Where is the low side hose located on a 93 toyota camry?
    President:
  • 3,433 Answers
Passenger side coming out of fitrwall. Its the large aluminum tubing . The low side and high side fittings are different in size, the low side being the larger. Good Luck. Ned
Posted on Sep 24, 2009
How do i adjust the transmission bands on a 93 toyota camry?
Adjustments - AutoZone
www.autozone.com/repairinfo/.../repairGuideContent.jsp?page...
AutoZoneBoth band adjustment screws are located on the left side of transmission, the ... 13: Automatic shift control adjustment-1989-93 vehicles with the 3.8L engine .... Ex. 04 Camry Battery See More Examples ... Explorer 4WD 4.0L EFI SOHC 6cyl; 2001 Toyota Corolla 1.8L EFI DOHC 4cyl; 2004 Infiniti M45 4.5L SFI DOHC 8cyl.
Aug 24, 2015 | Toyota Cars & Trucks
I need to add refrigerant to my 95 Camry? I have a can of R134a with a hose and connector, but it says it must be attached to the low pressure side. I see a fitting by the dryer (I think that is what it is...
i think it is r-i34.the way you can find out is when you open the hood,read the stickers that are on the underside of the hood.it should tell you there if it is 134 or r-12.if it's r-134.the low pressure hose usually has a blue cap on it and anyways you can't connect the hose to any other fitting because it will only fit on the low side valve.the valve should be located on the passenger side,right by the fire wall,in back of the strut tower.just look for the blue cap.if the cap is not on it,well like i said,you can't mix it up cause it only fits on the low side valve anyways.i hope this information helps you.good luck and take care, manny
Jul 09, 2010 | 1995 Toyota Camry
On a 1996 toyota camry ca you tell me where the thermastat and water pump are located?
the thermostat is located on the top of the engine follow the radiator hose it usually ends at the thermostat and the lower hose usually ends at the water pump which in your case will probably be on the side of the engine.
Feb 06, 2010 | 1996 Toyota Camry
Where is the thermo time switch located on a 93
First of all, I own the same vehicle. 93 camry xle v6. I have rebuilt the engine, etc. Open the hood. Looking at the engine, it's on the right side under the air intake tube from the air cleaner box, on the top of the intake manifold. There are two sensors threaded (screwed) in side by side and have a connector harness plugged in each of them. The thermal time switch is the sensor located on the inside, toward the engine. Note: Take a close look at the connecters inside grooves. You can tell the difference shape. Good luck.
Oct 25, 2009 | 1993 Toyota Camry V6
Where is the air conditioner located on a 93 toyota camry 4 cylinder
front pasenger side you see 2 hose come of the compresor
Aug 12, 2009 | 1993 Toyota Camry V6
What is the high and low pressure on 1997 toyota
The high and low pressure is refer the hose BEFORE (low) and AFTER (high) the A/C air compressor.
Low side can range from 0 (dead compressor) to 120+ (overcharged system)
High side can range from 0=dead to 170++ overcharged or damaged compressor.
DO not attempt to charge the system unless you has the correct manifold A/C unit and hoses to do the job.
Jul 16, 2009 | 1997 Toyota Camry
93 CAMRY V6 WATER LEAK ON PASSENGER SIDE BETWEEN RADIATOR AND FENDER. IS THIS WHERE THE WATER PUMP IS LOCATED?
generally in this model when water pump leak, drops on damper pulley, if leak is near radiator , check this
Jul 05, 2009 | 1993 Toyota Camry V6
Need to find location od thermostat on 93 camry
try these websites www.autozone.com and www.alldatadiy.com and you should be able to get the information you need.
Jun 30, 2009 | 1993 Toyota Camry V6
I cant locate the fuse for the power windo of toyota camry '93. i have a new switch, none of the switch is working.if i can locate the fuse for the power window , i guess i can fix it.
the power window fuse, which is linked to several other systems, should be in the kick-panel fusebox on the driver's side. there should also be a circut breaker for the motors, probably behind. the glovebox
Jun 04, 2009 | 1993 Toyota Camry V6
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
