Question about LG CU500 Cellular Phone
Reset att medianet parental control password
Accidently set parental control on my LG phone and need to reset the password as I do know default password.
Parental controls
HI,
Do the following for unlock the parental control. For this you should need the remote for the DVD payer.
1. Press the set-up button on the remote (set-up display will come on the TV screen )
2. Using Right arrow button or Left arrow button select DVD Setup menu
3. Using Down arrow select Parental control and press Enter button
4. now you can change the parental rating using up down arrows
If it ask for password the read the following carefully and do the same and enjoy your videos.
PARENTAL CONTROL LEVELS 1-8
The Parental Lock allows you to limit the use of your DVD Player to only those DVD discs that do not exceed the rating you specify. When the Parental Control is set, DVD discs that support this feature will play only after the password has been entered. However, typically only discs produced by major entertainment companies support Parental Control. Discs not supporting this feature will be "immune" to Lock-Out. When you attempt to change the Parental Control setting, you are prompted for a password. This of course makes sense, as this option would be useless if your kids could enter the Setup Menu and disable it! If there is no user password set, you'll be prompted to enter a new password. Choose a 4-Digit numeric password and write it down in Case you forget it. Key in the password and press ENTER. After the password is set, press ENTER on the CHILD option. You can choose from 8 levels of Parental Control, corresponding to the standard rating system in the USA. The available levels and their equivalent ratings are listed to the right.
PASSWORD - CHANGE
Here is where you can set an additional password to the default factory password. The procedures to change an existing password or enter a new password are the same - you must enter the OLD PASSWORD, then key in your new password twice to confirm. If you are entering a new password, or replacing a password you have forgotten, use the factory default password of 3351 as the OLD PASSWORD. If you are changing a previously entered password, you may enter that value as the old password.
A. Remember to keep in mind that the key to the the factory default password of 3351
B. Once the factory password has been changed, you should keep the password written in a safe location as a reminder if needed
Ajin
Jul 07, 2013 | Televison & Video
How to reset password on playstation 2
Hi Jessica
There are two methods to reset the Parental Control on a PlayStation 2, the Quick Method and the Easy Method.
The Quick Method to Reset Parental Control
  • Power on the PS2
  • Press the Reset button
  • Inset an R-rated and wait until the board comes up telling you that Parental Control is on
  • Hit the Select button
  • At the enter password prompt, hit the Select button
  • At the Delete password prompt, enter in your password
  • Hit the X button
If you do not know the Parental Control password on your Ps2, try the known defaults of 1111 and 7444.
The Easy Method to Reset Parental Control
  • Unplug the PS2
  • Wait approximately 72 hours
Hope this helps :)
Mar 20, 2011 | Video Game Consoles & Games
Locked phone
If you never set a password, the default password is always the last 4 digits of your cell phone's number. Hope this helps!
Jan 06, 2009 | LG VX5300 Cellular Phone
Need to change the parental control password
press select on your controller and then enter password 7444 this will delete current password and allow you to set a new one...
Nov 22, 2008 | Sony PlayStation 2 (PS2) Console
Internet settings for Shine KE 970 for AT&T
i tried so many different websites in order to access the internet for at&t on my lg shine ke970. i finally found a link that was really easy to understand and worked. here it is....
Check out http://forums.wireless.att.com/cng/board/message?board.id=LG&message.id=25732&jump=true#M25732 for the mediaNET settings.
Sep 28, 2008 | LG Shine KE970 Cellular Phone
Configuration settings
I used a few diffrent lg phones to get what I use. I have a V3x and my settings are diffrent but here is what I have
Name Media Net
Hmepage http://device.home
proxy on
ip addy 066.209.011.032
port 80
Acess point Media Net
mms
prfile name Att
mmsc http://mmsc.cingular.com
internet mode http
proxy addy .066.209.011.032
proxy port 80
connection MediaNet
Jan 10, 2008 | LG Shine KE970 Cellular Phone
How do you reset forgotten parental control password?
need password reset...also, forgotten how to enter password...MODEL NUMBER IS PDV-228...PLEASE HELP!!!
Dec 29, 2007 | Mintek MDP-1070
Kg800 can not go into att medianet
i think when you brought it, they locked your internet access...
Dec 21, 2007 | LG KG800 Cellular Phone
Disconnect power to the TV. The power interruption will allow you to reset the parental control password to the default password of 0000.
To change the password after disconnecting the power, do the following:
1. Press the Menu button on the remote.
2. Arrow up / down to SET LOCK CODE
The lock icom will appear
3. Arrow left / right to operate
4. Press 0 to access the lock code
5. The first digit will be highlighted.
Arrow left / right to select the number
Arrow up / down to move to the next digit
4. Continue to follow these directions for all 4 code numbers.
5. Arrow up / down to FINISH
6. Arrow left / right to save settings and exit.
The password has now been reset.
Nov 29, 2007 | JVC AV-36260 TV
LG CU500 Cellular Phone Logo
247 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
