Question about Hotpoint HSS25GFP Side by Side Refrigerator
Fridge is not running and cooling, everything is melted! The electric is working, the lights and temp gages are on
  • 34 Answers
Sounds like it's stuck in defrost. I'm not familar with this model so I can't tell you where the timer is located. Try looking on the back of the unit for a diagram that may show where the timer is located. Look for a small wheel that is made so that it can only be turned in one direction and use a dime to turn the dial until it clicks, the compressor should start.
Posted on Sep 24, 2009
Fridge and freezer not cold. Ice melting.
Need to replace circulation fan in freezer,
Remove plastic bump out in the back of the freezer, to access fan...
Mar 02, 2015 | Kenmore Refrigerators
Whirlpool conquest side by side. Ice began melting and red light for filter replacement was on. I changed the filter but it didn't seem to fix the issue. Few days later everything began working fine but...
Turn the temp control to max, does the compressor come on? If yes feel the discharge line at the back of the compressor, is it nice and cold? If yes you can eliminate the simple items, make sure all the fans are working inside the fridge and at the rear of the unit. Check to make sure the defrost drain/trap are clear. Let it run for a while, then drop the temp to the usual setting it, and see what happens.
Feb 26, 2015 | Whirlpool Refrigerators
My refrigerator is not cooling everythings seems to be working fine and I can hear the flow of refrigerant but it is not getting cold. Is it possible that it needs more refrigerant
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If it's iced up really heavy you have an auto defrost problem. Melt the ice with a hairdryer and check the defrost system.
Jul 10, 2011 | Dometic Refrigerators
My Frigidaire fridge model # FRS6LF7FW3 has stopped cooling and freezing, water has leaked out and everything has/is melting in the freezer. The light bulbs work but the freezer and fridge temp window...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 21, 2011 | Frigidaire 22.6 Cu. Ft. Side-by-Side...
TEMP GUAGE JUST QUIT WORKING. COOLANT LEVEL IS FINE, HOSES ARE FINE. EVERYTHING IS COOL TO THE TOUCH. TEMP GUAGE READS BELOW COLD, YET ELECTRIC COOLING FAN COME ON WHEN ENGINE IS SHUT DOWN.
your gage has just gone out and needs to be replace. the computer control the fan. so as long as the temp sensor is connected to the engine it will work fine but you will not know the temp of your vehicle.
Nov 30, 2010 | 2001 Chevrolet Malibu
Kenmore refrigerator stop cooling but fan working
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Apr 06, 2010 | Kenmore 53642 / 53644 Side by Side...
Fridge and Freezer won't cool.
The evap fan is running - but is your compressor motor running -t his is what i'm concerned about - 82F ? That is very high - this suggests to me there is no cooling AT ALL - only the fans are working - and my gut tells me your compressor is not running AT ALL - I would rule out thermostat since when it kicks in and your evap fans turn on, your compressor should turn on too. If this fridge has electronic controls, have your motherboard / control boards checked, have your compressor checked. If your compressor is running and you can hear its distinctive humming sound, then you have a sealed system problem, a major one :) Have those two things checked.
Aug 19, 2009 | GE Refrigerators
Hotpoint fridge freezer green and red light on, switch offering 0
It could be a few problems to do with electrics, but try this first:
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Dec 04, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Have a hotpoint rsf60 fridge/freezer,noticed over temp red light on, defrosted as ice buid up on top shelf of freezer.light still on red temp set at 3/4 ?
The red warning light will not go out?
1. Has the fridge freezer just been
installed? If so, this is normal and the
light will go out when the correct
temperature has been reached.
2. Has the fridge freezer been loaded
with a large quantity of food? If so,
the light will go out when the correct
3. Have the doors been closed
properly?
Jul 01, 2008 | Hotpoint Refrigerators
Hotpoint HSS25GFP Side by Side Refrigerator Logo
143 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
