
NOTE: THIS IS AN ADVANCED OPERATION AND RESTORES ALL SETTINGS
TO THE FACTORY DEFAULTS. NORMAL USERS ARE NOT RECOMMENDED
TO PERFORM THIS OPERATION!
If your device freezes up press the Menu button and hold for 15 seconds.
This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
will be gone.
Nov 11, 2008 | SanDisk Sansa e270 MP3 Player
Can't install my sansa e270 driver on vista ultimate
Go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer...it should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Thank you
Computerrep
May 03, 2008 | SanDisk Sansa e270 MP3 Player
Sansa E270
Reset, and then try resetting the clock again.
Jan 16, 2008 | SanDisk Sansa e270 MP3 Player
Refurb Sansa e270
Hold the power button for up to 30 seconds to "reset" the device.
Best of Luck.
Oct 31, 2007 | SanDisk Sansa e270 MP3 Player
SanDisk Sansa e270 MP3 Player Logo
674 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
