Question about Westinghouse W33001 30 in. HD-Ready LCD Television
Same as above
Westinghouse 3001 and it went out today, power supply has the green light on like it is working? and the front of the TV has the green light on and the picture won't work at all. Should I junk this thing and buy a new one?
Thanks
  • bolibruch1 Sep 24, 2009
    I belive the only reason I have sound is because I have it running through my reciever. but I will test the sound out of the TV when I get home. Now the Tv doesn't even power up? when you plug it in the led on the front goes green for 1 second, then it goes red, and stays red. while it is red it won't turn on at all none of the buttons do anything....
  • bolibruch1 Sep 25, 2009
  • 476 Answers
If it has sound but no raster or no picture it might be a back light problem, this could be worth the repair, check with your local repair shop and see what a repair of this type could run.
Posted on Sep 24, 2009
  • jaime vargas Sep 24, 2009
    If it does not have sound, Then there could be something wrong with the power supply. Some of these sets have replaceable boards, so this too could be something to look into. Bestbuy and Partstore have parts listings in their websites provided you give them a model number you can find out prices of a power supply board there and make a decision on what you might want to do.good luck!
Got new tv Westinghouse LTV-32W1 32 Inch Widescreen LCD TV LTV-32W1 in need of help! do not have the remote and trying to progam it to turn on but blue light turns green and picture turns blank
in this case i have to know if your tuner is working fine or not. First of all i like you to connect any external player Exp. DVD or blue-ray player if that works with audio then it is inverter board. if audio doesn't work then its main board. Also you will find out that if dvd is working fine on your tv than your tv setting is wrong or the tunes is dead. either way if tuner is gone then you have to change the main board. Either way let me know what went wrong i can provide you more information about what part need and where can you get it from.
Please let me know if you have any further questions or concerns. Also rate me if you like this post.
Thanks.
May 11, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Has power but won't turn on
Make sure that it does the same with other PC first.
You may have problem in the power supply section, look for bad caps first, the problem can also be bad lamps (I had to fix one today with bad lamps assembly). This unit is really hard to disassemble, the switch assembly is attached to the front section, so be REAL careful when the front and the back section come apart, see pictures here: http://s807.photobucket.com/albums/yy352/budm/Westinghouse%20LCM-22W3/
Feb 28, 2010 | Westinghouse Electric LCM-22W2 Monitor
Astar 30 inch model ltv-3001 will not turn on
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com
Jan 20, 2009 | Astar LTV-3201 32 in. LCD Television
I have a Astar LTV-3001 and can't turn on. and I have other LTV-30MA This one have sound , no picture, can you please guive me sam help, I use to repair, Tvs. a time a go
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Jan 03, 2009 | Astar LTV-3001 TV
Westinghouse Green Screen
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Jun 10, 2008 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
No Picture - Lamp Indicator Blinking
This may be the main power supply, or the lamp supply. This is providing that the new lamp is okay.
The service tech will swap out the modules to service the set.
Jerry G.
May 15, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Westinghouse LTV 20V 2SL
You will need to replace the power supply on this set. The blue light is controlled by a 5v line so it still comes on. If you have the power supply replaced their are some bad caps on it that have popped this will fix your problem.
Feb 05, 2008 | Westinghouse W32001 20 in. HD-Ready LCD...
Model LTV-27w2 westinghouse
The tv got a heat sensor, the only way to fix tv , if you are a tv tech, is to buy a bottle of "freez it" spray small sections of tv in side. It will be clearly where the fault is if you spray correct part that give trouble. Replace that part and Tv will be Ok.
Nov 04, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Westinghouse W33001 30 in. HD-Ready LCD Television Logo
303 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
