Question about Linksys EtherFast Cable/DSL Router
How to set up for internet use with muliple pc's
Trying to figure out how to use a router with a cable modem to get internet with 2 computers and a xbox360
    Scholar:
  • 102 Answers
I assume you router came with a configuration manual or CD. Its very easy. Once by following the instructions, go into the router like:
http://192.168.x.x (whatever IP is suggested by the manufacturer) and make sure the internet connection type. Mostly the ISP's use 'Dynamic IP' (if you scroll other ones will be like PPPoE, PPTP etc). Select Dynamic IP and restart your router and you will see after few seconds that your router has started to offer IP's to the internal Lan Pool. connect your ethernet cables from the computers to the router (behind the router you will find the ports to connect them)
In your Network settings in the router assign an internal IP to the router like '192.168.x.x' subnet mask 255.255.255.0, enable DHCP server and assign the internal LAN ip pool like 192.168.x.20 to 192.168.x.100 and you are all set.
Very important:
Security settings Always make sure your router (if in case its wireless router as well) assign and use an authentic security feature like 'WPA, PSK or WPA2, PSK' you could also use WEP (but WEP its getting old) I recommend WPA higly for wireless clients. If you have NONE wireless connections to offer than do not worry about it.
OR
simply put the CD inside your system connect it with router and it will guide you through for configuring it.
I hope it helped
Posted on Dec 16, 2007
How to set up my router with modem?
Connect the router to the modem with an ethernet cable, CAT 5, 6 or 7. Try amazon.
Jul 19, 2016 | TP-LINK Computers & Internet
I can not connect to the Internet. I have WiFi connection but can't do anything else
Plug your computer/laptop directly into router. Can you get to the Internet then?
If you CANNOT get to the internet when your computer is plugged into the router, reboot your router. If it doesn't have a power switch, unplug it. Leave it unplugged. Next, you need to figure out if you have another modem for DSL or Cable. If you do have another DSL or Cable modem, unplug that device to. After 5 minutes has elapsed for both devices being unpowered, plug in the DSL or Cable modem to the power source. Keep the router unplugged from power. After your DSL or Cable modem has powered up for 5 minutes, plug your router into the power source. Wait a few minutes. Reboot your computer/laptop. Try the wireless connection again.
If you CAN get to the internet when your computer is plugged into the router. Reboot your computer. Try to connect again. If you cannot connect after rebooting, make sure you are connecting to YOUR OWN wireless access point and not someone else's.
Do you have other computers/laptops/wifi devices that CAN/CANNOT connect to your wireless / access the Internet?
Jul 03, 2011 | Computers & Internet
Can not connect to the internet through router if i hook up the internet straight to computer it works but when i try through the router the computer has no internet connection but it picks up the router
Some cable modems look for the MAC address of the computer until reset. You can either enter the MAC address from the PC into the MAC spoofing setting on the router OR disconnect and unplug the cable modem for 24 hours and start over. First, plug in the cable modem and connect the cable. 2nd, plug the router cable into the modem and router and plug in the router's power supply. Then connect the computer and it should work fine.
Feb 27, 2011 | Computers & Internet
I got a NETGEAR router and I have been trying to get my Motorola SURFboard to recognize it. I had the USB connection installed and the NETGEAR uses ethernet, so I tried to install the ethernet but my...
The Cable modem must be disconnected from the computer. You cannot use USB and Ethernet at the same time.
1. Turn off power to the Cable Modem and the Netgear Router. Do the same with the computer.
2. Connect an ethernet cable from the modem to the router's WAN (Internet) port.
3. Connect another ethernet cable from one of the remaining 4 LAN ports on the router to the computer's ethernet port.
4. Now power on the Cable Modem ONLY. Wait for the modem to sync up with your service provider
5. After about 2-5 minutes power up the router and wait about 1-2 minutes.
6. Now power on your PC.
Check and see if you have internet access. If not you may have to uninstall any cable modem software related to USB connection. if this is the case, then you may have to repeat steps 4-6.
Since most cable internet providers do not use proprietary connection settings, your internet connection should be up and running without changing any settings in the router or modem.
If this does not resolve your issues, we can continue to work with you.
Nov 29, 2010 | Arris SURFboard® SB5101 Cable Modem
Router not working right
When there is limited connectivity check if the laptop gets an IP address from the router. ELse try configuring it manually. Restart the laptop if necessary.
Please rate if helpful.
Thanks
Apr 14, 2010 | Gateway 802.11g Wireless DSL/Cable Router...
Changed from AT&T to a cable company for DSL. Trying to set up
You need to "fool" your cable box into thinking that the wireless router is the computer. This just means that the modem is locking into the first ip address it can get... it tends to block out all others. Here's how to remedy and allow everything to get access...
1 Shut off computers, routers, everything.
2. Turn on your wireless router FIRST... leave everything else off until you see it's completely booted.
3. Then with the cable connected to the modem/cable box and the router, turn on the cable box/modem and let it cycle up. This should allow the cable modem to "find" the wifi ip address as the main ip.
After that, turn on any other routers, and the computers...
This should allow you access to the net by any of your computers because the wifi router should give all the other comptuers and routers on the system inddividual ip addresses and all should be well...
Give it a try and let me know!
K
Aug 28, 2009 | 2wire (1000-400108-001) Router
My computer can see my router but can't get past my modem
1. delete all the saved networks from your computer
2. Make sure that firewall id disabled in computer
3. Tried to set your wireless as unsecured network and try to connect
4. Uninstall/Reinstall wireless adaptor and tried.
Aug 05, 2009 | Belkin (F5D7230-4) Router (587009)
Trying to program my zonet zsr4154we with comcast modem cannot figure it out tried the sequence in the manual is there something else i must do also
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Configuring router for Cable Internet
To configure your router for Cable you will need to set your router's WAN (INTERNET) port to 'Dynamic IP' (DHCP) option. The router is set to this option by default.
Configuration steps:
Step 1 Connect the cable modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Connect your computer(s) to the router's LAN port(s) or establish connection to it wirelessly.
Step 2 Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.0.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, default is `admin' for both.
Step 3 After logging into the router select Setup. Set Internet Connection to 'Dynamic IP (DHCP)' option.
Setup'.
- Select the MAC Cloning option. Click on Clone MAC Address button. Do this from the computer which the cable modem was directly connected to the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router. Reboot your cable modem as well.
- Log in to the router and go to Status page. Note what IP address it is getting on the WAN (INTERNET) interface. If the IP address you see under WAN (INTERNET) appears to be in the same range you are using on your network (e.g. 192.168.0.x), you will need to change the range you are using on your LAN to something different, e.g. 192.168.88.x. You can do this on your router under Setup > LAN Setup. Note that after changing the IP of your router you will only be able to access it through its new IP, e.g. 192.168.88.1.
- Uninstall your antivirus/firewall software (sometimes disabling or closing the software is not enough) and reboot your PC. After establishing the Internet connection through the router, reinstall your antivirus/firewall software.
Jul 24, 2009 | Computers & Internet
Not recognized by cable modem
Turn everything off for 2 minutes, cable modem, router and pc.
Turn on modem and wait 2 minutes for the modem to sync to TW.
Turn on router after 2 mins and wait until the router syncs with the modem.
Turn on PC
It sounds like your router lost its connection to the cable modem, which happens from time to time. TW will not help with your router. I worked for a cable co and the router and modem losing sync was the at least 70% of the calls. FYI cable doesn't use DSL,just the phone co.
May 19, 2009 | Zoom X6 Adsl Modem/router Rohs...
Linksys EtherFast Cable/DSL Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
