Question about Nintendo Game Boy Advance SP Console
Backlight the screen backlight is not coming on when I press the button
Cant find cheats anywhere for need for speed most wanted
Posted on Jan 18, 2008
  • 35 Answers
What happens if you press it for a long time?? does that work?
Posted on Dec 27, 2007
  • Nicola Saya Dec 31, 2007
    happy to help... even if it hurts your finger.. srry.
Blank screen on LCD TV
either the backlight power board or the power board itself isn't powering up the backlight power board
or your backlights are burnt... this is where testing comes in
Dec 30, 2013 | Televison & Video
My 6-month old tv is making intermittent 'buzzing" sounds. It was a Christmas gift and I don't have any paperwork on it but it did come from Costco. What should I do? Thanks so much.
Humming usually begins when the backlight setting is low. For some sets setting the backlight anywhere from 95 to 100 works. Most wok at 100. So turning it up should get rid of the problem. You can follow the 5 steps below to change the backlight setting.
1. Turn the TV on.
2. Press the Menu button on the remote, located right below the channel changing button.
3. Press the down direction button, located at the middle of the remote. Press that button until the backlight is highlighted.
4. Press the right direction button until the backlight is at 100.
5. Press the OK button and then the Exit button until you get back to your picture.
Jun 15, 2011 | Vizio 42 in. LCD TV
How do you turn on the Backlight on the screen?
If the screen backlight is not on, first try adjusting the brightness.
Press TV/AV button on remote to select TV mode. Press the MENU button on the remote. Using the arrow keys (navigation buttons), choose picture mode and adjust the brightness and contrast.
If your TV screen is still not lighting up in a dim room, then the backlight is broken.
You have 90 days labor and 1 year parts from date of purchase.
Oct 19, 2010 | Haier HLT71 7 in. Portable TV
My sansa clip will play music but the screen will not light up;
There's a timer for the display backlight that can be set and used for
saving power. When leaving the player untouched for a certain time, the backlight switches off. Touching any button will turn on the backlight, restarting the timer.
To set the backlight timer on the Sansa Clip,
execute the following steps:
1. Press Menu button to return to the Main Menu.
2. Move to Settings and select it.
3. Select Display.
4. Select Backlight.
5. Press |<< or >>| button to select desired backlight timer.
Dec 24, 2009 | SanDisk Sansa Clip MP3 Player
Backlight off and can't get it on again.
Either clean the screen or navigate the iPod by heart. Try pressing any button and it should come on
Dec 22, 2008 | Audio Players & Recorders
My psp has no image but it has sound
Dude, I had the same problem, the screen everything works fine when I use the TV out,
Check it out and tell me. I already call Sony and they will replace it with a new one, I recommend you call them if you still your warranty and your receipt.
If the LCD screen suddenly turns dark
  • Check the Backlight Auto-Off setting
    If the Backlight Auto-Off setting is turned ON, the backlight will turn off after a set period of time. Press any button to turn the screen back on.
    To check the Backlight Auto-Off setting:
    1. From the XMB™ menu, go to icn_settings.gif (Settings) > [Power Settings] and press the icn_btnx_color.gif button.
    2. Highlight [Backlight Auto-Off] and press the icn_btnx_color.gif button.
    3. Select a time interval and press the icn_btnx_color.gif button to save. Select OFF if you wish to disable this feature.
  • Check the Auto Sleep setting
    If the Auto Sleep setting is turned ON, the screen will turn dark after a set period of time. Press any button to turn the screen back on.
    To check the Auto Sleep setting:
    2. Highlight [Auto Sleep] and press the icn_btnx_color.gif button.
  • Check the Display Button
    Check the Display button on the front of the PSP system. Pressing the Display button (located to the right of the PSP logo on the bottom front) will cycle through the brightness settings of the LCD screen.
    The brightness setting can only be used when the PSP system is plugged into an electrical outlet with an AC adaptor.
Aug 15, 2008 | Video Game Consoles & Games
No backlight
A couple things to try:
1st check the backlight settings
Turn on Backlighting and Control Brightness To use your device in dark environments, enable the automatic backlighting feature:
  1. From the Jump screen, press MENU t02003-15.gif then select Settings > Battery & Display.
  2. In the second group box, select the Turn on backlight when using device check box.
  3. Highlight, then select the Brightness slider to open it for editing. Roll the TRACKBALL right to increase brightness; roll the TRACKBALL left to decrease brightness. After you've made the adjustment, press the TRACKBALL to exit edit mode. t02007-55.jpg
  4. Select the length of time you want backlighting to stay on from the Turn off after pop-up menu.
  5. To use the device's light meter while the backlight is on, select the Use ambient light sensor check box.
  6. Press JUMP t02003-14.gif to return to the Jump screen and save your setting.
Now, when you press any button or key, or flip open the screen, backlighting will turn on for the set amount of time. Note that as long as you press a key or button before the set time elapses, the backlight will stay on.
  • Even if you have not selected automatic backlighting, you can turn on backlighting at any time by pressing MENU t02003-15.gif + JUMP t02003-14.gif . The backlight will remain on for the time specified in the Backlight Turn off after pop-up menu.
  • When in key guard mode, you can turn on the backlight by pressing the RIGHT SHOULDER t02003-66.gif button.
If it still does not work, then you can try resetting the flex cable to the lcd.
Reseat the SidekickFlex cable
If that doesn't fix it then a new lcd assy will take care of the issue. they run about 45 dollars on ebay.
Sidekick LCD screens
Apr 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
No screen
The backlight is probably gone. Just had same problem on my sons one. I purchased a replacement off ebay seems a simple enough job to do if you are sort of tech minded.
Apr 03, 2007 | Sony PlayStation Portable (PSP) Console
Nintendo Game Boy Advance SP Console Logo
75 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
