Question about Maytag Washing Machines
Cannot remove agitator from speed queen top loader washer
Cannot remove agitatorfrom speed queen washing machine
  • 177 Answers
SOURCE: Speed Queen Top Loader heavy duty washer
First unplug the machine, now take off the front panel, two screws at the bottom of the front panel, front panel swings up and off.
check to make sure the six springs are still in place.
Under the tub is bearing housing between the tub and base usually white in color, under this is a plastic ring, does it seem to float easily when you move the tub. it could be broken. Also look around for loose or missing screws.
If all seems fine, make sure you have all four rubber feet on, level machine, in the front first side to side, then pull machine toward you to bring rear legs off floor, these are self leveling, have someone assist and make sure they are not stuck, use a pliers and break loose if they are. So with the machine on its front feet and the back feet off the ground set the machine down on all four feet check level front to back adjust as needed on the front legs. You should reset rear legs as you adjust the front. now with machine level tight the nut between the front legs and the base locking them.
This should help, if machine still shakes it could be the balance ring, has lost if solution its filled with a salt water solution, the hard part is you need to find it under the tub cover. we will go into the detail if we need to. ask more questions later
Posted on Jul 08, 2008
  • 177 Answers
SOURCE: Speed queen top loader
You should be able to get a replacement agitator from partselect.com or repairclinic.com. look on line for an agitator however How old is the washer, would you give me the serial number.
T
Posted on Jul 29, 2008
  • 3 Answers
SOURCE: Whirlpool top loader washing machine - agitator does not turn
If it does not drain, I'd check the water pump first (for an obstruction - I found a sock in my pump and that fixed my problem) ... see this video - the top is getting to the WM drive shaft (transmission), but it shows you how to remove the pump first: http://www.youtube.com/watch?v=WLPGs2UMUJc&feature=related
If it does drain ... Is it just the TOP part of the agitator not working, or the whole thing (agitator is in 2 parts)? If just the TOP, you probably just need new "dogs" (agitator dogs). Check this out:
http://www.youtube.com/watch?v=V5wIN1J70-Y ... it shows you what to do.
If it is the whole agitator that is stuck, that video will show you how to remove it (remove a single bolt) and you can see if there is an obstruction keep the agitator from moving.
If there's no obstruction or the water pump isn't stuck, you might be looking at a new drive/transmission = expensive. Good luck
Posted on Jul 02, 2009
localwonder
  • 6784 Answers
SOURCE: how do you remove agitator
Hi. The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly, which is removable as well. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to preform a combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytag's may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Posted on Aug 04, 2009
  • 84 Answers
SOURCE: My speed queen top loader is leaking water during
It is probably the pump. Run the washer with the front off of it. The pump is on the bottom of the motor.
Easy repair.
Posted on Jan 12, 2010
HOW DO I PULL AGITATOR ON A SPEED QUEEN WASHING MACHINE MODEL AWS76NW
down the center about 6 inches deep u have a 7/16 inch screw remove it then u can pull the first part of agitator, the second pc can be pulled out after but may not be that easy may have to pry it up
Mar 01, 2015 | Speed Queen AWS76NW Top Load Washer
Smell coming from AWN32 speed queen top loading washer
All washing machine "smell" when the lid is left closed for more than one day. If it is really bad it might be something inside the body of the machine or something caught under the agitator.
Inside the body work. Unscrew the three screws at the bottom of the front panel. Lift the bottom of the panel forward and up. Remove. Make sure the machine is unplugged and switched off before reaching into the body work. Look for something "smelly"
Agitator - switch off and unplug - depending on the model unscrew the top cap on the agitator. Some models do not have an screw cap although it might look so. Reach with both hands into the machine and grab the agitator at it bottom flanges hands opposite each other. Pull up hard - it does not let go easily- make sure it doesn't have a top screw cap. To replace just push back until it clicks or replace and tighten the top cap.
Dec 13, 2013 | Speed Queen Washer Top Load AWN432
How do i take agitator out of speed queen awn412 washer
To remove the agitator all that ya need to do is grab the bottom edges of it and pull it straight up and out..if locked onto a hub under it and is just held to that hub by several tabs
Gene
Aug 25, 2011 | Speed Queen AWN412 Top Load Washer
When the spin cycle begins the washer vibirates and moves on the floor. After the spin cycle reaches the maxium speed it stops. The springs are fine, but what else could be wrong?
The machine is probably not leveled properly. To level the machine, partly fill it with water. Make sure that the drum is standing in the middle of the machine and then adjust the machine until the water is at the same level all around at the nearest set of holes to the water. Check that the drum is still in the center of the outer drum. Make sure that the adjusting feet are all firmly on the floor and that you cannot rock the machine at all by hand. A top loader must be 100% level or it will shake.
Jul 25, 2011 | Speed Queen AWS44NW Top Load Washer
Just bought a speed queen top loader model LWS 17
that top cap/container on top of the agitator is for fabric softner if you use it. As to why it wont spin possible overload or if you bought a second hand machine could be a belt or gearbox ??
Suggest you put the detergent in the bowl, the fabric softner on top of the agitator, drop the clothes in till it's full not pushing down on the clothing - the weight rating of the washer is for wet clothes weight not dry clothes. If this doesn't get you going in the right direction then call someone who knows what their doing, it's too good a machine to risk stuffing it if you dont know what your doing
Dec 10, 2009 | Washing Machines
My speed queen top loader is leaking water during the washing period. Water is coming out of the bottom of the washing machine while it is washing
Easy repair.
Nov 08, 2009 | Speed Queen AWS52NW Top Load Washer
Speed Queen doesn't agitate.
can i see solution that ziobob got on nov.08 2008
Nov 08, 2008 | Speed Queen AWS52NW Top Load Washer
Water leak under the rotating drum
Have you removed the front panel?
If not remove front panel two screws 5/16 on bottom
Start the washer in a cycle. look with a flash lite and look for leak.
It maybe the rubber boot.
Please let me know if you have any other questions.
I will also need model number, because a AWS52NW is a top loader model number not a front loader.
T
Jul 27, 2008 | Speed Queen AWS52NW Top Load Washer
T
Jul 27, 2008 | Speed Queen AWS44NW Top Load Washer
Washing Machines Logo
155 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
