Question about Canon PIXMA MX700 All-In-One InkJet Printer
Canon mx700 not printing blue with new 'canon' cartridge. It didn't work with 'office depot' cartridge either. Any ideas? I've been using the printer for more than a minute. Changed tanks before with no problem as long as I use the canon brand :-( I've cleaned heads with no joy.
    Sergeant:
  • 284 Answers
Maybe PURGE UNIT or PRINT HEAD is not functioning properly.
Posted on May 27, 2010
I have a Canon MX700 and suddenly I began to have problems with the color. I am using Canon ink cartridges but all my color jobs come out with only blue and black, no magenta or yellow. Every time I run...
This worked for me:
Unplug (not just turn off) the printer. Wait at least 20 seconds, then plug it back in. Hold the Feed Switch down, then turn on the printer (continue to hold the Feed Switch down). When the printer finishes cycling the paper feed, release the Feed Switch. Copy anything and it should print. You're good to go.
Oct 01, 2013 | Canon PIXMA MX700 All-In-One InkJet...
MX700 printer does not print in black
you have a clogged jet and ink has dried inside i reckon... the only other thing it could be is the message from the logic board (its motherboard) inside printer isnt getting to the print head or print head itself has malfunctioned - i would suggest to fix but it would probably be cheaper to buy a new one but dont give up.... sometimes they do work if you print pages even tho there is no flow and the heat may dislodge blockage if there is one... But heres a video that may help...
May 06, 2017 | Canon PIXMA MX700 All-In-One InkJet...
Nozzle check for Printer
take out the colors and see if the black prints. if not you could need a new one.
Sep 02, 2012 | Canon MX700 Office All-In-One InkJet...
Installed Office Depot ink cartridges, BCI 6 C and Y in my MP780. Worked ok at first, but then started getting "wrong cartridge" msg, Per canon rep, turned off mach, disconnected power, took out...
This is an example of why 2nd class refills are junk. I would try to gently clean the printer out. While a lot of people disagree with this advice, a mixture of 90% alcohol in a tiny pipit works well. Then use some lint free q-tips. Most cartridges have electronic chips on them that report the status of the cartridge. Refilled ink cartridges may have bad or defect chips.
Jan 04, 2011 | Canon PIXMA MP780 All-In-One InkJet...
Canon Pixma MX700:one print cartridge not working
The cartridge is only a tank that holds ink. The printhead is the device that you put it into and probably has a blockage in the magenta head. Open the machine so the carriage moves to the center. remove all the cartridges.
TCT How to remove and clean Canon Printhead see the link below. The MX700 may have the locking mechanism at the front of the carriage, so you should move it slightly right and then pull the colour bar forward to release the printhead. carefully remove the printhead. Sit it in a shallow dish/tray of hot water for a few minutes and dry with a paper towel. Put it back in the printer reset the locking bar and cartridges. Try a nozzle check through the tools menu. Yoyu may need to repeat the process if the magenta printhead is badly blocked
Feb 13, 2018 | Canon PIXMA MX700 All-In-One InkJet...
Canon MX700 with new cyan cartridge very faint
The print head needs a chemical solution. You have to soak it to chemical solution to unclog it. It should be a chemical solution that is really use for print head. If it does not work, the worse thing to do is to buy a new print head.
Sep 24, 2009 | Canon MX700 Office All-In-One InkJet...
My print is crooked.
try to change the ink cartridge and see if that works and also do the alignment after
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 20, 2009 | Canon MX700 Office All-In-One InkJet...
Ink Cartridge
how do you set the ink tank on a mx700
Feb 25, 2009 | Canon MX700 Office All-In-One InkJet...
Printing too red
At this point I would offer that you bight the bullet and get a set of OEM Canon cartridges and do all the deep cleaning etc and see where that puts you. The third party cartridges may have caused some kind of problem, and not any "damage"
Nov 23, 2008 | Canon MX700 Office All-In-One InkJet...
Canon PIXMA MX700 All-In-One InkJet Printer Logo
143 people viewed this question
old marine
old marine
