Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner
Problem for Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD...
PTO clutch will not engage.
By tigergrant on Sep 24, 2009
Problem stated with a 10 second delay for the clutch to engage, now it will not engage at all. Where is the relay on my cub 2130? How can I test the clutch?
Best Solution
posted on Sep 24, 2009
Very Helpful)
dean_lynn166
Rank: Guide
Rating: 100%, 4 votes
first start by turning ign on,then switch on the pto switch to on. you should hear a click in the clutch. if not use a twelve volt test light,hook aligator end to a good groundand the needle end,,,touch to the pto switchharness to see if you have power to the pto switch. if you don"t, you have to go checkfurther to your power source,(battery) if you do have power there check to see if you have power at the plugin at the end of your wire harness, just at the beginning of where your cluch connects up. you can test you clutch by conneting a test wire from positive on your battery to one of the terminals on your clutch and the other terminal to ground . It willengage if it is good .using either wire is ok as all it will be doing is completing a circuit. hope this helps.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Oregon Scientific Electric PTO
Questions and Unsolved Problems for Oregon Scientific Electric PTO
Do you recommend Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner?
Answer
Answer
wiring burned up on cub cadet riding mower. need to see wiring diagram.
Answer
I have a cubcadet lt1045 and my pto will not engage, I just replaced the pto clutch, and put... (More)
Answer
My electric clutch is gone on my toro walk behind. How easy is it to replace?
Answer
I pull the engage switch i hear a sound, the engine revs down about 1 second, then it doesn't... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Riding Mower and... Experts
Top Garden & Power Tool Repairmen
in Tulsa, OK
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
