Question about Sharp AL 1631 Copier
Indicator light shows and i lost the manuel so i don't know what's wrong. i think its the drum but don't know. it won't work now
    Guru:
  • 389 Answers
Hi! Yous problem is CH blinking? Dev unit is not properly installed...Or yous master unit is need to change to another.
The Main problems копиров AL-1000, 1631:
# optics and lazer
- a soiling the white band under left lid, fault E7-04
- a soiling the defensive lens of the block of the lazer, residing on drum; the near edge of the picture leaves light; remove драмом and neatly wipe lens, вычистить отработку in cartridge (is rammed bunker, and отработка is sprayed on lens) # presenting
- does not take sheets from pallet: faulty **** of the seizure or solenoid, openning ****
- an offset of the front edge or застревание papers on sensor of the registrations - is polluted sensor, faulty **** or her(its) solenoid, has weakened spring of the ****
- a crackle in region of the presenting - a roller to registrations left with its place and was displaced to the right # stove
- an senary bursts because of strong load (NGERH0540) of the teflon gross or is broken off her(its) internal salient
- an internal ring бушингов gains ellisic type because of uneven load on them that changes the pressure of the teflon on silicone; as effect, can be swabbed imprint or in general sheet remains in stove
- a finger of the branch on silicone are executed in the manner of tin-plate plate, and sooner cut the furrows on silicone, than execute its function - take away the plate under the first possibility - also standard fault H4 cleares out the code 14 (if thermostats does not work, possible, in him залипли contacts; then it is enough his(its) remove and enough powerfully knock on something - a contacts disperse)
- a sheet stops after passing of the stove - left with its place roller, taking sheet after leaving from stove because of breakage of the near fastening the roller (is found on block of the lazer, and access to him only after removing lid, main board and table optometrists)
- also comes out of building (is polluted) sensor output from копира - a main ajestment of the problems nearly does not create, with the exclusion of шестеренки, providing in motion stove (disappear teeth) # power supply unit - most often flies Q1 # коротроны
- upper in the event of contamination gives uneven thickness of the band on отпечате (remove, wash with soap and высушить)
- трансфер - gives the weak imprint; почистить brush, зачистить copper contacts in копире and contact springs коротрона little sprain # call attention: under wrong installation байпасса (the bypass pallet) iron fastening his(its) mechanism begins to brush against редуктор, heard crackle # фотобарабан rather sensitive to condition red bracket; their advisable change together with drum, otherwise appear the white bands on edge of the drum and white gaps on imprint # is sometimes overfilled bunker отработки, and toner is thrown outward, polluting upper corona and defensive lens of the block of the lazer.
Posted on Sep 24, 2009
Need to know how to enter radio code Suzuki 2006 Grand Vitara, have code, don't know how to enter
In your owners manuel, theres a card. Looks like a credit card, white with a light green stripe. (atleast mine is) Theres a 4 diget code on it
thats the code. If you lost it, the dealer can suply you with it.
To enter the code (the radio probably shows C0d----) use the numbers that your radio has for its preset stations
Sep 20, 2012 | Cars & Trucks
We have an Jandy Ji8000. We have really enjoyed having it for years. Just lately, the filter goes on at the wrong time. If we try to turn it off at the panel in the house, it will not turn off. We have to...
Look up Zodiac Pool systems, on the web site you can find a list of service providers in your area. You may be looking at replacing your automation at this point.
Mar 24, 2017 | Jandy AQUALINK RS TELELINK KIT
2007 fatboy lost the 'flashing' of turn signals (but they still light up), lost horn, lost rear break light. All fuses in the fusebox are OK. I also lost all gauges (speedo, neutral indicator,...
Your turn signals (but not your running lights), horn and a few other things are on the "accessories" fuse in your electrical circuit, I think. If the fuse is not blown, I would guess that you have a bad connection in the power lead for that circuit. I'm not sure of what I'm going to say here because I don't work on the newer bikes but in the older bikes, the "orange" colored wires carried the battery voltage to the individual components much like "red" wires used to do in most DC circuits. I'd look for a bad connection in a plug somewhere. I hope this helps but like I said, I don't know a lot about the newer bikes. I mostly work on the older bikes that the dealers will not work on any longer.
Good Luck
Steve
Aug 13, 2011 | Harley Davidson FLSTF Fat boy Motorcycles
I lost my manuel and don't know how to record a
Select the model of your phone from the list beginning at
http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl/
Jul 09, 2011 | Uniden DECT 6.0 Cordless Phone
I've lost my manual. Does the red light that
The red light that looks like an empty cylinder on the Sharp AL 1631 Grayscale Copier panel is the "drum replacement required" indicator. The "cartridge replacement" indicator is represented by 6 dots forming a triangular shape.
The drum replacement indicator lights up when there are about 1000 copies left until its end of life. It is only when the indicator starts blinking that the drum really needs replacement.
The part number for the drum is AL-100DR.
I hope this helps.
Nov 19, 2009 | Sharp AL 1631 Copier
After replacing rear drums the ABS light is on
you probably bumped the sensor and now it isn't close enough to the gear looking thingy to read it. just set the abs sensor a little closer so the light goes off but the sensor ins't touching the gear thingy. I have had the same problem. I bet your abs isn't working right now. see if you your brakes lock up when you slam on them.
Sep 07, 2009 | 2000 Ford Focus
What could be wrong ?
Hi Please check your manuel I think this is an indicator that your bulb may have gone , usually with most projectors this is what a red flashing light means . At the price they are | hope for your sake I am wrong but I dont think so Sorry .. regards vortash
May 13, 2009 | Sony Televison & Video
Sharp AL 1631 Copier Logo
76 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
