Question about RCA Televison & Video
My 52 inch RCA projection TV has the picture wide on top and small at the bottom..what can cause this and how can it be fixed??
  • RCA Master
  • 3,287 Answers
This sounds like a problem with "convergence" of the TV. The convergence circuitry performs the electronic aiming of the Red, Blue & Green projectors. Typical convergence problems result in distorted images on the screen such as: double or triple images on part or all of the screen, wavy lines, curled edges, excessive red, green or blue color or tint, etc. Sometimes, convergence issues can be corrected in a menu setting of the TV that has to do with "Picture Settings" or "Advanced Settings".
If the colors are out of alignment a great deal or went out "all of a sudden" it will probably not be repairable via the menu adjustment described above - but is certainly worth trying.
If it does not straighten out with the menu adjustment, it will probably require replacement of the convergence integrated circuit(s) chips located in the TV. This was a "big ticket" repair years ago, but can be done sometimes for as little as $40 in parts. Don't let the low price fool you though.. It can easily take several hours (or more) to access, remove & replace the components and reassemble the TV. Soldering skills are a must - and I'm not talking about soldering plumbing pipes here either. These are delicate electronic parts and need a 15 - 30 watt soldering iron and de-soldering braid or "solder ******" and LOTS of patience to perform CORRECTLY. As such, it is "not a DIY project" unless you're willing to risk turning your TV into a large floor model paper weight. If you decide to attempt this repair, you should google your TV brand and model along with the term "convergence". Parts, costs and procedures vary by TV. Unplug the TV for a day or so before starting the work to let capacitors discharge fully - just to be safe. Lastly, if you're going to attempt the repair - don't forget to purchase silicone heat sink compound - it is an absolute *must*!
Posted on Sep 25, 2009
I own a 52 inch rca projection tv and last week
Most likely the Horizontal output transistor has shorted. When it shorts it causes the power supply to chirp. This is a common problem with this series of TV. Have a shop check it out. It should not be real expensive.
Oct 16, 2009 | RCA P52926 52" Rear Projection Television
RCA P52755BA 52 inch tv looks 3D
You have a problem with convergence and all you may need to do is replace a fuse. Look up convergence for your tv model and hopefully you will get an answer as to where the fuse is located and how to replace it. Very common for RCA tv's
Aug 30, 2009 | RCA P52926 52" Rear Projection Television
RCA 52" projection tv convergence problems,can i fix it?i try auto convergence? the model is P52920BL and is a 1998 i try the green centering blue & red convergence in the setup of the tv,and it goes back...
My RCA 52 rear projection TV has the letters getting blurry on top and bottom, Picture is OK but visually losing my eyesight staring at blurry numbers and letters.
Is this a bulb or simple fix ??
Mar 28, 2009 | RCA P52920BL 52" Rear Projection...
Sanyo 42" 1080p, picture doesn't fit on screen
this is normal and this feature is for wide screen programs! normal shows and games will lose part of the top of the screen sides and bottem because it zooms in on whats in the middle of screen! hope this helps
Dec 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 52 inch convergence
You have a opened fuse FL231 next to flyback transfomer are 3 Fuses they look like small brown squares/ Fuse in the middle is bad when you do not have convergence listed in menu.You can pull the top off of these fuses .
Nov 06, 2008 | RCA P52960 52" Rear Projection Television
Picture is warped. rca 52 inch model p52929
This is hte beginning of a convergence problem. If you can solder, try resoldering the pins on the convergence ICs. These are large black ICs attached to a heat sink and will be marked STKxxx. If that fails to resolve the problem, replace the ICs.
Keep us posted.
Dan
Aug 25, 2008 | RCA P52929 52" Rear Projection Television
52" RCA Rear Projection P52937SG Color Dots?
There could be an obstruction in the way of the three picture tubes on the inside. This tv has a chassis that comes out from the back all in a chip core frame with handles. Takes a quarter inch nut driver to remove and you should look to see if the speaker wires or the keyboard wires are obstructing the picture tubes. Other something I think of is a broken reflector and when you get the chassis out you can look up inside behind the screen to check for this and for any other obstructions.
Jan 05, 2008 | RCA P52937 52" Rear Projection Television
RCA 52" projection Model no. D52W19 produced 9/04
make sure you do not have the automatic screen mode set to wide screen on tv menu .Also if you have cable box set to wide mode only then the tv will only display wide mode.
Dec 05, 2007 | RCA P52937 52" Rear Projection Television
1 inch lines on top and bottom of screen
Is the picture overall too small by 1 in. on top and bottom? Or is it cut off by the lines?
If it's too small, look for an adjustment labeled Vertical Height. This may only be accessible internally, it's normally a service adjustment, not a user adjustment.
Your problem is a vertical deflection issue, either an adjustment or the vertical circuit requires repair by a technician. In the latter case, electrolytic capacitors are a likely cause.
Oct 17, 2007 | Televison & Video
Televison & Video Logo
147 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
