Question about LG RUMOR Cellular Phone
LG900 keeps rebooting
Its brand new and i put my at&t sim card in and it wont work..it keeps rebooting..help!
I just got phone yesterday put my sim card in and it will call once but then will stop making calls or sending text. Then it will work OK for a few if I reboot it hrlp
Galaxy S4: Major problem - SIM card not detected - Android Forums ...
forums.androidcentral.com > ... > Samsung Galaxy S4
May 7, 2013 - 25 posts - ‎19 authors
At first I thought maybe my sim died, so I put it in another phone and it worked. ... Youcan do that - but if it's a brand new phone you should just take it ... me a new SIM card because it was right at closing and had me call Tmobile support. .... This kept happening yesterday and then once I got it to stop, I came ...
Why Does My iPhone Say No SIM Card? Here's The Real Fix!
www.payetteforward.com > Tech Blog > iPhone
Nov 28, 2014 - Put your original SIM card back in your iPhone when you get back to the states, and you're good to go. ... on their website to find its location and then come right back here. ... other cell phone that takes a SIM card), and be making phone calls.... But now, my iPhone is wiped, and iTunes can't connect to it to ...
Getting strange "SIM Card Added - please reboot" message all the ...
productforums.google.com/d/topic/nexus/b-HQZZ_jM74
Google
Jan 08, 2016 | Cell Phones
How do I stop no SIM card coming up on my iPad screen all the time.
This is a bug in iOS 8, and there is no solution for it, but I did find 2 workarounds you can try.
1. Buy an empty SIM card and put it in it. Most companies will give you a free one.
2. This is more complex, and it is from a post I read.
I waited to update my iPad 2 but finally bit the bullet & did the update last week. Lo & behold, I started getting the 'no sim card' popup especially while using the App Store (updating & downloading new apps), settings, & apps that required location based services. I read through this thread & searched elsewhere for a solution. After turning off most location services & going through every app (I have many) the problem still remained. Airplane mode worked but I wanted to see if I could fix the problem. Prior to updsting to iOS 8.1.3 & had 'reset all settings' not erasing data. This morning I decided to do it again. still keeping my data. When my iPad rebooted I got the 'no sim card' message once (which is normal) but so far (fingers crossed) it has not reappeared. I also noticed that it rebooted with location services off which I then re-enabled leaving all the defaults on. I have opened maps, the App Store & settings, along with various other apps & my iPad is behaving nicely. It is also snappier than before especially safari. Maybe there were some cache files or corrupted files leftover from the last install. For anyone still having this problem, give it a try before totally resetting your iPad as new.
Feb 28, 2015 | Apple iPad 2 Wifi 16GB
Sandisk sd 8gb
The LG900 works with microSD cards. Your 8GB card is actually a microSDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use microSD cards, 2GB and smaller.
Jun 10, 2012 | LG900 CePhone Hotwired to Net10 Service
Phone keeps coming up insert sim everytime i switch it on enen tho ive put a brand new sim card in, any ideas?
you can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network,try here
http://www.prounlocking.com/sony-ericsson-w910i/rs8wp9/
Dec 21, 2010 | Sony Ericsson W910i Cellular Phone
Phones unlocked but i still cant get it to work signals there but wont let me call or text im on 02 network
It could be a SIM card issue but you can try as my daughter did, take the battery and sim card out of your phone and let it sit for about fifteen minutes and the put your sim card and battery back into your phone and reboot it. When you reboot see if it will let you call or text, if it does not work after that take the phone back to the service providers store and they either need to give you a new SIM card or it is a technical issue with the phone and it may need to be replaced/repaired, if it is still under warranty I would go ahead and replace the phone and the sim card.
Nov 13, 2010 | Cell Phones
MY SIDEKICK 08 KEEPS SAYING NO SIM CARD EVEN WEN
I just got a sidekick off the internet and I put my SIM card in the phone and it says no SIM card. What do I do? Anyway to fix whatever is wrong?
May 30, 2009 | Sharp Sidekick LX Smartphone
Motorolla slvr wont recognize sim card
try taking the sim card out and put it back in...it could be network, tower or sim related....wait at least 20 seconds before putting battery back in..this reboot should help..if not, u should contact ur service provider....
May 13, 2009 | Motorola Mobility SLVR L7 Cellular Phone
My viewty keeps switching it self on and off
I have just had the same problem. i was so scared that i had lost all my personal data.
my sim card was years old and as the software on the lg is new it was causing it to shut down and reboot over and over and the only way to stop it was to take out the battery.
This MIGHT help! it helped me.
Take the battery out and put someone else's sim card in (someone who has a new sim card) - they have to be the same network. (if your own sim is really new this may not help) .
put the LG back together and switch on - the phone should start new set up. if it prompts you to copy contacts to phone press no.
if this works then it is a software problem. this may be the best time to back up all your data on your computer via the lg suit.
then put your own sim back in. if the problem still happens then you need to call your phone service provider and get them to refresh your sim card - do the same process as above and this should fix it.
i hope this helps.
RW
Jan 06, 2009 | LG KU990 Viewty
Phone wont recognize Sim Card
same prob here.. went to an at&t store and they put a new chip into the phone. they couldn't get the existing data xfer'd tho... which sucks. at least the phone is alright.
Feb 14, 2008 | Pantech C300 Cellular Phone
Sony ericsson S500i
Hey i'm having the same problem with mine, u prob got it sorted by now but i found that it is because my sim card is so old, tested it with my friends brand new sim card and works fine,
did you solve the problem?
Jan 15, 2008 | Lands Phones
LG RUMOR Cellular Phone Logo
155 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
