Question about Texas Instruments TI-30XA Calculator
I am trying to make a sum of degree,minutes,and seconds but i do not know how to do it
  • Texas Instru... Master
  • 8,025 Answers
Here is how you manipulate them. Hope it helps.
Posted on Sep 29, 2009
How do I input Degrees-Minutes-Seconds to convert to Degrees? Vice-Versa.
On any calculator, let's convert degrees-minutes-second to degrees and then we will do the reverse.
Let's start with the number of seconds in a minute - 60, so we must take the seconds and divide by 60 to get the number of minutes. Next, add the number of minutes. The number of minutes in a degree is 60, so we take this total and divide by 60. Now we add the number of degrees to get out final answer.
Example: 35 degrees 50 minutes 32 seconds
(32/60 + 50)/60 + 35 = 35.842222 degrees
Just out of interest, let's start with 35.842222 degrees and convert it to degrees-minutes-seconds. We know it is 35 degrees, the whole number. Now we have to determine the minutes and seconds. Start by subtracting 35 to get the decimal 0.842222. Now multiply by 60 to get the number of minutes. I get 50.5332. Subtract 50 from this and multiply again by 60. I get 31.9992, which rounds to 32 seconds.
Good luck.
Paul
Jul 06, 2015 | Texas Instruments TI-36 X Solar Calculator
How can i convert decimal in degrees, minutes and second
I don't think I have that calculator, but let's work through it with any calculator.
Let's say our heading is 45.3275 degrees. So we know it is 45 degrees, so subtract 45 from the number and multiply by 60, since there are 60 minutes in a degree. I get 19.65. So now we have 45 degrees and 19 minutes. Subtract the 19 minutes to calculate the number of seconds by multiplying the result by 60. I get 39 seconds. Overall, we have 45 degrees, 19 minutes, and 39 seconds.
Good luck.
Paul
Apr 22, 2015 | Casio FX-65 Calculator
How do you write numbers in degrees, minutes and seconds?
In Run/Mat press OPTN key. Press F6/Next until you locate the ANGL tab. Here what it will reveal. To enter the values in DMS, use the F4 key.
May 28, 2014 | Casio FX-9750GII Graphing Calculator
Their are three angle d first one is 128 degree, the second one is 37 degree, find x
I presume that x is the measure in degrees of the third angle. Use the fact the sum of the interior angle of a triangle is equal to 180 degrees.
x+128+37=180
x+165=180
x=180-165=15 degrees.
Sep 16, 2013 | Office Equipment & Supplies
I know how to convert between decimal degress and degrees, minutes, seconds, but how do you enter degrees, minutes, and seconds directly?
Enter it as DD.MMSS and then press 2nd [DMS-DD] to convert it to decimal for further calculations.
For example, to enter 21 degrees 34 minutes 45 seconds, enter 21.3445 then press 2nd [DMS-DD].
May 12, 2011 | Texas Instruments TI-30XA Calculator
I'm using the Casio fx-115ES model. When i try to put in 52 Degrees, 10 minutes, I dont seem to be able to do this. I key in the numbers 52 then hit the "degree, minutes seconds" button and i get the...
When entering the information it only shows the degree symbol. If you press enter or type inthe formula, then the answer will show the Degree, Minutes, and seconds. It seems to be the way it was program by Casio. It still seems to work fine for entering that information
Aug 03, 2010 | Casio FX-115ES Scientific Calculator
Sir i want to know calculations degree, minutes and seconds
Since one degree is defined as one three hundred sixtieth (1/360) of a circle .Where as 1minute is (1/60) part of a degree and 1second is (1/60) part of minute .They have following relation : 1 degree = 0.0167 minute = 0.000278 sec . You can convert them easily using your calculator .
Jul 28, 2010 | Casio FX-115ES Scientific Calculator
Find cos 32° 45'
Look at the column of keys under the ALPHA key. You have the integral, the square root, and then the key that has a degree sign, an apostrophe and a double closing quotation mark. That is the one you use to enter the angle in sexagesimal notation. To simplify my task I will symbolize the key with [DMS], degree, minute , second.
To calculate cos (32° 45')
you press
[COS] 32[DMS]45 [DMS] ) and press [=] The result si 0.841039013
Hope it helps.
Nov 08, 2009 | Casio FX-115ES Scientific Calculator
I do not know how to load latitude and londitude into my tomtom. I am going to Bad Liebenzell in Germany (with caravan) The Latitude is 48.87329 (I do not undestand that because lat/long is usually...
Latitude is N or S, longitude is E or W, correct.
When entering degrees, minutes and seconds, you dont have to type the double apostrophe at the end off seconds, the device will understand...
ALT and LONG can also be seen as decimal degrees,
as in your case N48.87329 E8.6923
The TT device understands them both, just type them in....
Sep 03, 2008 | Tomtom GPS
How do you enter an angle in degrees, minutes and seconds on the HP 33s ?
Enter than angle as 32.2010 then press left-shift [->HR] to convert to decimal degrees.
The ->HR function (and the companion ->H.MS are for working in hours-minutes-seconds, but they work just as well for degrees-minutes-seconds.
Oct 21, 2007 | HP 33s Calculator
Texas Instruments TI-30XA Calculator Logo
53 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
