Fan not turning on
Turned off power to drain the pan, and now the fan won't turn back on. Pan is still slightly full, and I thought there might be a reset button inside the panel of the fan.
    President:
  • 3,433 Answers
Finish draining the pan Unplugthe unit and turn off the switch then plug back in and turn it on.. Here's hoping.
Posted on Sep 24, 2009
HOW DO I GET THE WATER TO DRAIN?
Sounds like your drain needs a strap. Does all the water drain out as soon as the unit turns off?
Jul 26, 2017 | Heating & Cooling
How to drain and fill transmission fluid in 2012 chevy malibu?
GET NEW GASKET AND FILTER FOR TRANNY ALONG WITH THE FLUID (BEFORE YOU BEGINE)
GET A LARGE FLAT DRAIN PAN.
PUT CAR UP ON 4 JACK STANDS.
place drain pan under tranny pan.
undo tranny pan screws - allow one corner to hang lower than the other corner (to allow fluid to drain) slowly remove them all.
Its messy! empty tranny pan into drain pan. set tranny pan to the side. undo the filter clamp, carefully remove the filter - set into the drain pan, remove the gasket around the tranny body/tranny pan.
Clean tranny block surface with clean cloth. install new filter, install clamp tightly. Clean tranny pan, place gasket onto pan and then reinstall tranny pan. (this only change the fluid in the tranny body and pan) If you wan the fluid out of the torque convertor you have pull the pan under the torque convertor and turn the convertor so you can get at the drain plug. Allow fluid to drain into drain pan. Reinstall drain plug and pan. (you will need a lot of fluid) Check manual for qty. Place car back on to ground/floor. Refill tranny through filler tube. Do not start the engine until oil is at full mark, and when you do start it do not all it to run for than 4 minutes - stop and add more fluid and check full mark again (repeat until no longer sinks below full mark. gently test drive around you block -- come back and check level while engine running. Top up if needed.
Siphon out excess above full mark. Test drive around 3 block,
come back check full mark. Because the torque convertor was emptied it can take a while to get all the air out it.
Jul 19, 2014 | 2012 Chevrolet Malibu
Were do i get the manuel for model number ph3 12r03 is the model number were or how do I drain the water and can you send me a manual
Here is the link to the manual:
http://s3.amazonaws.com/szmanuals/b0348062b23e23cd40550b61e1dc5f43
Here are those particular instructions:
Compressor Indicator
The " " icon will light up on the control panel display when the compressor turns on. The " " icon will turn off when the compressor shuts off.
Emergency Condensate Holding Tank
When the room temperature is low and the indoor humidity is high, the air conditioner may not be able to evaporate some of the moisture fast enough. When this happens, the water will accumulate in an emergency condensate tank inside the unit. Once the emergency condensate tank is full, the unit will automatically shut off and the " " will appear on the control panel display. To empty the condensate tank, unscrew the screw plug at the bottom back of the unit. You will need a small pan, approximately 1" high to catch the water coming out of the condensate tank. Once the condensate tank is drained, the unit will begin working within a few minutes. The emergency condensate tank holds approximate
ly 1.5 Liters of water.
Another option is to purchase a small hose from a hardware store that can fit around the 5/8" drain plug on the back of the unit and drain the unit into a gravity drain or larger pan for continuous drainage.
To resume operation quickly, empty the water container according to the following steps:
1. Turn the unit off. Do not move the unit when the water container is full.
2. Place the drain pan accessory under the drainage port at the back of the unit.
3. Remove the screw plug from the drain hole. The condensate water will drain out automatically. When the drain pan is full, screw the screw plug back onto the drainage hole to stop the water flow. Empty the drain pan. Repeat until all the water is emptied.
Once the water container has been emptied, screw the plug back onto the drain hole. Do not allow the
water to drip continuously into the drain pan, as it might easily overflow.
Jul 13, 2014 | Soleus KY-34 Portable Air Conditioner
Hi, I just purchased this used. It was working fine for one day, but now it won't turn on. Can u help? Haier CPN12XH9 12000 BTU Portable Air
If the water collection tank is full, it will not turn ON. Since you said the unit worked fine for one day and now it won't turn ON, more than likely, that's the problem. After draining the tank, the unit should reset itself and turn ON like it should.
The drain plug is on the rear of the unit, just above floor level. You can either drain it into a low sided pan or bowl that's capable of holding up yo a quart of water. O r roll the unit to a floor drain or outside to drain it. If you choose to drain it into a pan, turn the unit OFF & unplug it, before draining it.
I hope this helped you and thanks for choosing FixYa
Jul 25, 2011 | Haier CPN12XH9 Portable Air Conditioner
Asko dishwasher did not finish complete washing cycle and now has a very low humming sound. It will not start washing cycle. I have turned it on and off but after I turn it back on humming sound...
Some wash water may have gotten into the bottom pan area below the wash tub. If water has overflowed from the tub into the bottom pan, the drain pump will activate and remain active until water has been removed from the bottom pan. To check for this, the lower front panels will need to be removed. With power turned off at the breaker, a wet-vac can be used to remove water from the bottom pan. If there was water there, check the door seals, door closure and make sure the drain hose has a high-drain loop. If the drain is shared with the kitchen sink, it may simply have backed up into the dishwasher through the drain hose when a full sink was emptied. The best drain system is for the dishwasher to have its own separate drain.
Jun 29, 2011 | Asko Dishwashers
It keeps switching off about 15 minutes after it is turned on. i would like a manual for the wood burning stove 37557.
If your Air Conditioner keeps turning off the first thing I would check is your drain pan. Most AC's have a safety switch that will turn off the AC if the drain pan is full. This keeps the drain pan from overflowing and causing water damage to your home. There are various ways to clear the drain from fishing wire, blowing with compress air, to forcing pressurized water through the drain
Jan 30, 2011 | Heating & Cooling
I have a split system SAP-K181AHA, SAP-K241AHA that is leaking water from unit inside house.
Air conditioners wring moisture from the surrounding air that collects in a pan under the cooling coil in the inside unit.
Chances are that the condensate drain is plugged or the drain pan is plugged. Look for a hose that exits the inside unit and runs to a drain. You can follow it back to the drain pan of the A/C unit. If there is water sitting in the pan, then either the hose or pan or both are plugged.
Turn the unit off, get a small bucket and remove the drain tube. Catch the water in the bucket. Blow through the drain line until it's clear. If the thought of doing this is too repulsive, then use an air compressor or even a manual tire pump. Now check the drain pan in the unit for debris and remove as much as possible from the pan and the drain fitting.
Both the pan and drain line should be checked at the beginning of each cooling season.
Reinstall the drain tube and see how it works!
Jan 07, 2010 | Sanyo Heating & Cooling
Our everstar is stuck on p1 and will not turn on what do we do
The P1 code means the lower water bowl is full.
Put a pan under it an pull the lower plug (some 10" below the upper drain plug that I hope you have a hose attached to.
Jul 17, 2009 | Danby DPAC8020 Air Conditioner
A/C drain pan not draining.
The drain must have one and only one trap in it. A trap is where the pipe goes up then back down so that water is kept in a section of the pipe - will stop the air from blowing thru the drain and not letting the water drain - may not sound right but it is! I've seen this many times! Drain traps are not understood at all by the HVAC industry.
May 12, 2009 | Heating & Cooling
Drain pan underneath fridge is filling on a daily basis
The system is designed to evaporate that water using the warmth of the compressor.. is your compressor warm ? (the drip tray sits on top of it) I see that model has an Ic e maker... to check that the ice maker refill is not running on too long, switch off the ice maker, by lifting the wire arm that checks the level of the ice in the storage bucket.. leave it turned off for a day or two.. empty the drain pan, and check it again after 24 hours.. but if the ice is already full, the water problem may APPEAR to be resolved already, but will return when the level drops and the ice production begins again.
If it is just condensate, then the drain pan should be able to contain the amount it produces, but 3-days straight, would indicate to me, that is not that... if your water pressure is good, it may be that the ice tray filler solenoid is being held open a fraction too long (maybe a second or so) and as the fridge is new, it will be making lots of ice to fill the container up,... so lots of small overfills.. mounting up to a full drain pan. Under normal use,.. other than parties and festive nights, when you use a lot, the water should evaporate faster than it is produced, but it shouldn't be happening at all.. if it is that, then turn the tap at the back of the fridge to where the cold water dispenser slows down slightly.. that should be enough to prevent it continuing.. IF that's the problem.
Apr 24, 2017 | Frigidaire FSC23F7D Side by Side...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
