Question about KitchenAid KEYS750LQ Electric Dryer
Does not turn on at all. I checked the breaker and its good.
  • A Miller May 11, 2010
    You are plugged in, correct? Might you be in a circuit that is GFI protected? You are certain the door is closed?
  • 27 Answers
Usually is a thermal fuse problem... un plug machine... remove back cover... will be small strip with two wires going to it somewhere near the exhaust duct... needs to be replaced
Posted on Sep 24, 2009
No power to the display, dryer will not turn on
First thing you need to do is check the Circuit Breaker for the dryer. If it is tripped unplug the dryer and reset the Circuit Breaker. Now plug in the dryer and try to run it. If it does not work again check the Circuit Breaker again if it is tripped again unplug dryer and call someone that can help you or fix it. If the Circuit Breaker is not tripped check for good power readings on both power lines coming into the dryer. Should have 110V or more on each line to neutral, and 220V or more between each line. If you do not have the correct voltage at each line check Circuit Breaker for good power coming out.
Mar 13, 2014 | Maytag MDE9700AYW Neptune 174 Electric...
Truck won't start key turns get a click out of fuse panel checked breaker good battery test good power going to panel not to starter checked wire off battery to starter good Is their another bre
make sure all grounds are clean and area of metal that ground wire's bolt to are clean and rust free if that check's out ok there could be a break in a wire going to the starter and most starter's have two wire's going to them and those both need to have power going to them one drop's off when key is turned to starting mode volt meter work's good for this or test light or the starter could be bad
Mar 04, 2012 | 2004 Ford F150
When turned on it just humms and blows the 15 amp breaker in the panel
you have a dead short! Check the compressor you are plugging in. Check cord for damage to wires. If cord looks good and compressor is in good shape where you are plugging in is overloading circuit and tripping breaker. Does the breaker hold for any period of time when you reset it?
Jan 19, 2012 | Air Tools & Compressors
I was following TheMobilian's walkthrough of figuring out the problems with dryer model 11060622990, and I have successfully determined that the timer, the heating element, and the thermostats are all...
you should have gotten 240 volts, between the two top legs. I would check the circuit breaker in the panel, it should be a 30 amp breaker. I would pull off the cover of the panel, with a meter check and make sure it is putting out the 240 volts from the breaker, if it is not then I would go to a home improvement or hardware store and buy a new one, if it is then I would turn the breaker off and pull the cover off the outlet, inspect and make sure the wires are connected and not burnt. If all is good then I would turn the breaker on and test the legs. Good Luck Tim
Dec 23, 2010 | Dryers
All of a sudden dryer won't come on. Checked connection, OK.
Check your circuit breakers. Your unit usually has a double circuit breaker. Find the correct circuit breaker and turn it to the off position to reset it then turn it back on.
Good luck
Sep 29, 2010 | LG DLE2532W Electric Dryer
I have a 1990 hd ultr clasic tour glide. when i use my turn signals my instrument lights and gauges flash. all grounds have been cleaned and look good.
Your turn signals are controlled by the turn signal cancelling unit and the only thing it has to do with the lights and gauges is the power source. Check your "lights" circuit breaker. It sounds like you may have a short circuit somewhere causing the circuit breaker to break and then reset, only to break again. This happening over and over will appear to be a turn signal flashing. Find the circuit breakers, usually under the seat, and listen when you turn the turn signals on. See if you can hear the circuit breaker "clicking". Good Luck!
Jan 27, 2010 | 2000 Harley Davidson FLHTCUI Electra Glide...
No water in the house from well. circuit breaker is trippe. when i move it to on...it sparks & trips immediately (pump does respond & turns on briefly)
There is really only Three options...
1) The pump is out
2) Wiring is shorted
3) Breaker is bad
The reason it sparks when you turn the breaker to " ON " is there is a dead short. An easy way to check a 110v wire and breaker is to disconnect it from the pump and hook it to a SPARE NEW receptacle and plug in a light... turn on the breaker and see if it still sparks and if the light comes on. If you don't get sparks and the light comes on, then your pump is shorted and needs repaired or replaced. If it does spark when you turn on the breaker then you need to replace wire and or breaker.
Hope this Helps,
RSMITH972278
P.S. PLEASE RATE MY ASSISTANCE
Dec 02, 2009 | Plumbing
RUNS BUT WON'T HEAT
Is it gas or electric ? if it's gas, good be a ignitor, flame sensor, etc. if electric...check your breaker. is this a new home, new wiring, just moved in ? don't just visually inspect the breaker either, I mean physically turn the breaker (it should be 30amp) "off" and then back "on". breakers can partially trip, which will still supply the unit with 120v hence allowing the drum to turn, but the heater cannot come on.
NOTE; keep in mind if the breaker is tripped, have the unit inspected, it's a symptom to another problem.
good luck
Sep 26, 2009 | Whirlpool Dryers
Hotpoint washing machine keeps tripping electric
First unplug your washer. Check the ground on the washer and make sure it isn't loose; this would be a good time to inspect the wiring harness for any problems. Next check the outlet (turn off the electric to that breaker first) make sure all the wires are tight and are making good contact; pay special attention to the neutral (white) wire. If that seems fine, and you are comfortable with going into you breaker panel, turn off that breaker and check the hot (the wire on the breaker) to make sure it isn't loose and then check the neutral wire. If either of these wires seem loose tighten them down....a loose wire will move when a load is put on it and cause the breaker to trip. If all seems normal and washer is still tripping the breaker you might want to replace the breaker.....they can go bad. Good luck!
Aug 26, 2009 | Hotpoint Washing Machines
Was welding 10 min later mach. quit power was good circut breaker was good and fuses were good
it probably has a fuse for overheating safety, or else the feed motor fried
Apr 24, 2009 | Welding Tools
KitchenAid KEYS750LQ Electric Dryer Logo
123 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
