Question about Sony KDS-55A3000 55" HDTV
TV doesn't turn on
My sony bravia kds-55a3000 doesn't turn on..I hear a buzzing sound and the power light blinks and then the red lamp light blinks
  • 476 Answers
If it does not give a picture at all not even for a moment, i would suspect a bad power supply, the circuit has quite a few components and either one of those could be giving you trouble.
Posted on Sep 24, 2009
Sony kds 55a3000 sound but no picture
I hate to say it but maybe the new lamp is bad.
Dec 07, 2012 | Sony KDS-55A3000 55" HDTV
Sony kds-r60xbr2 power wont come on and hte power led is blinking red 5 times
The 5 blinks is indicating the lamp ballast needs replacement your model uses the Sony lamp Ballast 147401211 for sony models KDF42E2000, KDS-50A2000, KDS-50A2010, KDS-55A200, KDS-60A2000, KDS-60A2010, & KDS-60XBR2 amd LDS-R60XBR2
Which is available at the bottom of the page at the following link. The ballast comes with installation instructions,
http://www.tvrepairworld.com/sony_circuit_boards/sony_dlp_circuit_boards
Aug 04, 2012 | Sony KDS-R60XBR2 Television
Green power light blinks, and TV comes on, and goes out, and power light goes red
Sounds like a problem with the power supply. After it shuts off do any other lights blink, apart from power LED turning red? Please provide this info as it is a self-diagnostic code that will help identify the problem.
Sep 16, 2011 | Sony KDS-55A3000 55" HDTV
Sony Bravia KDS-55A3000 while watching last night screen went black as if someone turned the TV off when attempting to turn it back on the the power indicator light flashes green repeatedly stops then a...
It sounds like the lamp has failed. It is advisable to use a genuine Sony lamp. The part number for is XL-5200. It will cost around 180.00. That should fix you problem. If you cannot find the lamp local to you can order it form Sony at.
1800-222-SONY
I hope this help,
Skyassoc
Dec 15, 2010 | Sony KDS-55A3000 55" HDTV
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Power button goes from green to red then lamp button blinks no picture or sound
Lamp in tv is dead and need to be replaced to get tv back in action.
Lamp replacement procedure is easy and would be written in user manual.
Please buy Sony original lamp to get bright picture in tv.
Thanks.
Jul 08, 2010 | Sony KDS-55A3000 55" HDTV
I have a 52 inch sony bravia. turn it on and i hear a buzzing sound then the red standby light blinks 13 times.....what gives. I need help
Sounds like the lamp is blown. Check your manual to see what the blinking lights mean and how to check the lamp.
Jan 16, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
I have a Sony Bravia KDS-60A3000. I changed the lamp, plugged in the TV and it was working. Was trying to reset lamp indicator, power went off, red indicator light is blinking and cannot get TV to turn off...
I went to another tech site and saw a suggestion to unplug the TV for a couple hours and then plug back in to see if this helped, but they also indicated this could be a serious power problem. I was really concerned, but tried it and it worked! I think it was running some kind of diagnostics after the new lamp was placed. Back up and running!
Dec 31, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony kds-r50xbr1 turns itself off and then green light blinks 52
I too have a Sony KDS-R60XBR1 tv and the issue that you are experiencing is due to one of your fans in the rear of the tv is not working.  The tv automatically shuts off in protective mode.  Make sure the POWER/STANDBY light is blinking and not the lamp light below it.  Is the power/standby blinking 4 times in red? If, yes then its a fan that needs to be replaced.  If its the lamp light blinking then you need to replace the lamp.  The lamp is easy to replace by ordering the lamp either from Sony for $250 or find it cheaper for approx. $150 from other DLP sources and replace youself by following your manual.  I hope this helps you.
Apr 22, 2009 | Sony KDS-R50XBR1 50" HDTV
Tv won't turn on red lights blinking
You are hearing the spark gap mounted on the lamp ballast board. If you can hear that sound, that means everything in the lamp driver circuit is working except the lamp!
Get a new lamp.
michtech
Jan 31, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Open Questions:
Sony KDS-55A3000 55" HDTV Logo
364 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
