Question about Sharp EL-1701C Calculator
Can't set tax rate on my EL-1607P - Sharp EL-1701C Calculator
SOURCE: Setting Tax rate
Push the Tax + button
Push the Rate button
Put in the rate you would like to set
Posted on Jan 22, 2008
SOURCE: Set Tax Rate
Type in the rate of tax you want to use, then press rate and then press tax+ :)
Posted on Jul 14, 2008
SOURCE: SETTING TAX RATE
On your Sharp press
CA
C.CE
C.CE
RATE SET(+TAX Key)
175(No decimals for they are not taken into consideration)
RATE SET(+TAX Key)
To check if all went well press
CA
C.CE
C.CE
RATE RECALL(-TAX Key)
It should read your tax rate.
Posted on Jan 29, 2009
  • 3 Answers
SOURCE: Set tax rate for Sharp EL-1701C
I Finally figured it out after playing with it for almost 1/2 an hour!
Hit 2nd then Tax + (rate set) it will appear as 0.000 enter your tax rate... mine is 5% so I enter 5.0 then hit 2nd and Tax + (rate set again) And it will work!
It is glorious!!!
Answered By James Soltys from: Edmonton, Alberta Canada
Posted on Apr 10, 2009
SOURCE: NEED TO SET TAX RATE
Solution #1 has it backward..
(tax rate), STR, TAX+ (or TAX-)
Example- San Francisco sales tax = 9.5% you enter 9.5, STR, TAX+.
now it functions as (amount entered) plus tax. Example- find the total with tax for a purchase of $14.99 14.99, TAX+ Calculator will show 16.41
Posted on Apr 16, 2010
HOW DO SET TAX RATE ON SHARP ELSI MATE EL-2125
Easy. Press M- key [has RATE SET] above it. This will shown your current setting say 17.5. Amend to 20.0 and Press M- key again. Rate should now be set at 20%.
Test by entering:
100 and pressing +TAX key - Answer should be 20.
100 and pressing -TAX Key - Answer should be 83.33
Jan 04, 2011 | Sharp EL-330AB Calculator
How do you set the tax rate
Example: setting 5% tax rate
1. move mode switch to 'rate set '
2. press 5 (for tax rate ) followed by TAX+ button
3. Move mode switch to GT
to add tax to e.g 200 type:
200 TAX+, the result is 210
Feb 16, 2009 | Sharp EL-1197PII Calculator
TAX SET
Press +TAX
press the number you need to set it at
Press +TAX again then CA
worked for me!!
Hope this helps
Oct 21, 2008 | Sharp EL-1801P Calculator
Setting tax
If the model is EL-2125 , and not 2125C or 2125E the following will work
1)switch on
2)press CE and then CA (you should see 0. with small 00 in top left hand corner but nothing else)
3)press M- button (rate set button),current tax rate 17.50% will appear with tax at left hand side
4) type new rate eg 15.00 (making sure to hit the decimal and two zeros, tax at the left and % should still be on the screen)
5) press M- (rate set button) (small 00 will appear in top left hand corner)
6) press = ( new rate and G will appear small 02 in top left hand corner and = sign below it)
hope this works for you, please let me know either way
David
Jul 31, 2008 | Hanns.G Corporation HW191D 19" LCD Monitor
Jun 05, 2008 | Sharp EL-2192Rll Calculator
SETTING TAX RATE
On your Sharp press
CA
C.CE
C.CE
RATE SET(+TAX Key)
RATE SET(+TAX Key)
CA
C.CE
C.CE
May 01, 2008 | Sharp EL-330AB Calculator
Set tax
To set your tax rate:
1. Be sure to switch to "rate set" from GT
2. Enter the tax amount like so - if your tax rate is 7% type in 7%
3. Go back to the GT setting and it should work...at least that is how I fixed mine! I did the same thing last week & have no manual!
Hope this helps you
Mar 03, 2008 | Sharp EL-2196BL Calculator
It is glorious!!!
Jan 20, 2008 | Sharp EL-1701C Calculator
Need to change tax function on Sharp EL-334A
I had the same problem and finally figured it out. Here's what you do:
Press C-CE twice
Press +TAX (Rate set)
Key in your new tax rate as an integer (e.g. 5)
Press +Tax (Rate set) again
Press C-CE
Then you're ready to calculate with the new rate!
Now what's the GT button for?
Nov 19, 2007 | Sharp EL-334AB Calculator
Sharp EL-1701C Calculator Logo
160 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
