Question about Dell Dimension E510 Dual Core 2.8 Ghz (847403171179) PC Desktop
Blinking amber light and wont boot up.
One of the USB in the front of the computer Dell Dimention E510 had one pins shorted. fixed that and problem wad resolved.
If the power button was blinking amber, unplug your tower, and hold the power button for 30 seconds to 1 minute, to use any excess power stored in the capassitors in the pc. this was told to me by a dell tech, it is a small issue with the 3100=E310, and 5150=E510 Dimension desktops
Posted on Oct 16, 2009
How do I fix my Dell computer that keeps blinking amber color light and does not turn on?
You are going to get a range of opinions on this one. Some suggest a new power supply and others more invasivel repairs involving removal of the front panel and soldering!
http://www.tomshardware.com/answers/id-2277673/dell-wont-boot-amber-blinking-light.html
Apr 21, 2015 | Dell OptiPlex Computers & Internet
How do I fix a dimension E510 with a solid amber power light?
A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Apr 25, 2014 | Dell Dimension E510 PC Desktop
Dell Precision T3500 wont boot 1-3 lights blinking
An amber light means your computer isn't reading the hard drive or CD right, Take it to a professional to get this corrected
Dec 16, 2013 | Dell Precision Computers & Internet
I've got a Dell Dimension 5150. After connecting to the mains the power light is blinking amber for some time, it then disappears and only then the computer can be booted. Unfortunately this delay is...
Check POST Boot messages for a flat Battery; Check Front control panel circuit over (remove); Check other USB connectors; Try a replacement Power Supply Unit.
Sep 12, 2010 | Dell Dimension E510 Dual Core 2.8 Ghz...
My Dell E510 desktop won't start. No lights on the front
You have problem with motherboard if you’re PC in warranty then call them from u buy your PC.
And Thanks.
Apr 08, 2010 | Dell Dimension E510 PC Desktop
Boot up problem
Unplug all the Harddrives, Cd Drives attached to the motherborad. Try turning up the system. If it boots, you may to have to change the I/O cables.
Still if it is amber, then your motherboard is having the problem with. As long as the LED glows PCU gotta be okay.
Kindly get back for futher help
Jan 09, 2009 | Dell Dimension E510 PC Desktop
Dell e510 won't make it to post
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
If this has worked you have proven that it's not the power supply (it turned on). If you purchased a non dell power supply, you might try this with the original one installed.
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Now, close case, plug in all usb/monitor/internet/etc. Power up computer. You'll get an internal floppy drive error. Push F2 (maybe F1) to get into the BIOS settings and go to "drives" and turn off the internal floppy. Save and exit. The computer should boot properly now.
This seems to be a big problem with the e510, my theory is that this one small battery is the root of most of these failures (as these computers usually fail after 1-2 years), not the power supply or the motherboard (heck, when you replace the motherboard it comes with a new one of these batteries...a several hundred dollar piece of hardware, with a $5 battery that will actually fix it).
Nov 09, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
4600C no power, flashing amber light
FLASHING AMBER LIGHT FIX. This maybe in fact a motherboard issue, but actually its a bit more. You can and should replace the power supply with a more powerfull one as it will help overall, but the issue is Really the front USB ports and 2 issues concerning them, 1 some devices pluged into them have boot sequences of their own, (remember your boot seq goesfrom,USB,CD,ARRAY)etc.
So if the device isnt design with its own OS, the mis-boot will get stuck Hence the Flashing light. and 2. the front USB ports dont supply alot of power upon bootup. and the devices pluged into them will again cause a mis-boot. Simply unplug everything from the FRONT usb ports. You may have to shut the computer off and unplug the machine for about *15* minutes.
Enough to get the motherboard to downpower completely.
with the front usb ports clear, and the power cord unpluged, hold down the power button and plug in the machine. should boot no problem. So to sum things up. The motherboard is fine, it just not happy with so many usb ports (power wise). A larger power supply is a good idea but wont entirly fix the issue, Unplug front usb devices as they may have some form of bootup.
Jan 19, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension E510 Dual Core 2.8 Ghz (847403171179) PC Desktop Logo
481 people viewed this question
Alun Cox
