Question about IO Magic Corporation GigaBank (I250HD35) 250 GB USB 2.0 Hard Drive
Our external hard drive is constantly blinking and our computer can't find the drive. How do we get it to connect again?
  • 696 Answers
If the computer is not seeing the drive, first try it on a different computer to confirm if the problem is with the drive or with the computer. If it works reply and I will guide you through figuring out what's wrong with your computer. Second, take the drive to your local PC shop and have the technicians move the hard drive inside it to a new enclosure and test it, if it works, buy the enclosure and you should be fine. Third, if neither of the first two suggestions works, then reply back with your location(Country, State, City) and I will be happy to direct you to a professional data recovery facility near you to help retrieve your files.
Hope this helps FixYa,
Chris
Posted on Sep 24, 2009
3 Suggested Answers
SOURCE: Lacie 750 GB External hard drive
Dear,
Please check your BIOS setting. Make sure that Boot from USB device/drive is disable.
Reply....
Regards,
Rakesh Kumar
Posted on Apr 01, 2009
virtualhost
  • 2185 Answers
SOURCE: I have a 320gb toshiba
This is because there is a connection problem between the external drive and the computer. If you have changed cables to no avail, you can open the casing of the external drive where you will find the hard disk inside. Unplug the two cables connected to the harddisk and replug it after a minute. Then try again. If it still does not work, then you need to buy just a usb enclosure and plug the harddisk there to be able to use it again.
Hope this helps. Thank you for using FixYa.
Posted on Jan 13, 2011
My seagate freeagent 1tb is blinking whit lights and my computer does not recognize it. Help me
***Please NOTE***
Touch the drive and put your ear to it, to test if the drive is spinning and working. Do this while it is powered on. Also, try disconnecting the USB cable, reboot the computer, re-connect USB cable to another USB port on computer. If you still have the same issue, try the below solutions.
  • Make sure the computer and external hard drive are powered on.
  • Disconnect the external drive's USB or the eSATA cable, which ever one you're using.
  • Disconnect the power supply plug from the external drive.
  • Power off the computer.
  • Disconnect the computer's power supply cord for 60 seconds.
  • Reconnect the computer.
  • Power on the computer.
  • Connect the power supply to the external drive.
  • Connect the drive's USB or the eSATA cable and check for detection.
If the still no detection and still blinking lights on the drive, check the power supply to the drive.
Check to see what the led light on the power supply is doing.
If it's blinking, power down the drive, unplug data cable and then reconnect the power supply to another electrical outlet. If it still blinks repeatedly, then you power supply is bad.
If the led is solid (lit and not blinking) follow the same steps from above to connect it to another outlet.
Next, plug the power supply to the external drive and power it up.
If the power supply starts to blink repeatedly, then your controller board inside the enclosure is bad.
Thank you for the opportunity to help you.
Jun 04, 2011 | Seagate FreeAgent Pro 1TB External USB...
I just got a 1.5 TB WD ext HD. It blinks evenly & slowly when the computer is sleeping. It blinks rapidly when the computer is awakened, & becomes solid during the time the computer is...
Seems perfectly normal, the slow blink while sleeping shows you that it is active but not in use (witched off but immediately available) The rapid blinking is the machine accessing the disk and the constant light means it has power but not connected. The occasional blink is probably the HDD parking the reading head or shutting down the disk or both.
Nothing to worry about.
Jan 15, 2011 | Western Digital My Book Essential 1TB...
I have a 320gb toshiba external hard drive, i've been using it around 3 years without any trouble. A few days ago i lost the cable connecting it to the PC. I bought a few cables but no use. Doesn't...
Jan 13, 2011 | Toshiba 120GB USB 2.0 Portable External...
My Seagate FreeAgent Go 500 GB, stopped working in the middle of copying some of its data into my PC. Now instead of the constant light-up when connecting to the pc, it blinks continually. And the hard...
First i would remove and reinstall drivers for this device,next try device on another system if it works ok on another system drive ok if not drive has failed.Good luck!!!
Jan 08, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Blinking light flashes continually. The pc can not access the eternal hard drive. I have re-started the pc several times and the pc will not recognize the external hard drive. The WD External Hard Drive...
try to connect the usb port properly maybe there is a loose contact. and try to remove all the gadgets connected in the computer... only connect the external HDD
Oct 30, 2010 | Western Digital External USB 2.0 80 GB...
When I t urn on my laci external harddrive I get a fast pace blinking light and when I put my ear to it, it seems that the motor wants to start running then nothing Just a constant blinking blue light!
It seems that you have a problem with the disk-drive inside the case. If it still is under warranty, exercise the warranty to get it replaced.
If not, then disassemble the case, and remove the disk-drive.
Connect it as a "slave" disk-drive inside a desktop computer,
to see if it can be read. If not, then it is "dead".
You could buy an identical disk-drive, and put it inside the case,
to construct a "new" external disk-drive.
Sep 28, 2010 | LaCie (300770) 250 GB Hard Drive
I have a constant flashing green light and computer wont detect it
First, try connecting the external drive to another computer. If the second computer fails to detect it, chances are that the housing or, the drive inside have failed. Determining this requires a basic knowledge of external drives. If however the drive is rckognized the the second computer, turn off the first computer and strt it up again (not restart). Then plug your external drive to a usb port directly (not to a hub) and, it should be detected.
Nov 24, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
External hard drive can not be seen on My Computer
It might still be connected but may need a letter assigned to the drive, go into disk management and if it is there right click it and assign it a letter. If it is not then look at this forum for more ideas
http://www.techsupportforum.com/hardware-support/hard-drive-support/269193-acomdata-external-hd-not-recognized.html
I hope this helps
to get into disk management, go to Control Panel> administrative tools> computer management and will see disk managment in the left menu (for vista)
Jan 10, 2009 | Computers & Internet
Unable to see the 250Gb external drive shown on 'my computer' when plugged in
Hi - thanks for your quick response, much appreciated .........I will try again to explain!!
We have purchased a 250Gb Maxtor portable hard drive which I was told was plug and play. We have followed the instructions for connection but no drive letter is showing up and the external drive is lit up and making a constant beeping noise. The computer doesn't seem to be recognising that an external drive has been connected.
To test our computer out I have connected an 8Gb memory stick to the processor and it shows up as drive H immediately.
FYI - we have XP running on our machine.
Hope you can help!! Thanks
Oct 25, 2008 | Maxtor MaXLine Plus II 250GB 7200 RPM...
IO Magic Corporation GigaBank  (I250HD35) 250 GB USB 2.0 Hard Drive Logo
1,053 people viewed this question
Top IO Magic Corporation Computers & Internet Experts
David Payne
David Payne
Are you an IO Magic Corporation Computer and Internet Expert? Answer questions, earn points and help others
