Question about Bakers Pride P-44S Oven
Baker's Pride P-44s P44s
I have a Baker's Pride P-44s (P44s) oven and I need to replace the thermostat on it. I don't know how I am supposed to run the wire and capalary in the back of the unit to the top without taking the entire thing apart. All that shows in the front looking into the oven is a small hole that the wire and capilary comes out. Anyone know how to get access to the back to run it?
  • Andre Sep 24, 2009
    I already have the parts to replace the thermostat. I am wondering how do I run the wire and capilary to the back and top of the unit without taking the whole thing apart.
    The service manual doesn't specify how to do it. Anyone know?
  • 8,197 Answers
You can get parts here at this link.
http://www.tmeinc.biz/xbpride.htm
Good luck and please rate
Posted on Sep 24, 2009
  • Jyackle5
    Jyackle5 Sep 24, 2009
    Sorry can not find you a service manual. You need to contact them here.
    Bakers Pride Oven Company
    30 Pine Street
    New Rochelle, NY 10801
    Phone: (914) 576-0200
    Fax: (914) 576-0605
    Toll Free: (800) 431-2745 U.S. & Canada
    sales@bakerspride.com
    Good Luck
  • 657 Answers
How to replace the thermostat on BP y-600
Turn off gas supply. Open panel on left side. Loosen the top and bottom unions. Remove thermostat capillary line from the oven. Now remove thermostat with 2 pipe wrenches. install new thermostat and attach assembly to the unions you loosened. Now insert the capillary line back into the oven.
Jul 27, 2014 | Bakers Pride Y-600 Gas Single Oven
I have had a P-44 oven in an Auntie Anne's Pretzels shop for 15 years. It has been connected to a 4-wire, double-breaker circuit. I ordered a new P-44 through Auntie Anne's and thought it would be...
hi...since the specification of your new oven is 208v 1-phase and since voltage rating on your receptacle or outlet s only 120v..it would be advisable for you to purchase an INVERTER, it is a step-up transformer that converts 120v to 220 v..in that way you can supply your oven according to its specification..thanks..
Jul 06, 2011 | Bakers Pride P-44S Oven
My wires are labeled A1,A2 ,A3 and A4 .how do they connect to the terminal block
hi..there is color coding on the wires..BLACK WIRE is the live wire(wire #1) which should be connected on top of the terminal supply of your oven (if vertically positioned) and sometimes to the leftmost right(horizontally positioned),then the RED WIRE to the bottom (vertically positioned),or rightmost part (horizontally positioned) and the WHITE WIRE is at the center(both horizontally/vertically positioned0 and the GREEN wire must be connected to the grounding of the unit just below/beside the terminal supply of your oven..hope this helps..
Apr 16, 2011 | Bakers Pride P-44S Oven
Needs a new safety switch, discontinued part.Any suggetsions?
Take out the part and note any markings and numbers on the switch, you may be able to source one from somewhere else if it isn't Bakers Pride specific, also go to an electronics parts store with the switch , they may be able to adapt something or may have something similar.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Mar 01, 2011 | Bakers Pride P-44S Oven
Stones get too hot, burns on bottom before top cooks
Assuming you have the oven adjusted properly maybe the thermostat might need to be replaced?
I would try and adjust the flame to a lower height before replacing the stat.
Oct 23, 2010 | Bakers Pride Y-600 Gas Single Oven
Need a wiring schematic for a Bakers Pride p44 double pizza oven.
Apr 15, 2010 | Bakers Pride P-44S Oven
Need a thermostat for lang model gpo-1 pizza oven
I'll try to find one for you if you haven't found it already. Please email or call me. EllaWatson25@yahoo.com 9728590929. Hope this helps.
Aug 21, 2009 | Bakers Pride FC-616 Gas Single Oven
Bakers pride pizza oven not lighting
Hello. Usually this problem is related to the pilot being dirty, and not heating the bulb for the safety device properly/hot enough to fully open the valve. If you have a general purpose mini torch you can heat the metal bulb near the pilot with it, if this is the problem, the safety will open, and the main burner will come on. CAREFUL, you are not on/around the main burner, as it will allow gas to come on to the main burner, and if your pilot is not working properly, might not light the gas. Get the pilot cleaned and adjusted.
or... :) I know... your safety has failed, allowing gas to the pilot, but internally is not opening, this requires replacement. Last though, it could be your thermostat, its last in line, and would require replacement. The safety, and the thermostat are mechanical valves, open or closed depending on its function.
If you have a more current type, they will have a combination valve, and thermopile/thermocouple that are electromechanical, your thermostat at this point can be either mechanical, or electromechanical. This system has a few more possible causes for your symptom.
You can tell which you have by how you light the pilot, have a red button on the front of the unit, by the on/off valve? this is the first type.
Have to open a small door to access a knob, turn it to pilot, and hold in? this is the latter type.
ask if you need more help.
Hope that helps, and thank you.
Dec 17, 2008 | Bakers Pride Y-600 Gas Single Oven
Thermostat setting for bakers pride y600 oven.
Hi, those screws are for the calibration of the knob to the thermostat, so your calibration is correct. Most likely you will have to contact a servicer to check the calibration, and set you knob and plate where they will align with the actual temp again.
May 19, 2008 | Bakers Pride Y-600 Gas Single Oven
Bakers Pride P-44S Oven Logo
381 people viewed this question
Top Bakers Pride Ovens Experts
ashburton
paulcarew
Dan Webster
Dan Webster
Are you a Bakers Pride Oven Expert? Answer questions, earn points and help others
