We bought a PolarWind portable air conditioner for the upstairs in our home. It states it is a 9000btu. It was working fine. Pullling water out of the air and then it quit working and we need to troubleshoot the problem, however, we cannot find anything like it online. Please respond. Thanks Model MPA-09CR Ser No B116140021607119120019
    President:
  • 3,433 Answers
What do you mean it quit working?
Posted on Sep 24, 2009
Mastercool Adobe P550A portable water cooler. Where can I get a user manual?
try searching on line for a water dispenser manual rather than a water cooler manual
Jun 11, 2015 | Mastercool Heating & Cooling
I am looking for instructional manuel for danby 9000btu portable air conditioners
You'll find one at this link, as long as you have a model number. These are every product that Danby makes or has made int he last 5 years or so. Good luck.
http://www.retrevo.com/samples/Danby-manuals.html#Air Conditioner
Jul 22, 2011 | Kitchen Ranges
Can't control my air conditioner with remote controller. What can I ddo?
The first thing to do is change the batteries in the hand-held remote control. Then make sure that you are close enough to the unit and that the receiver's sensor is not dirty or obstructed.
Jul 11, 2011 | Haier 9000BTU Portable Air Conditioner
AC unit seems to be working normally but not cooling house
If you are referring to the secondary pan there could be a problem with your drain line.i would find the drain at the exterior of your home and **** it out with a wet vac..most A.H.Us have float switches or moisture sensors.They will shut down the unit if the drain clogs.
Jun 21, 2009 | Weather King 10AJA3601AH Air Conditioner
Exhaust hose
i could not find that model number on the haier website www.haieramerica.com you can get the manuals and parts list there. you dont need the haier hose however lowes and home depot sell what im guessing is three or four inch hose that you can use say a dryer vent flex hose or alumaflex hose to connect this unit. unless you are going for the looks.
May 31, 2009 | Haier Heating & Cooling
Exhaust fan running slow
sounds like the compressor is turning off cause of high pressure. check the coil that the exhaust hose connects to, if dirty clean it. if the fan is not blowing enough air threw the coil the unit will build up high side pressure and cut out, but will turn back on when pressure drops. if that dont help, maybe the fan motor is bad or needs taken apart and oiled.
May 31, 2009 | Maytag Portable Air Conditioner M6P09S2A
9000btu Haier portable air conditioner HPAC99ER doesnt blow cold air. What do I need to do?
I own the Haier 9,000-BTU Portable Air Conditioner - White. This is the second day that my unit has blow out air that smells really bad. I went to check my unit to find that there was a leak of some sort of chemical that smells like what is blowing from my unit. What should I do?
Jun 06, 2008 | Haier Heating & Cooling
Installation
This is apparently a new product, and not having provided me with a model number, I was only able to ascertain that this is a dual hose model? If so, then I would assume that since there is no direct correlation between 1 hose and the other, that it probably doesn't matter, since both hoses are utilized for proper operation. Click the link below for more information.
http://www.rainbowappliance.com/Air-Conditioners-1/Danby-DPAC90061-9000BTU-115V-PORT-AC-DANBY-3340.html?utm_medium=shoppingengine&utm_source=yahooshopping&cvsfa=673&cvsfe=3&cvsfp=DPAC90061
Jun 03, 2008 | Danby 7,000 BTU Portable Air Conditioner -...
Heating & Cooling Logo
465 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
