Question about Kwikset Locks & Locksmithing
Just had my kwikset dead bolt lock rekeyed. i put it back on the door and now you can't pull the key out after you lock the door. please help
  • 1 more comment
  • Anonymous Mar 12, 2014
    i dont know how to remove lock to install on another door
  • Anonymous Mar 22, 2014
    Bolt was stuck not retract
    Bolt stuck not retract
  • 557 Answers
Sounds like its binding. Loosen the screws that hold the 2 halfs together. Get the key to work smothly. snug the screws and try again. If ok then tighten the rest of the way.
Posted on Sep 24, 2009
No key for a schlage dead bolt i like to rekay
If you don't know how to open a lock cylinder in your hand, you probably should take it to a professional locksmith. They don't charge much to rekey a lock that you bring into the shop, and they can usually do it in under ten minutes. Twelve minutes if you don't bring a key that can open it.
That said, you can open it by shimming with a key blank and a shim, bumping with a bump key, removing the slide or top of the cylinder, picking with a pick, pick gun, or electric pick, key picking it, using tryout keys, rapping it open with a hammer handle, or simply wiggling every old key you can find in it until it either turns or you run out of old keys.
Dec 20, 2013 | Kwikset Professional Door Lock...
Kwickset door handle fell apart on my front door help
Kwikset locks are inexpensive because they do not have replaceable parts. Buy a new one.
By the time the lock breaks, it's probably time to get different keys, but if you have so many keys in the hands of people you cannot contact, or you have more than three other locks keyed alike, and you must have the new lock work with the same keys as before, the place where you buy new locks probably has someone who can rekey the new lock to your old keys. Kwikset also sells locks that you can rekey to other Kwikset keys yourself. They are more expensive than other locks of the same type, but could save money long term, especially if you find a need to rekey your locks a lot (lots of visitors, part-time tenants or roommates, your kids lose their keys a lot, etc.)
Sep 07, 2013 | Kwikset Professional Door Lock...
How do I rekey smartkey when original keys are lost?
the only way to fit a new key to the ' smartkey ' lock system is to use the Kwikset smartkey reset tool, then after the cylinder is reset - you can put a new key in it for alignment.
this tool is availible at most lockshops and they will reset the lock for about 5 dollars.
c...
Jan 14, 2011 | Kwikset Professional Door Lock...
Kwikset SmartKey Error in Changing Key to Lock
Your out of luck this new design is terrible once it locks up and no keys turn it, the lock is done you will have to replace it use the traditional pin tumbler style kwikset and it can be rekeyed unlimited times by a locksmith with or without a key.
Apr 22, 2010 | Kwikset Professional Door Lock...
I have Kwickset door knobs on my outside doors. I
The instructions they send are almost always generic and cover more than one subject.
If you insert the key and turn it all the way clockwise, you should be able to insert the tool tip they sent you into the hole on the shank part of the handle. Pull straight out and it should come off. Some times it takes several attempts to do.
Next turn key counter clockwise back to starting position and remove key. Dump lock out of handle, paying attention to orientation. Turn lock 180 degrees and reinsert back into handle. Put lock and handle back on to door and reinsert the key. Turn key clockwise and push.... remove key.
Hope this Helps,
RSMITH972278
P.S. PLEASE RATE MY ASSISTANCE
Jan 20, 2010 | Kwikset Professional Door Lock...
I bought 2 kwikset deadbolts.The first one worked out fine.The second one I turn the original key by accident.Now neither key will work.Is there a way to rekey my original key.
put the 'dummy key' that came in with it, turn it a 1/4 turn right, put smart key in, pull out smart key. pull out the key and insert the key that you would have as a desired key and turn left 1/4. thats it!!!!!!
Jul 20, 2009 | Kwikset Locks & Locksmithing
Lost entry door key, need to rekey kwikset deadbolt
Unfortunatley you need to have the key to remove the cylinder. You can take it to a locksmith that can pick" it to remove the cylinder and make you a key but it may be more cost effective to replace it.
Sorry not to be mre help.
May 21, 2009 | Kwikset Professional Door Lock...
I cannot remove the door lock to replace it.  It is a screwless type but i dont know the brand
generally, you remove the faceplate on the thin side of the door... there should be 2 screws there... then you'll see 2 holes on another faceplate underneath that one, which require an allen key of the right size... if your lucky you'll see a flathead bolt that can be loosened... then put your key only partially into the deadbolt and turn it counterclockwise and it will come out into your hand... then replace it or rekey it.
Jan 13, 2009 | Kwikset Professional Door Lock...
Kwikset powerbolt 1000 keyless entry deadbolt lock with keypad
Make sure that the bolt hole on the jamb side is recessed enough so the bolt gets a full extension. Without this externsion the bolt will not engage the key release. So when you do your quarter turn you are actually turning more. Remove the strike plate and drill the hole deeper until the bolt can extend all the way. Also double check your key to make sure it is not spurred or worn.
Aug 13, 2008 | Kwikset Professional Door Lock...
Lost keys to my Entry door lock
Visit your local Home Depot and purchase a Kwikset re-keying kit. They're inexpensive and work fine but stay alert and follow the instructions properly. This kit comes complete with proper pins as well as new keys. Good Luck!
Mar 07, 2008 | Kwikset Professional Door Lock...
Locks & Locksmithing Logo
200 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
