Question about Olympus VN-3100PC Digital Voice Recorder
My batteries are low. Will I loose my information that i have stored on it when i change them.
    President:
  • 987 Answers
No no you wont loose ...
Posted on Sep 24, 2009
Testimonial: "Thank you! That takes a load off!"
2008 ford edge turns over a bit slow then the interior lights flash twice and click. Is this a battery issue?
Yes, sounds like the battery is low. need to recharge or replace. An auto parts store can test it for you.
Oct 29, 2013 | 2008 Ford Edge
2001 victory v92c bucks and dies at low rpm...
Hi, Biothumper and the usual suspects are:
1. Severely discharged or a damaged battery must have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
2. Faulty alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Faulty main circuit breaker or ignition switch, check for loose connections and continuity.
5. Faulty system and or ignition relay, check for continuity.
6. Faulty ignition coil, ignition/electronic module.
7. Faulty CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Faulty neutral, side stand or clutch lever safety switch.
10. Fuel tank empty
11. Fuel tank contaminated with ethanol sludge.
12. Water or dirt in the fuel system, or clogged filter.
13. Restricted, blocked or kinked fuel line.
14. Faulty fuel pump.
15. Faulty pressure regulator.
16. Faulty or clogged fuel injectors.
17. Lean angle switch is faulty or needs adjustment.
For more information about your issue and valuable "FREE" downloads that you need please click on the blue links below. Good luck and have a wonderful day.
2003 v92 stalling an low idle Please help
2002 V92TC Stall jerky throttle even when warm dealer can figure it out
Victory Motorcycles Classic Cruiser 2002 Service Manual
Motorcycle Service Parts Part Finder Victory Motorcycles Store
Victory Motorcycles V92C Owner Manual
May 31, 2017 | 2001 Victory V92 Cruiser
Why it shows low battry backup wen evere in use
Hi when a phone shows low battery when in use, is because the battery of the phone you are using is too low to power on the phone too long, so the information means,WARNING you might loose all information at that moment that you are using the phone,you you need to save what ever your doing at that moment in time so that you will not loose any important document on your cell phone.Also you should shoot down quickly because it damages the cell of the battery faster....
I guess that's what the message on your phone means .
Hope that helped.
Take care....
Feb 09, 2011 | LG Prada KF900 Cell Phone
2004 Trailblazer will not start. Battery and fuses check out to be good.Tach and speedometer jump around when starter is engaged.
Hi!!
It sounds like your battery is ether LOW or the wiring is loose. Check battery cables to be tight and free of corrosion, also check for loose wires to the battery and alternator. if everything is OK, jump start vehicle. If problem persists, take vehicle ot an AutoParts store to have Starting and Charging Systems checked. (no charge).
Good Luck!! Don't forget to rate this post!!
Aug 03, 2010 | 2004 Chevrolet TrailBlazer
I have a nokia 5200 mobile handset,now the problem that i am facing for the last 8 or 9 months is the moment my phone starts ringing or i am playing some games on my mobile handset,my battery starts...
Due to agening the mobile looses its power storing capacity.Due to this your moblie switches off soon.So please change your mobile it wil be ok.
Thanx
Jul 20, 2010 | Nokia 5200 Battery
I changed the alternators starter and a brand new battery something is still draining my battery down if i dont drive it for a couple of days. ???????????????
Hi my name is Tom and I can help you.
There are a number of reasons a battery gets drained. First, Is your battery capable of being charged. To determine this, take the battery to a parts store and they can tell you.
If the battery is so low it will not take a charge, you can charge it forever and it will do no good. Assuming the battery is good, check and see if any lights are on when you shut the car off. Dome and trunk lights are key spots.
My bet is the battery is too low to be charged and when you get a new battery that should be the end of your problem. I trust this information was of help to you.
Please take the time to grade my information and if I can be of further assistance please call or email me.
TomE
Jun 29, 2010 | Cars & Trucks
"my 2005 dodge spinter 3500 2.7 diesel has bat light on that says hi whats this mean?
Means output is to high this can be casued by low battery water bad regulator a loose wire on the altanator or starter and would need to be tested to know for sure, However most auto parts stores will test the ouput for you and give you an ideal. The only thing is if you have it tested post the results here so we can give a detailed way to test your issure. I could answer this with more information but the test voltage and amperage output would give me enoght information to keep you from spending money on parts and a lot of tests at the auto parts store.
If you leave it like this it could damage your electrical system. Hope this helps and thanks for using fix-ya!
Jun 26, 2010 | 2005 Dodge Sprinter 3500 Standard Roof
I changed the baterry on my previously running cherokee and now wont even turn over
Hard to say exactly with out checking myself;
Wrong (to low amps) battery, poor condition of battery clamps, loose cables going from battery to starter assembly, battery installed in reverse polarity. Perhaps the NEW battery need to be charged ( storing a battery on concrete (cement) slab will cause a drainage of the battery and it doesnt take long)
Nov 23, 2009 | 1994 Jeep Cherokee
Will changing a bios battery in Dell GX280 affect
Some information will be reset and you will have to set the correct time.
But the information stored in your hdd is not concerned. It should be safe.
Hope it helps.
Aug 29, 2009 | Dell OptiPlex GX280 PC Desktop
I recently purchased 5 double packs of 9V Energizer Batteries to replace in my CO/SMOKE ALARMS which I have 8 detectors. The alarm was chirping and had the batteries checked and they all checked out as...
Try calling the battery company or taking them back to the store where you bought them. Most will have a date code on the batteries so you want to always check them when buying as old batteries that have set on the shelf for a while will eventually loose thier charge
Aug 16, 2009 | Energizer Ml1W2Aae
Olympus VN-3100PC Digital Voice Recorder Logo
57 people viewed this question
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
