Question about Mitsubishi WS-65909 65" Rear Projection Television
My Mitsub. ws-65909 green power light turns on for about 3-4 seconds, then shuts off. Ideas ??
  • Mitsubishi Master
  • 5,138 Answers
Replace Both of your STK ICs they are big black ICs will have # on them STK392-570? Call Mats for Parts 1-800-628-1118
Posted on Sep 24, 2009
Mitsub
The model listed has a self check: when you turn it on and green power light comes on and goes out in a few seconds, on the front of the set press and hold both the Menu and Input(input may be labeled Source) at the same time and hold for at least 5 seconds.
Release both buttons and the power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat for a total of 5 times.
If you have unplugged the set you will have to plug it back and turn set on, let it fail and then do the check--removing power clears all errors.
Let me know what code you find.
Dec 16, 2012 | Mitsubishi WS-55859 55" Rear Projection...
Ws-65909 power light goes out after 3 seconds no sound or picture
Thats the code which normally indicates a convergence failure you can get the WS55909 - WS65909 Convergence repair kit which also has instructions from www.tvrepairworld.com its listed under the Mitsubishi repair kits catagory.
Oct 26, 2012 | Mitsubishi WS-65909 65" Rear Projection...
I have ws-65909 65 in TV , The power went out and now the timer light is blinking and i can not reset it.
Unplug it for 2-3 hrs. then when you turn it back on again, be sure to reset the sleep timer to "off".
Sep 08, 2010 | Mitsubishi WS-65909 65" Rear Projection...
9 months ago our Mitsub WS-65611 starting turning
The part number you indicate is the STK-393-110 convergence IC that this set uses--it is possible it is bad again--if properly installed it should not have failed for at least 5 years.
When the set shuts off, on the front of the set engage the self check feature this set has: when the power light goes off ON THE FRONT OF THE TV press both the MENU and INPUT buttons at the same time and hold them for at least 5 seconds and then release both buttons.
The power light should blink a two digit error code: for example--2 blinks, a pause and 2 blinks--this is the most common and it will repeat the code several times.
Let me know what you find---I am here to help people.
If this information helps you, rate this solution as I do this here for FREE.
SD TECH
Nov 16, 2009 | Televison & Video
When I power up the TV, I hear a click and the green light turns on, but seconds later, it clicks off.
try self check==when it shuts off press and hold both menu and input buttons on the front of the set for 5 seconds and release both====power light should blink a two digit code===most common is 2 blinks and then 2 blinks, let me know error code and I will tell you what it means====it should repeat the code 10 times
SD TECH
Oct 17, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi turns on for 3 seconds then shuts off..after power surge
try holding in the menu and input buttons together on the front panel for about 8 seconds to see if the self diagnosis feature will blink a two digt code then let me know what happens
Jun 05, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Mitsubishi Daimond Series 65" Model#WS-65909
Most common repair is one or two open fuses in power supply
and bad convergence Ic's = expensive repair.........Also, have
the tech check for coolant leakage from CRT's...........T.
Dec 30, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi ws-65909
I suspects you have bad convergance IC's
It takes a good tech around 3 or 3 hours to take the old ones out and solder in the new ones. Also, it is likely one or two resistors are burnt and will need replacing as well.
Don not run the tv till you have it fix you will cause more damage!
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 30, 2007 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi WS-65909 65" Rear Projection Television Logo
113 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
