Question about Asko 24 in. D3250 Built-in Dishwasher
Asko 1876 dishwasher soap flap opens as soon as power on.
Soap dispenser flap operates as soon as the mains on / off switch is operated , must be powered up all the time as unable to release opening mechanism until power turned off. Unit gets hot whilst dishwasher used , due to being powered up all the time. Looks like the control board being faulty???
I don't know about the control panel - I am having trouble with mine too, but in regard to the soap dispenser -- don't use it anymore. Just buy those little tablets. That is what the secretary at the repair shop told me when I had a problem and that's been fine.
Posted on Sep 24, 2009
Testimonial: "THE SOAP TABLETS ARE A GOOD IDEA , BUT IT DOESN'T STOP THE DISPENSER BEING POWERED ON ALL THE TIME AND POSSIBILY OVERHEATING. SO STILL NEED A SOLUTION"
Why does my detergent latch open up while the dishwasher is running?
If neither the detergent flap open or the rinse aid is being dispensed the this is usually down to a faulty or 'open circuit' solenoid that operates the dispensor unit.
Sep 20, 2014 | Maytag Dishwashers
Soap dispenser won't stay closed
Only two reasons this may happen. One is the dispenser is just bad (most likely) or that the timer is somehow malfunctioning and sending power to the soap dispenser all the time (least likely) You will usually know if its the second because the dispenser will get really warm after the dishwasher had been on for a few minutes.
Aug 15, 2012 | Asko D1716 Built-in Dishwasher
My Asko D1716 dishwasher works fine apart from the soap dispenser. It won't open to release the soap.
Most likely it's a corroded door catch or a bad solenoid. Hopefully it's not the main control board. You'll need a repair manual or technician. A work around would be to use detergent tablets in the compartment
Mar 02, 2012 | Asko D1716 Built-in Dishwasher
The soap isn't emptying out of the compartment during the wash cycle. 1. We didn't load any items too close to the dispenser. 2. We didn't use the Rinse program, just main wash cycle. 3....
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Aug 01, 2011 | Asko 24 in. D3112 Free-Standing Dishwasher
Soap dish does not open during normal cycle on my maytag dishwash
the soap u use may be causing this try cleaning it out real good and use liquid soap
Apr 20, 2009 | Maytag DWU9962 Dishwasher
Dishwasher problem
Symptoms:
Dispenser lid is open. Caked powder at (what would be during normal operation) bottom edge of soap dispenser or caked powder fallen onto dishes or dishwasher bottom. There may be loose powder in rest of dispenser or spilled down inside door or onto dishes underneath dispenser.
Solution:
Keep the area around the soap dispenser lid clear when loading the top tray.
Explanation:
The soap dispenser needs to swing open during the wash cycle. In many dishwashers the top tray has an indentation as wide as the lid of the dispenser. This allows the top tray to be as large deep as possible while still allowing space for the dispenser lid to open. People often pack their dishwasher with things overhanging this gap.
During the wash cycle the catch will release but the overhanging cutlery or crockery prevents the lid from opening all but a few degrees. Some water will splash in but not enough to wash out the soap powder. The soap powder at the bottom of the dispenser will then cake.
When the front door is opened the spring loaded lid, which is partly open, will of course swing fully open and you'll be convinced that the lid opened normally during operation. If this is the problem then if you're very careful and open the door very slowly you can actually hear the lid flip open. Also, depending on when the lid opens, how far it opened during operation and how fast you open the door you may find soap powder spilled down to cover the dishes at the front or down the inside of the door. This happens when you first open the door and obviously there couldn't be loose powder there if the powder had emerged while there was water washing around. Seeing the lid open as you open the door is a lot harder but can be done on some machines.
Oct 24, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Soap dispenser flap not opening
Not a solution but exactly the same problem. I should have sent the machine back (I bought mine about 2008 too) but by now, 2010, the machine is a complete waste of time and money. The soap dispenser fails to open every time, wasting money, water and my patience because I then have to hand wash after all. will try the suggested oil trick, but it was obviously a bad design to start with.
Jul 20, 2008 | Bosch 22 in. SKT5102 Free-Standing...
Dishwasher Issues
I would try using a different soap or less of your current soap.
Jun 21, 2008 | Maytag 24 in. MDB4100 Built-in Dishwasher
Soap dispenser door doesn't open during cycle of my Maytag dishwasher
Kqon, looks like your dispenser has a wax motor. I think the first thing you have to do is remove the inner door and inspect the soap dispensor assy. See if any of the moving parts are broken. This wax motor is 120V so you can run a cheater cord to it to see if it works, but be very careful when doing this. It will expand the plunger and open the flap. If the wax motor operates with 120V applied to it then you want to see if you have power coming from the timer. It will be the tan wire # 27 on the timer harness. You also want to make sure the spring and pin are in place on the dispenser flap. Your part number for the wax motor is 902899. Catriver.
Jan 16, 2008 | Maytag 24 in. PDC3600A Built-in Dishwasher
GE Monogram DIshwasher
Before taking anything to bits, check you aren't just loading the machine in such a way that something (for us, it's usually a frying pan) is stopping the soap dispenser from springing open all the way. A.
Apr 21, 2007 | GE 24 in. Monogram ZBD6880KSS Stainless...
Asko 24 in. D3250 Built-in Dishwasher Logo
313 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
