Question about Canon Rebel XT / EOS 350D Digital Camera
When i start camera power on it flashes Err CF will not allow me to take pictures
    Problem Solver:
  • 17 Answers
Assuming you have inserted a CF memory card; try a different one. This is typical of a defective memory card. Also, look into the slot to verify no bent pins(they are tiny!)
I do not know if this is applicable on the XT, but some Canon's have a setting to block/allow taking pictures without a memory card inserted. If it does, set it to allow to verify the camera is operable otherwise.
Posted on Sep 24, 2009
I have a canon EOS 400D and when i turn it on it works fine but when i start to use the flash it doesn't flash i get on the screen ERROR 99 ! what do i do ?
ERR99 means the camera is not communicating with the lens - probably just dirty contacts.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Apr 14, 2009 | Canon Digital Rebel / EOS-300D Digital...
Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
Mar 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
''err 99'' code appearing fairly often recently on Canon Rebel XT
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon 40d error 99
Try the following diagnosis steps: -
Mar 12, 2009 | Canon EOS Elan 7ne 35mm SLR Camera
Err 99 when I attach lens
I had the same problem with my camera and i found this guide online very helpful in most cases
4. Insert a fully charged battery, and turn on the camera.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
Jan 29, 2009 | Canon EOS-10D Digital Camera
Err 99 & err cF in my canon 350d camera
had the same problem before
camera body.
camera should be serviced.
Jan 28, 2009 | Canon Rebel XT / EOS 350D Digital Camera
My camera say err CF
These are steps to Fix Err 99's, have a go and see if resolves your other problem too.
Dec 28, 2008 | Canon Rebel XT / EOS 350D Digital Camera
My canon 20d stopped taking photos for no aparant reason. Kept getting error 99 and when I re insert the battery it starts clicking on it's own whether turned on or not. I sent it to Canon repair who...
If two cameras are doing it, I would suggest the contacts on your lens are dirty.
Try the following diagnosis steps for solving ERR 99 issues : -
Dec 14, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS Digital Rebel XTI 400D Displays Err 99. Problem with CF card. Replaced with brand new card-still same err 99 camera is totally charges, acts dead, keep flashing Err CF, I try to format, it...
camera body.
Aug 31, 2008 | Canon EOS-20D Body only Digital Camera
My Canon 20D suddenly started saying "Error 99" and it won't take any pictures. What should I do?
To isolate the cause of the issue, we suggest that you do the following:
Does the “ERR 99′ message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
Does the “ERR 99′ message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
  2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the camera body.
If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
Aug 06, 2008 | Cameras
Canon Rebel XT / EOS 350D Digital Camera Logo
95 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
